I just installed the RPM: foreman-0.1.6-2 but I keep on getting error
message: Directory index forbidden by Options directive: /var/lib/
foreman/public (when running via passenger)
I have it running fine in my test environment which is running from
source, but I don't seem to be able to get it to run with the RPM. I
have all the requirements installed. I can run foreman via script/
server -e production --port 8080, but I can't run it via passenger.
OS=CentOS 5.5
RPM's:
httpd-2.2.3-43.el5.centos.3
rubygem-sqlite3-ruby-1.2.4-1.el5
rubygem-rake-0.8.7-2.el5
Gems:
daemon_controller (0.2.5)
fastthread (1.0.7)
file-tail (1.0.5)
mysql (2.8.1, 2.7)
passenger (2.2.11)
rack (1.0.1)
rake (0.8.7)
rubygems-update (1.3.7)
spruz (0.2.2)
sqlite3-ruby (1.2.4)
Any Ideas?
BTW: This is my /etc/httpd/conf.d/foreman.conf:
<VirtualHost x.x.x.x:80>
ServerName server.dev.domain.com.pem
ServerAlias foreman
DocumentRoot /var/lib/foreman/public
RailsAutoDetect On
AddDefaultCharset UTF-8
Grant access to puppet reports
Alias /report /var/lib/puppet/rrd/
<Directory /var/lib/puppet/rrd/>
PassengerEnabled off
Options Indexes
Order deny,allow
Allow from all
</Directory>
</VirtualHost>
<VirtualHost x.x.x.x:443>
ServerName Server.domain.com
ServerAlias foreman
RailsAutoDetect On
Use puppet certi ficates for SSL
SSLEngine on
SSLCertificateFile /etc/puppet/ssl/certs/
SSLCertificateKeyFile /etc/puppet/ssl/private_keys/
SSLCertificateChainFile /etc/puppet/ssl/ca/ca_crt.pem
SSLCACertificateFile /etc/puppet/ssl/ca/ca_crt.pem
SSLCARevocationFile /etc/puppet/ssl/ca/ca_crl.pem
SSLVerifyClient optional
SSLVerifyDepth 3
SSLOptions +StdEnvVars
</VirtualHost>
> OS=CentOS 5.5
> RPM's:
> Gems:
> fastthread (1.0.7)
> file-tail (1.0.5)
> mysql (2.8.1, 2.7)
> passenger (2.2.11)
> rack (1.0.1)
> rake (0.8.7)
> spruz (0.2.2)
> Any Ideas?
> Thanks,
double check that ~foreman/config/environment.rb is owner by foreman user
and not root.
it sounds like passenger doesnt start up correctly… probably more info at
apache logs.
Ohad
ServerAlias foreman
RailsAutoDetect On
Options Indexes
Order deny,allow
Allow from all
ServerAlias foreman
RailsAutoDetect On
SSLEngine on
SSLVerifyDepth 3
source, but I don’t seem to be able to get it to run with the RPM. I
server -e production --port 8080, but I can’t run it via passenger.
OS=CentOS 5.5
RPM’s:
Gems:
fastthread (1.0.7)
file-tail (1.0.5)
mysql (2.8.1, 2.7)
passenger (2.2.11)
rack (1.0.1)
rake (0.8.7)
spruz (0.2.2)
Any Ideas?
“Foreman users” group.
foreman-users+unsubscribe@googlegroups.comforeman-users%2Bunsubscribe@googlegroups.com
I'm checking /etc/httpd/logs/error_log, and this is what I get:
[Fri Dec 10 14:05:47 2010] [notice] suEXEC mechanism enabled
(wrapper: /usr/sbin/suexec)
[Fri Dec 10 14:05:47 2010] [notice] Digest: generating secret for
digest authentication …
[Fri Dec 10 14:05:47 2010] [notice] Digest: done
[Fri Dec 10 14:05:47 2010] [notice] Apache/2.2.3 (CentOS) configured
– resuming normal operations
[Fri Dec 10 14:05:52 2010] [error] [client xx.xx.xx.xx] Directory
index forbidden by Options directive: /var/lib/foreman/public/
[Fri Dec 10 14:05:53 2010] [error] [client xx.xx.xx.xx] Directory
[Fri Dec 10 14:05:54 2010] [error] [client xx.xx.xx.xx] Directory
[Fri Dec 10 14:05:58 2010] [error] [client xx.xx.xx.xx] Directory
[Fri Dec 10 14:06:18 2010] [error] [client xx.xx.xx.xx] Directory
/usr/share/foreman/config/environment.rb is owned by Foreman and the
permission is 755…
> and not root.
> it sounds like passenger doesnt start up correctly... probably more info at
> apache logs.
> Ohad
> > ServerAlias foreman
> > RailsAutoDetect On
> > # Grant access to puppet reports
> > Options Indexes
> > Order deny,allow
> > Allow from all
> > ServerAlias foreman
> > RailsAutoDetect On
> > # Use puppet certi ficates for SSL
> > SSLEngine on
> > SSLVerifyDepth 3
> > > OS=CentOS 5.5
> > > RPM's:
> > > Gems:
> > > fastthread (1.0.7)
> > > file-tail (1.0.5)
> > > mysql (2.8.1, 2.7)
> > > passenger (2.2.11)
> > > rack (1.0.1)
> > > rake (0.8.7)
> > > spruz (0.2.2)
> > > Any Ideas?
> > > Thanks,
> > You received this message because you are subscribed to the Google Groups
> > "Foreman users" group.
> > To post to this group, send email to foreman-users@googlegroups.com.
Also, puppet works fine under the same server and it's running under
passenger. Somehow, the RPM version of foreman under passenger is a
bit of an issue… Somehow the source version works fine provided the
same configs…
> digest authentication ...
> -- resuming normal operations
> permission is 755....
> Thanks,
> > and not root.
> > apache logs.
> > Ohad
> > > ServerAlias foreman
> > > RailsAutoDetect On
> > > Options Indexes
> > > Order deny,allow
> > > Allow from all
> > > ServerAlias foreman
> > > RailsAutoDetect On
> > > SSLEngine on
> > > SSLVerifyDepth 3
> > > > OS=CentOS 5.5
> > > > RPM's:
> > > > Gems:
> > > > fastthread (1.0.7)
> > > > file-tail (1.0.5)
> > > > mysql (2.8.1, 2.7)
> > > > passenger (2.2.11)
> > > > rack (1.0.1)
> > > > rake (0.8.7)
> > > > spruz (0.2.2)
> > > > Any Ideas?
> > > > Thanks,
