Hello foreman-users,
I am running smart proxy on windows and was updating it along with
foreman to 1.14.1.
However, dhcpsapi fails to load for some reason and I am out of ideas why:
> W, [2017-02-08T18:44:27.153727 ] WARN – : Couldn't find settings file C:/TheForeman/smart-proxy/config/settings.d/dhcp_native_ms.yml. Using default settings.
> E, [2017-02-08T18:44:27.169390 ] ERROR – : Disabling all modules in the group ['dhcp_native_ms', 'dhcp'] due to a failure in one of them: cannot load such file – dhcpsapi
> D, [2017-02-08T18:44:27.169390 ] DEBUG – : ["C:/TheForeman/smart-proxy/modules/dhcp_native_ms/plugin_configuration.rb:5:in require'", "C:/TheForeman/smart-proxy/modules/dhcp_native_ms/plugin_configuration.rb:5:in
load_classes'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:294:in load_classes'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:243:in
load_settings'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:81:in block in load_provider_settings'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:80:in
each'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:80:in load_provider_settings'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:155:in
block in initialize_plugins'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:155:in each'", "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:155:in
initialize_plugins'", "C:/TheForeman/smart-proxy/lib/launcher.rb:134:in launch'", "C:/TheForeman/smart-proxy/bin/smart-proxy:6:in
<main>'"]
I ran bundle update as usual:
> $ bundle update
> Your Gemfile lists the gem single_test (>= 0) more than once.
> You should probably keep only one of them.
> While it's not a problem now, it could cause errors if you change the version of just one of them later.
> Your Gemfile lists the gem rdoc (>= 0) more than once.
> Fetching gem metadata from http://rubygems.org/…
> Fetching version metadata from http://rubygems.org/…
> Resolving dependencies…
> Using concurrent-ruby 1.0.4
> Using ffi 1.9.17
> Using dhcpsapi 0.0.11
> Using highline 1.7.8
> Using json 2.0.3
> Using rack 1.5.5
> Using rack-protection 1.5.3
> Using rb-inotify 0.9.8
> Using rb-kqueue 0.2.4
> Using tilt 2.0.6
> Using sinatra 1.4.8
> Using smart_proxy 1.14.1 from source at .
> Using win32-service 0.8.8
> Using bundler 1.10.6
> Bundle updated!
> Gems in the groups development, test, krb5, puppet_proxy_legacy, bmc, libvirt, p uppet and puppetca were not installed.
Also, dhcpsapi loads without trouble:
> [1] pry(main)> require 'dhcpsapi'
> => true
I can only think of an load path issue; all other gems seem to load
correctly however. For the time being I reverted back to 1.13-stable
Suggestions welcome …
Daniel Helgenberger (helge000)
daniel@helgenberger.net
Late to the game, but seeing this on 1.14.3 too with dhcp.yaml… on a
centos 6.6 box. Is this another centos ruby 1.8.7 error?
On Wednesday, February 8, 2017 at 12:15:45 PM UTC-6, Daniel Helgenberger wrote:
> foreman to 1.14.1.
> > W, [2017-02-08T18:44:27.153727 ] WARN -- : Couldn't find settings file
> default settings.
> > E, [2017-02-08T18:44:27.169390 ] ERROR -- : Disabling all modules in the
> load such file -- dhcpsapi
> > D, [2017-02-08T18:44:27.169390 ] DEBUG -- :
> `require'",
> `load_classes'",
> `load_classes'",
> `load_settings'",
> "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:81:in `block in
> "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:80:in `each'",
> `load_provider_settings'",
> "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:155:in `block in
> "C:/TheForeman/smart-proxy/lib/proxy/plugin_initializer.rb:155:in `each'",
> `initialize_plugins'", "C:/TheForeman/smart-proxy/lib/launcher.rb:134:in
> `launch'", "C:/TheForeman/smart-proxy/bin/smart-proxy:6:in `'"]
> > $ bundle update
> version of
> version of
> > Fetching gem metadata from http://rubygems.org/............
> > Fetching version metadata from http://rubygems.org/..
> > Resolving dependencies.......
> > Using ffi 1.9.17
> > Using json 2.0.3
> > Using rack 1.5.5
> > Using tilt 2.0.6
> > Using sinatra 1.4.8
> > Bundle updated!
> libvirt, p
> > => true
> Suggestions welcome ...
> Thanks,
> dan...@helgenberger.net
hah, nevermind, you're on windows… odd we're seeing the same thing.
On Monday, May 8, 2017 at 2:56:42 PM UTC-5, Byron Miller wrote:
> Late to the game, but seeing this on 1.14.3 too with dhcp.yaml.. on a
> On Wednesday, February 8, 2017 at 12:15:45 PM UTC-6, Daniel Helgenberger > wrote:
>> foreman to 1.14.1.
>> why:
>> default settings.
>> cannot load such file -- dhcpsapi
>> `require'",
>> `load_classes'",
>> `load_classes'",
>> `load_settings'",
>> > $ bundle update
>> version of
>> version of
>> > Using ffi 1.9.17
>> > Using json 2.0.3
>> > Using rack 1.5.5
>> > Using tilt 2.0.6
>> > Using sinatra 1.4.8
>> > Bundle updated!
>> libvirt, p
>> > => true
>> Thanks,
