Discovered host creation fails with error:
**Oops, we're sorry but something went wrong** Host::Base#name= delegated to primary_interface.name=, but primary_interface is nil: #<Host::Managed id: nil, name: "test-a", last_compile: nil, last_report: "2020-01-10 14:59:47", updated_at: nil, created_at: nil, root_pass: nil, architecture_id: 1, operatingsystem_id: 14, environment_id: 1, ptable_id: 76, medium_id: 20, build: true, comment: "", disk: "", installed_at: nil, model_id: 1, hostgroup_id: 31, owner_id: nil, owner_type: nil, enabled: true, puppet_ca_proxy_id: 1, managed: true, use_image: nil, image_file: nil, uuid: nil, compute_resource_id: nil, puppet_proxy_id: 1, certname: nil, image_id: nil, organization_id: 2, location_id: 1, type: "Host::Managed", otp: nil, realm_id: nil, compute_profile_id: nil, provision_method: nil, grub_pass: "", global_status: 0, lookup_value_matcher: nil, discovery_rule_id: nil, openscap_proxy_id: nil, pxe_loader: "PXELinux BIOS", expired_on: nil, initiated_at: nil, build_errors: nil>
if you create a bond and set it to primary.
Creating Host with full network setup works if you leave the primary interface as it is discovered. After creating set the host bond to primary it works. Creating new host via “create host” and set a bond to primary works without any problems.
foreman-1.24.1-1.el7.noarch
foreman-proxy-1.24.1-1.el7.noarch
and
foreman-1.24.0-15.el7.noarch
foreman-proxy-1.24.0-5.el7.noarch
tfm-rubygem-foreman-tasks-core-0.3.3-1.fm1_24.el7.noarch
tfm-rubygem-foreman_remote_execution-2.0.6-1.fm1_24.el7.noarch
tfm-rubygem-foreman_expire_hosts-6.0.2-1.fm1_24.el7.noarch
tfm-rubygem-foreman_ansible-doc-4.0.3-1.fm1_24.el7.noarch
tfm-rubygem-foreman_discovery-16.0.1-1.fm1_24.el7.noarch
tfm-rubygem-foreman_ansible-4.0.3-1.fm1_24.el7.noarch
tfm-rubygem-foreman_bootdisk-16.0.0-1.fm1_24.el7.noarch
tfm-rubygem-foreman_ansible_core-3.0.1-1.fm1_24.el7.noarch
tfm-rubygem-foreman-tasks-0.17.5-1.fm1_24.el7.noarch
tfm-rubygem-foreman_remote_execution_core-1.3.0-1.el7.noarch
and
LSB Version: | :core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch |
Distributor ID: | RedHatEnterpriseServer |
Description: | Red Hat Enterprise Linux Server release 7.7 (Maipo) |
Release: | 7.7 |
Codename: | Maipo |
Latest patch level.
*Module::DelegationError*
**Host::Base#name= delegated to primary_interface.name=, but primary_interface is nil: #<Host::Managed id: nil, name: "test-a", last_compile: nil, last_report: "2020-01-10 14:59:47", updated_at: nil, created_at: nil, root_pass: nil, architecture_id: 1, operatingsystem_id: 14, environment_id: 1, ptable_id: 76, medium_id: 20, build: true, comment: "", disk: "", installed_at: nil, model_id: 1, hostgroup_id: 31, owner_id: nil, owner_type: nil, enabled: true, puppet_ca_proxy_id: 1, managed: true, use_image: nil, image_file: nil, uuid: nil, compute_resource_id: nil, puppet_proxy_id: 1, certname: nil, image_id: nil, organization_id: 2, location_id: 1, type: "Host::Managed", otp: nil, realm_id: nil, compute_profile_id: nil, provision_method: nil, grub_pass: "", global_status: 0, lookup_value_matcher: nil, discovery_rule_id: nil, openscap_proxy_id: nil, pxe_loader: "PXELinux BIOS", expired_on: nil, initiated_at: nil, build_errors: nil>**
/usr/share/foreman/app/models/host/base.rb:98:in `rescue in name='
/usr/share/foreman/app/models/host/base.rb:98:in `name='
/usr/share/foreman/app/models/concerns/interface_cloning.rb:14:in `block in setup_object_clone'
/usr/share/foreman/app/models/concerns/interface_cloning.rb:13:in `each'
/usr/share/foreman/app/models/concerns/interface_cloning.rb:13:in `setup_object_clone'
/usr/share/foreman/app/models/concerns/interface_cloning.rb:6:in `setup_clone'
/usr/share/foreman/app/models/host/base.rb:361:in `setup_clone'
/usr/share/foreman/app/models/nic/managed.rb:125:in `setup_clone'
/usr/share/foreman/app/models/concerns/orchestration.rb:85:in `valid?'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:84:in `perform_validations'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/validations.rb:52:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:315:in `block in save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:387:in `block in with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `block in transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:239:in `block in within_new_transaction'
/opt/rh/rh-ruby25/root/usr/share/ruby/monitor.rb:226:in `mon_synchronize'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/transaction.rb:236:in `within_new_transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/connection_adapters/abstract/database_statements.rb:254:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:212:in `transaction'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:385:in `with_transaction_returning_status'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/transactions.rb:315:in `save!'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/suppressor.rb:48:in `save!'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-16.0.1/app/services/foreman_discovery/host_converter.rb:54:in `block in unused_ip_for_host'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/relation/delegation.rb:41:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-16.0.1/app/services/foreman_discovery/host_converter.rb:47:in `unused_ip_for_host'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-16.0.1/app/controllers/discovered_hosts_controller.rb:81:in `block in perform_update'
/usr/share/foreman/app/models/taxonomy.rb:61:in `block in no_taxonomy_scope'
/usr/share/foreman/app/models/taxonomy.rb:68:in `block (2 levels) in as_taxonomy'
/usr/share/foreman/app/models/concerns/foreman/thread_session.rb:195:in `as_location'
/usr/share/foreman/app/models/taxonomy.rb:67:in `block in as_taxonomy'
/usr/share/foreman/app/models/concerns/foreman/thread_session.rb:154:in `as_org'
/usr/share/foreman/app/models/taxonomy.rb:66:in `as_taxonomy'
/usr/share/foreman/app/models/taxonomy.rb:60:in `no_taxonomy_scope'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-16.0.1/app/controllers/discovered_hosts_controller.rb:79:in `perform_update'
/opt/theforeman/tfm/root/usr/share/gems/gems/foreman_discovery-16.0.1/app/controllers/discovered_hosts_controller.rb:75:in `update'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:194:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rendering.rb:30:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
/opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/callbacks.rb:41:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/rescue.rb:22:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:34:in `block in process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal/params_wrapper.rb:256:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activerecord-5.2.1/lib/active_record/railties/controller_runtime.rb:24:in `process_action'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/abstract_controller/base.rb:134:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionview-5.2.1/lib/action_view/rendering.rb:32:in `process'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:191:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_controller/metal.rb:252:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:52:in `dispatch'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:34:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:52:in `block in serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/journey/router.rb:35:in `serve'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/routing/route_set.rb:840:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/static_dispatcher.rb:65:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/extractor/recorder.rb:137:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.14/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/tempfile_reaper.rb:15:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/etag.rb:25:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/conditional_get.rb:38:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/head.rb:12:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:232:in `context'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/session/abstract/id.rb:226:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/cookies.rb:670:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:28:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/activesupport-5.2.1/lib/active_support/callbacks.rb:98:in `run_callbacks'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/debug_exceptions.rb:61:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/actionpack-5.2.1/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:38:in `call_app'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/railties-5.2.1/lib/rails/rack/logger.rb:28:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/method_override.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/runtime.rb:22:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/sendfile.rb:111:in `call'
/opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.0.0/lib/secure_headers/middleware.rb:13:in `call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:68:in `block in call'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `each'
/opt/theforeman/tfm-ror52/root/usr/share/gems/gems/rack-2.0.6/lib/rack/urlmap.rb:53:in `call'
