[discovery auto-provision] OS parameters ignored when hostgroup parameter present
My Foreman version is: *Version 1.15.6 *
Discovery plugin: *9.1.5*
In my PXELinux provisioning template, I use the *host_param('param_name')* construct to access parameters assigned *to the operating system*. Just as described here:
http://projects.theforeman.org/projects/foreman/wiki/templatewriting#Host-or-host-group-parameters .
This works fine -- however...
If a single hostgroup parameter exists (don't mistake with Puppet class parameter), then Discovery auto-provision fails to resolve the *host_param('param_name') **from the operating system parameters*.
*<%= host_param('os_param_name') %> *gets populated with nothing (empty string).
Same goes for the old syntax *<%= **@host.params['parameter_name'] %> *.
This happens only when using auto-provision. Does *not* occur when: - using 'Provision' on a discovered host
- using 'Build' on hosts page
- using 'Rebuild config' on hosts page
Probably just a minor code stuff... Help appreciated.
I think if the autoprovisioning fails, managed host should be created instead of the discovered one.
Can you please send the result of GET /api/v2/hosts/<my-new-host-id>?
Also I would like to see the result of host's ENC rendering. It should be available through the UI:
1. Go to hosts list
2. Click on the new host
3. Look for YAML button above host's properties table.
My wild guess would be that the OS is not set for the host for some reason.
as described here:
string).
Thank you for your reply.
Autoprovisioning doesn't really fail as a whole.
It fails to retrieve hostgroup's OS parameter in the assigned template. As a result, I get empty fields instead of values in the rendered PXE template. Happens only when at least one hostgroup parameter exists (as explained in the original post).
The managed host is indeed created and looks just fine.
Example host - autoprovisioned few minutes ago - api curl result: https://pastebin.com/D80t368T
Host's ENC data (YAML dump): https://pastebin.com/Ssezxv4Z
Also, I find some inconsistencies in discovery auto-provision VS locations -- will start another topic for that.
Thanks once again!
1. Go to hosts list
the operating system*. Just as described here: http://projects.theforem
group-parameters .
string).
Google Groups "Foreman users" group.
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/foreman-users/lT1x-_iye5I/unsubscribe.
Jacek Mierzwa
Systems Integration Engineer
*NOVOMATIC Technologies Poland S.A.*(formerly ATSI S.A.)
Krakowska 368Position
32-080 Zabierzów
Poland, Europe
Tel.: +48 12 617 67 15
www.novomatic-tech.com
Does the user who initiates the auto provisioning have "view_params" permission?
If you start foreman-rake console and type:
Host.find(ID).host_param('param_name')
for the already provisioned host, do you get the expected result there?
Can you comment out line "return cached_host_params unless
cached_host_params.blank?" in host_params.rb and see if it helps?
··· On Wed, Nov 29, 2017 at 1:50 PM, Jacek Mierzwa <jmierzwa@lbisa.com> wrote:
the original post).
Thanks once again!
1. Go to hosts list
reason.
My Foreman version is: Version 1.15.6
Discovery plugin: 9.1.5
In my PXELinux provisioning template, I use the host_param('param_name')
construct to access parameters assigned to the operating system. Just as
described here:
host_param('param_name') from the operating system parameters.
<%= host_param('os_param_name') %> gets populated with nothing (empty
string).
Same goes for the old syntax <%= @host.params['parameter_name'] %> .
This happens only when using auto-provision. Does not occur when:
https://groups.google.com/d/topic/foreman-users/lT1x-_iye5I/unsubscribe.
Jacek Mierzwa
32-080 Zabierzów
Poland, Europe
Later,
  Lukas @lzap Zapletal
Autoprovision is triggered by user with Administrator rights. In fact, it's the initial admin user, 'Administrator' ticked on roles tab.
OS parameter name is *'prov_vgname'*.
Now for the foreman-rake console results:
*Host.find(263).host_params('prov_vgname'): *https://pastebin.com/WAa6H2JU *Host.find(263).host_params: *https://pastebin.com/i0JnZvnZ
I got sql debug on so the output is a bit messy. Still, the parameter is there, on the bottom of the second paste. As for the first one - I don't know, you judge it.
Commenting out the given line does indeed help! At least in my case :). Awesome, thanks. I will need you guys once I start the new topic (auto-provision vs location).
Regards!
W dniu środa, 29 listopada 2017 14:47:41 UTC+1 użytkownik Lukas Zapletal napisał:
permission?
On Wed, Nov 29, 2017 at 1:50 PM, Jacek Mierzwa <jmie...@lbisa.com > <javascript:>> wrote:
As a
template.
in
the original post).
locations
Thanks once again!
be
1. Go to hosts list
reason.
as
described here:
class
string).
foreman-user...@googlegroups.com <javascript:>.
To post to this group, send email to forema...@googlegroups.com
<javascript:>.
Jacek Mierzwa
32-080 Zabierzów
Poland, Europe
Groups
an
email to foreman-user...@googlegroups.com <javascript:>.
<javascript:>.
Later,
This needs to be debugged, please create a ticket for us.
LZ
OS parameter name is 'prov_vgname'.
Host.find(263).host_params('prov_vgname'): https://pastebin.com/WAa6H2JU
Host.find(263).host_params: https://pastebin.com/i0JnZvnZ
know, you judge it.
Regards!
permission?
As a
template.
in
the original post).
locations
Thanks once again!
be
1. Go to hosts list
reason.
as
described here:
class
string).
foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
Jacek Mierzwa
32-080 Zabierzów
Poland, Europe
Groups
an
email to foreman-user...@googlegroups.com.
Later,
Later,
