Dracut-need[1691]: curl: (18) transfer closed with 447542611 bytes remaining to read
During the PXEgrub2 loading : experiencing the following error :
dracut-need[1691]: curl: (18) transfer closed with 447542611 bytes remaining to read
3.7.1
RH 8.10
6.546333] tg3 0000:06:00.0 eth0: AEE is disabled
6.546700] IPv6: ADDRCONF(NETDEV_CHANGE): eno8033: link becomes ready
[ 0 OK ] Finished nm-wait-online-inidrtd.service.
Starting dracut initqueue hook…
[ 15.139752] systemd-gpt-auto-generator[1248]: EFI loader partition unknown, exiting.
[ 15.137541] systemd-gpt-auto-generator[1248]: The boot loader did not set EFI variable LoaderDevicePartUUID.
[ 15.380610] dracut initqueue[1575]: % Total % Received % Xferd Average Speed Time Time Time Current
[ 15.083610] dracut initqueue[1575]: Total Upload Total Spent Left Speed
[ 15.083690] dracut initqueue[1575]: 11686
[ 100 5773 100 5773 0 0 11709 0 --:–:-- --:–:-- --:–:-- 11686[ 16.723527] dracut-initqueue[1691]: % Total % Received % Xferd Average Speed Time Time Time Current
[ 16.723617] dracut-initqueue[1691]: Total Upload Total Spent Left Speed
[ 16.723769] dracut-initqueue[1691]: 234k
[ 167.096190] dracut-need[1691]: curl: (18) transfer closed with 447542611 bytes remaining to read
[ 167.168292] loop: module loaded
[ 167.169977] loop: detected capacity change from 0 to 889469
[ 167.162889] dracut-initqueue[1814]: losetup: /tmp/curl_fetch_url1/install.img: Warning: file does not fit into a 512-byte secor; the end of the file will be ignored.
[ 167.165040] dracut-initqueue[1820]: mount: /run/initramfs/squashfs: wrong fs type, bad option, bad superblock on /dev/loop0, missing codepage or helper program, or other error.
[ 167.171333] dracut: FATAL: Failed to find a root filesystem in /tmp/curl_fetch_url1/install.img.
[ 167.173137] dracut: Refusing to continue
[ 167.192192] systemd-shutdown[1]: Sending SIGTERM to remaining processes…
[ 167.192416] systemd-shutdown[1]: Sending SIGKILL to remaining processes…
[ 167.194930] systemd-journald[3421]: Received SIGTERM from PID 1 (systemd-shutdown).
[ 167.228609] systemd-shutdown[1]: Sending SIGKILL to remaining processes…
[ 167.230125] systemd-shutdown[1]: Unmounting file systems.
[ 167.230530] systemd-shutdown[1]: Unmounting /var/lib/nfs/rpc_pipefs.
[ 167.236383] Unmounting /run/credentials/systemd-tmpfiles-setup.service.
[ 167.237323] Unmounting /run/credentials/systemd-sysvamaenb.
[ 167.237771] Unmounting /run/credentials/systemd-sysvamaenb.
[ 167.238138] Unmounting /run/credentials/systemd-sysvamaenb.
[ 167.238491] Unmounting /run/credentials/systemd-sysvamaenb.
[ 167.248910] Rebooting…
[ 167.252337] systemd-shutdown[1]: All filesystems unmounted.
[ 167.258674] systemd-shutdown[1]: Deactivating swap devices.
[ 167.268680] systemd-shutdown[1]: All swapoff.
[ 167.268811] systemd-shutdown[1]: Detaching loop devices
[ 167.268881] systemd-shutdown[1]: Detaching loopback /dev/loop0p.
[ 167.252211] systemd-shutdown[1]: All loop devices detached.
[ 167.257221] systemd-shutdown[1]: Stopping MDD devices
[ 167.251747] systemd-shutdown[1]: All MDD devices stopped.
[ 167.284041] systemd-shutdown[1]: Detaching MDD devices
[ 167.252337] systemd-shutdown[1]: All filesystems,slaps, loop devices, MDD devices and DDD devices detached
[ 167.259541] systemd-shutdown[1]: Syncing filesystems and block devices.
[ 167.259554] systemd-shutdown[1]: Halting system.
[ 167.197702] megaraid_sas 0000:02:00.0: megasas_disable_intr_fusion is called outbound_intr_mask:0x40000009
Thank your for your help/
