I am trying to install Foreman/Katello using the Forklift Ansible scripts.
The installation ends with an error.
[ WARN 2020-12-02T03:25:08 verbose] /Package[tfm-rubygem-smart_proxy_pulp]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Settings_file[pulp3]/File[/etc/foreman-proxy/settings.d/pulp3.yml]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Module[pulp]/Foreman_proxy::Feature[Pulp]/Datacat_fragment[foreman_proxy::enabled_features::Pulp]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Module[pulp]/Foreman_proxy::Settings_file[pulp]/File[/etc/foreman-proxy/settings.d/pulp.yml]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Module[pulpnode]/Foreman_proxy::Settings_file[pulpnode]/File[/etc/foreman-proxy/settings.d/pulpnode.yml]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Module[pulpcore]/Foreman_proxy::Feature[Pulpcore]/Datacat_fragment[foreman_proxy::enabled_features::Pulpcore]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Plugin::Pulp/Foreman_proxy::Module[pulpcore]/Foreman_proxy::Settings_file[pulpcore]/File[/etc/foreman-proxy/settings.d/pulpcore.yml]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] Class[Foreman_proxy::Service]: Unscheduling all events on Class[Foreman_proxy::Service]
[ WARN 2020-12-02T03:25:08 verbose] /Service[foreman-proxy]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] /Service[foreman-proxy]: Unscheduling all events on Service[foreman-proxy]
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Register/Datacat_collector[foreman_proxy::enabled_features]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[cent-mgmt2.feric.ch]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] Class[Foreman_proxy]: Unscheduling all events on Class[Foreman_proxy]
[ WARN 2020-12-02T03:25:08 verbose] /Service[puppet]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] /Service[puppet]: Unscheduling all events on Service[puppet]
[ WARN 2020-12-02T03:25:08 verbose] /Service[puppet-run.timer]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] /Service[puppet-run.timer]: Unscheduling all events on Service[puppet-run.timer]
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Puppet::Agent::Service::Systemd/File[/etc/systemd/system/puppet-run.timer]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Puppet::Agent::Service::Systemd/File[/etc/systemd/system/puppet-run.service]: Skipping because of failed dependencies
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Puppet::Agent::Service::Systemd/Exec[systemctl-daemon-reload-puppet]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] /Stage[main]/Puppet::Agent::Service::Systemd/Exec[systemctl-daemon-reload-puppet]: Unscheduling all events on Exec[systemctl-daemon-reload-puppet]
[ WARN 2020-12-02T03:25:08 verbose] /Stage[main]/Puppet::Agent::Service::Cron/Cron[puppet]: Skipping because of failed dependencies
[ INFO 2020-12-02T03:25:08 verbose] Class[Puppet]: Unscheduling all events on Class[Puppet]
[ INFO 2020-12-02T03:25:08 verbose] Stage[main]: Unscheduling all events on Stage[main]
[ WARN 2020-12-02T03:25:08 verbose] Applied catalog in 339.32 seconds
[ INFO 2020-12-02T03:25:10 verbose] Puppet has finished, bye!
[ INFO 2020-12-02T03:25:10 verbose] Executing hooks in group post
[ INFO 2020-12-02T03:25:10 verbose] All hooks in group post finished
[ INFO 2020-12-02T03:25:10 verbose] Installer finished in 442.793562332 seconds
stdout_lines: <omitted>
When I look at the installation log file, I can see the following Traceback and ERROR:
[ INFO 2020-12-02T03:21:06 main] Pulpcore::Admin[collectstatic --noinput]: Scheduling refresh of Exec[pulpcore-manager collectstatic --noinput]
[DEBUG 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]: 'pulpcore-manager collectstatic --noinput' won't be executed because of failed check 'refreshonly'
[DEBUG 2020-12-02T03:21:06 main] Exec[pulpcore-manager collectstatic --noinput](provider=posix): Executing 'pulpcore-manager collectstatic --noinput'
[DEBUG 2020-12-02T03:21:06 main] Executing with uid=pulp: 'pulpcore-manager collectstatic --noinput'
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: Traceback (most recent call last):
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/bin/pulpcore-manager", line 11, in <module>
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: load_entry_point('pulpcore==3.6.3', 'console_scripts', 'pulpcore-manager')()
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/pulpcore/app/manage.py", line 11, in manage
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: execute_from_command_line(sys.argv)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 381, in execute_from_command_line
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: utility.execute()
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/core/management/__init__.py", line 325, in execute
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: settings.INSTALLED_APPS
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 79, in __getattr__
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: self._setup(name)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 66, in _setup
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: self._wrapped = Settings(settings_module)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/django/conf/__init__.py", line 157, in __init__
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: mod = importlib.import_module(self.SETTINGS_MODULE)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib64/python3.6/importlib/__init__.py", line 126, in import_module
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: return _bootstrap._gcd_import(name[level:], package, level)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap>", line 994, in _gcd_import
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap>", line 971, in _find_and_load
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap>", line 955, in _find_and_load_unlocked
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap>", line 665, in _load_unlocked
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap_external>", line 678, in exec_module
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/pulpcore/app/settings.py", line 240, in <module>
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: ENVVAR_FOR_DYNACONF="PULP_SETTINGS",
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/contrib/django_dynaconf_v2.py", line 76, in load
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: lazy_settings.populate_obj(django_settings_module)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/parse_conf.py", line 206, in evaluate
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: value = f(settings, *args, **kwargs)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 142, in __getattr__
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: self._setup()
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/base.py", line 184, in _setup
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: default_settings.reload(self._kwargs.get("load_dotenv"))
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 71, in reload
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: start_dotenv(*args, **kwargs)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/default_settings.py", line 57, in start_dotenv
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: or _find_file(".env", project_root=root_path)
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 60, in find_file
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: search_tree.extend(_walk_to_root(work_dir))
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: File "/usr/lib/python3.6/site-packages/dynaconf/utils/files.py", line 13, in _walk_to_root
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: raise IOError("Starting path not found")
[ WARN 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]/returns: OSError: Starting path not found
[ERROR 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]: Failed to call refresh: 'pulpcore-manager collectstatic --noinput' returned 1 instead of one of [0]
[ERROR 2020-12-02T03:21:06 main] /Stage[main]/Pulpcore::Static/Pulpcore::Admin[collectstatic --noinput]/Exec[pulpcore-manager collectstatic --noinput]: 'pulpcore-manager collectstatic --noinput' returned 1 instead of one of [0]
katello.log (2.9 MB)
It’s unclear to me what exactly is causing the problem.
Am I missing something?
Kind regards
Toni Feric
