Creating a new host, the “IPv4 Address” does not automatically populate, upon clicking “Suggest new” I receive;
Failed to fetch a free IP from proxy foreman-test.#### (https://foreman-test.####:8443): ERF12-8202 [ProxyAPI::ProxyException]: Unable to retrieve unused IP ([RestClient::BadRequest]: 400 Bad Request) for proxy https://foreman-test.####:8443/dhcp
An unused IP address is populated in “IPv4 Address”.
Foreman 3.15
Proxy 3.15 (co-hosted)
smart_proxy_dhcp_dnsmasq 1.0
Ubuntu 22.04.5
2025-08-20T00:26:32 [D] Rack::Handler::WEBrick is invoked.
2025-08-20T00:26:32 4b5de642 [I] Started GET /dhcp/192.168.200.0/unused_ip from=192.168.200.100&to=192.168.200.200
2025-08-20T00:26:32 4b5de642 [D] verifying remote client 192.168.200.4 against trusted_hosts ["foreman-test.####"]
2025-08-20T00:26:32 4b5de642 [E] nil can't be coerced into Integer
2025-08-20T00:26:32 4b5de642 [W] Error details for nil can't be coerced into Integer: <TypeError>: nil can't be coerced into Integer
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:25:in `+'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:25:in `block in mark_ip_as_allocated'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:23:in `synchronize'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:23:in `mark_ip_as_allocated'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:65:in `block (2 levels) in find_free_ip'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:61:in `synchronize'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:61:in `block in find_free_ip'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:101:in `block in random_index'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:97:in `loop'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:97:in `random_index'
/usr/share/foreman-proxy/modules/dhcp_common/free_ips.rb:59:in `find_free_ip'
/usr/share/foreman-proxy/modules/dhcp_common/server.rb:110:in `unused_ip'
/usr/share/foreman-proxy/modules/dhcp/dhcp_api.rb:36:in `block in <class:DhcpApi>'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1644:in `call'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1644:in `block in compile!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:994:in `block (3 levels) in route!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1013:in `route_eval'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:994:in `block (2 levels) in route!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1042:in `block in process_route'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1040:in `catch'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1040:in `process_route'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:992:in `block in route!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:991:in `each'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:991:in `route!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1106:in `block in dispatch!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1080:in `block in invoke'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1080:in `catch'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1080:in `invoke'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1103:in `dispatch!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:926:in `block in call!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:926:in `call!'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:915:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/method_override.rb:24:in `call'
/usr/share/foreman-proxy/lib/proxy/log.rb:102:in `call'
/usr/share/foreman-proxy/lib/proxy/request_id_middleware.rb:11:in `call'
/usr/lib/ruby/vendor_ruby/rack/protection/xss_header.rb:18:in `call'
/usr/lib/ruby/vendor_ruby/rack/protection/path_traversal.rb:16:in `call'
/usr/lib/ruby/vendor_ruby/rack/protection/json_csrf.rb:26:in `call'
/usr/lib/ruby/vendor_ruby/rack/protection/base.rb:50:in `call'
/usr/lib/ruby/vendor_ruby/rack/protection/frame_options.rb:31:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/null_logger.rb:11:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/head.rb:14:in `call'
/usr/lib/ruby/vendor_ruby/sinatra/show_exceptions.rb:22:in `call'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:194:in `call'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1959:in `call'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1511:in `block in call'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1738:in `synchronize'
/usr/lib/ruby/vendor_ruby/sinatra/base.rb:1511:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/urlmap.rb:77:in `block in call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/urlmap.rb:61:in `each'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/urlmap.rb:61:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/builder.rb:177:in `call'
/usr/share/rubygems-integration/all/gems/rack-2.1.4/lib/rack/handler/webrick.rb:88:in `service'
/usr/share/rubygems-integration/all/gems/webrick-1.7.0/lib/webrick/httpserver.rb:140:in `service'
/usr/share/rubygems-integration/all/gems/webrick-1.7.0/lib/webrick/httpserver.rb:96:in `run'
/usr/share/rubygems-integration/all/gems/webrick-1.7.0/lib/webrick/server.rb:310:in `block in start_thread'
/usr/lib/ruby/vendor_ruby/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
Initially I’d thought that this was simply the unused_ip API not being supported in the dhcp_dnsmasq plugin but reading through the code it appears that it populates an internal list in the subnet service with the contents of the leases file and then the call to unused_ip just calls back directly to the base functionality so near as I can tell it SHOULD work.
