I'm running Foreman 1.15.6 and Katello 3.4.
I did apply an Errata to a host what did generate a new Content View
version, so far s good. The new Content View includes the Errata but not
the package for the this Errata.
<https://lh3.googleusercontent.com/-_dsY8rCYKsE/Wir3CtwsTBI/AAAAAAAABFI/TPsuLdeMyZsYBGmsnMgy87zIzEJhA86sQCLcBGAs/s1600/ContentView.png>
As you may see on the picture in version 1.1 there is one more Errata but
the amount of packages didn't change.
When doing a yum check-update on host i don't see any new package.
After generating a full new version version of the content view i will get
those updates on the host.
This sounds like a bug....
Thanks for any hint to help debug that issue.
Best regards,
Arsène
I also saw this with these versions. If you look at the release notes for
Foreman 1.16 and Katello 3.5 there are a number of bugs related that will
hopefully fix this issue.
The upgrade is a relatively simple process - I'd recommend it.
Cheers
L.
Cheers
L.
On 9 December 2017 at 07:38, Arsène Gschwind <arsene.gschwind@gmail.com> wrote:Hi,
I've tried the update to TFM 1.16 and Katello 3.5 but I had to revert back since the provisioning didn't work at all.
get those updates on the host.
Cheers
L.
I may give another attempt....
Tanks.
Cheers,
Arsène
On Saturday, December 9, 2017 at 2:40:04 AM UTC+1, Lachlan Musicman wrote:On 9 December 2017 at 07:38, Arsène Gschwind <arsene....@gmail.com > <javascript:>> wrote:
You are encountering this
bug: https://bugzilla.redhat.com/show_bug.cgi?id=1488167 looks like this fix is in pulp-2.14
On 9 December 2017 at 07:38, Arsène Gschwind <arsene....@gmail.com> >> wrote:
but the amount of packages didn't change.
Cheers
L.
Tanks.
Cheers,
Arsène
Thanks for your help guys, I will find a solution to upgrade my
installation.
Best regards,
Arsène
Best regards,
Arsène
On Saturday, December 9, 2017 at 5:59:42 PM UTC+1, Andrew Schofield wrote:
You are encountering this bug:
is in pulp-2.14
On 9 December 2017 at 07:38, Arsène Gschwind <arsene....@gmail.com> >>> wrote:
for Foreman 1.16 and Katello 3.5 there are a number of bugs related that
will hopefully fix this issue.
Cheers
L.
Tanks.
Cheers,
Arsène
