I'm rolling my own discovery iso but UEFI support seems to fail during
build.
Building on a CentOS 7.2 host running build-livecd then build-livecd. The
ISO builds OK and is bootable from legacy BIOS but I need to boot UEFI
hosts too.
I have the below in my 20-packages.ks
grub2-efi
efibootmgr
shim
Missing EFI file (/boot/efi/EFI/*/gcdx64.efi)
Failed to copy EFI files, no EFI Support will be included.
usage: mkefiboot [-h] [–debug] [-d] [-a] [-l LABEL] [-i ICONFILE]
[-n DISKNAME] [-p PRODUCT]
EFIBOOTDIR OUTPUTFILE
mkefiboot: error: /tmp/imgcreate-1xfrZU/iso-E4oXxM/EFI/BOOT is not a
directory
directory
ensure /etc/os-release is present (needed for RHEL 7.0)
What am I missing here? Any help would be appreciated.
Hello, we do only build on Fedora, the livecd tooling in RHEL7 might
be little bit outdated.
What is the reason for shim/efibootloader in discovery image? You want
SecureBoot over PXE?
LZ
On Sun, Oct 22, 2017 at 3:11 PM, Oleg Mcnoleg wrote:
> Hello,
> build.
> ISO builds OK and is bootable from legacy BIOS but I need to boot UEFI hosts
> too.
> grub2-efi
> efibootmgr
> shim
> usage: mkefiboot [-h] [--debug] [-d] [-a] [-l LABEL] [-i ICONFILE]
> directory
> directory
> * ensure /etc/os-release is present (needed for RHEL 7.0)
> Thanks,
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
Worked for me on Fedora, do a PR and I can add those files into the
official build.
LZ
> LZ
>> Hello,
>> build.
>> too.
>> grub2-efi
>> efibootmgr
>> shim
>> directory
>> directory
>> Thanks,
> Later,
> Lukas @lzap Zapletal
Do you have any specifics around your Fedora build env?
Using a fresh Fedora 26 install and latest master.zip, I'm modifying
00-repos-f21.ks and pointing to nightly f24. At which point the
build-livecd-root finishes but I get an offensive message:
dracut: dracut module 'dmsquash-live' cannot be found or installed.
mkinitrd failed
Followed by:
The ISO image doesn't look like a LiveCD ISO image to me.
Which version of Fedora are you building on and what is the contents of
your fedora ks files?
I am on latest stable Fedora, haven't done anything special, but this
is my development instance, I might have some packages that clean
installation don't have. It should be as easy as:
Quick look into yum/dnf database shows this package you are missing: dracut-live
Try to grab it and see if it works, file a README update if you are
using clean environment, there might be other missing bits, thanks!
LZ
On Fri, Oct 27, 2017 at 3:33 PM, Oleg Mcnoleg wrote:
> Hi LZ, thanks for the reply.
> mkinitrd failed
> Followed by:
> Which version of Fedora are you building on and what is the contents of your
> fedora ks files?
> Thanks a lot.
