My setup is configured to use oVirt as computing resource and standard kickstart deployment works as expected but when cloning a VM using TFM the disk will not be created in oVirt.
On the oVirt side the VM is correctly created with NIC, CPU, MEM but without disk.
An identical VM as the original
foreman-1.18.2-1.el7.noarch
katello-3.7.0-4.el7.noarch
foreman-proxy-1.18.2-1.el7.noarch
foreman-ovirt-1.18.2-1.el7.noarch
tfm-rubygem-fog-ovirt-1.0.4-1.el7.noarch
tfm-rubygem-ovirt-engine-sdk-4.2.3-1.el7.x86_64
tfm-rubygem-rbovirt-0.1.6-1.el7.noarch
I don’t see any error in the logs.
Any idea?
I’ve try to figure out how to debug the API call to oVirt without any luck so far, is there a logging level I may increase to see the oVirt API call?
Arsene
