Hello, when I use the following command to generate a VM:
hammer -v host create --hostgroup="Test"
–compute-resource="test_vmware_compute"
–compute-attributes="cpus=2,corespersocket=2,memory_mb=4056,cluster=1,guest_id=1"
–interface="primary=true,provision=true,compute_type=VirtualE1000,
compute_network=dvPG-Test"
–volume="datastore=isilon-vm2,size_gb=4,thin=true"
–name="hammertime02.example.com"
I get the following error:
Could not create the host:
Failed to create a compute test_vmware_compute (VMware) instance
hammertime02.example.com: failed to create vm: undefined method
`resourcePool' for nil:NilClass
Has anyone else had trouble using hammer to create vm's on a VMware compute
resource?
Here is a snippet from /var/log/foreman/production.log:
<SNIP>
> Started POST "/api/hosts" for 10.67.5.5 at 2016-01-06 11:54:27 -0500
2016-01-06 11:54:27 [app] [I] Processing by Api::V2::HostsController#create
as JSON
2016-01-06 11:54:27 [app] [I] Parameters:
{"host"=>{"name"=>"hammertime02.example.com", "compute_resource_id"=>1,
"hostgroup_id"=>3, "build"=>true, "enabled"=>true, "managed"=>true,
"compute_attributes"=>{"cpus"=>"2", "corespersocket"=>"2",
"memory_mb"=>"4056", "cluster"=>"1", "guest_id"=>"1",
"volumes_attributes"=>{"0"=>{"datastore"=>"isilon-vm2", "size_gb"=>"4",
"thin"=>"true"}}}, "host_parameters_attributes"=>{},
"interfaces_attributes"=>{"0"=>{"primary"=>"true", "provision"=>"true",
"compute_attributes"=>{"type"=>"VirtualE1000", "network"=>"dvPG-Test"}}}},
"apiv"=>"v2"}
2016-01-06 11:54:27 [app] [I] Authorized user admin(Admin User)
2016-01-06 11:54:31 [app] [W] Failed to create a compute
test_vmware_compute (VMware) instance hammertime02.test.dte.cert.org:
failed to create vm: undefined method resourcePool' for nil:NilClass > > NoMethodError: failed to create vm: undefined methodresourcePool' for
nil:NilClass
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-1.34.0/lib/fog/vsphere/requests/compute/create_vm.rb:31:in
rescue in create_vm' > /opt/theforeman/tfm/root/usr/share/gems/gems/fog-1.34.0/lib/fog/vsphere/requests/compute/create_vm.rb:8:increate_vm'
/opt/theforeman/tfm/root/usr/share/gems/gems/fog-1.34.0/lib/fog/vsphere/models/compute/server.rb:235:in
save' > /usr/share/foreman/app/models/compute_resources/foreman/model/vmware.rb:326:increate_vm'
> /usr/share/foreman/app/models/concerns/orchestration/compute.rb:76:in
`setCompute'
<SNIP>
Bump… Does anyone have a solution for this? Or are there known issues with redmine tickets?
Thanks!
----- Original Message -----
> --compute-resource="test_vmware_compute"
> --compute-attributes="cpus=2,corespersocket=2,memory_mb=4056,cluster=1,guest_id=1"
> --interface="primary=true,provision=true,compute_type=VirtualE1000,
> --volume="datastore=isilon-vm2,size_gb=4,thin=true"
> --name="hammertime02.example.com"
> resource?
> as JSON
> "apiv"=>"v2"}
> failed to create vm: undefined method `resourcePool' for nil:NilClass
> > NoMethodError: failed to create vm: undefined method `resourcePool' for
> nil:NilClass
> `rescue in create_vm'
> `create_vm'
> `save'
> `create_vm'
> `setCompute'
> "Foreman users" group.
> email to foreman-users+unsubscribe@googlegroups.com.
I have the same issue. Did you find a fix?
