Im still on Foreman 1.7.2 and for some reason one of my hosts has no value
for its primary network interface identifier:
foreman_interfaces:
- mac: 00:a0:d1:ee:f9:8d
ip: 192.168.0.104
type: Interface
name:
attrs: {}
virtual: false
link: true
identifier:
managed: true
subnet:
network: 192.168.0.0
mask: 255.255.255.0
gateway: 192.168.0.1
dns_primary: 192.168.0.1
dns_secondary: ''
to: ''
boot_mode: DHCP
ipam: DHCP
- mac: 00:a0:d1:ee:f9:8c
ip:
type: Interface
attrs: {}
virtual: false
link: true
identifier: em1
managed: false
subnet:
Now I am not even sure how that value is filled to be honest. Its not
like secondary interfaces where you can manually enter the value. I
havent seen the issue on other hosts. Its very important that this
value is correct though as I my network interfaces are renamed based
on this in /etc/udev/rules.d/70-persistent-net.rules. It having an
empty value for the name stops my system from being network accessible
after a reboot. Thoughts?
we update interfaces based on incoming facts. If you don't run Foreman in
unattended mode or the host is unmanaged, you can't edit interfaces (fixed in
1.8). Does that host have 2 interfaces and are MAC addresses correct? If not,
could you upload output of facter for that host? To workaround wrong values
you can make the host managed, fix the values and make it unmanaged again.
Hope this helps
Marek
foreman_interfaces:
ip: 192.168.0.104
type: Interface
name:
attrs: {}
virtual: false
link: true
identifier:
managed: true
subnet:
mask: 255.255.255.0
dns_secondary: ''
to: ''
boot_mode: DHCP
ipam: DHCP
ip:
type: Interface
attrs: {}
virtual: false
link: true
identifier: em1
managed: false
subnet:
Yes, all of my hosts have multiple interfaces and they are all managed.
On Mon, Jun 29, 2015 at 5:32 AM, Marek Hulan wrote:
we update interfaces based on incoming facts. If you don’t run Foreman in
unattended mode or the host is unmanaged, you can’t edit interfaces (fixed
in
not,
Hope this helps
Marek
value
foreman_interfaces:
ip: 192.168.0.104
type: Interface
name:
attrs: {}
virtual: false
link: true
identifier:
managed: true
subnet:
mask: 255.255.255.0
dns_secondary: ''
to: ''
boot_mode: DHCP
ipam: DHCP
ip:
type: Interface
attrs: {}
virtual: false
link: true
identifier: em1
managed: false
subnet:
"Foreman users" group.
