I am trying to provision an instance on EC2. Facing a problem there.
I am expecting the instance to have puppet agent installed on it.
Foreman starts to create the instance but fails while executing post
install scripts.
I can see the following in production.log
Prepare post installation script for ec2puppet3.proserv.com task failed
with the following error: undefined method grub_pass' for #<Host::Managed:0x000000092311e0>/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/attribute_methods.rb:407:in
method_missing'
/opt/rh/ruby193/root/usr/share/gems/gems/activerecord-3.2.8/lib/active_record/attribute_methods.rb:149:in
method_missing' /opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode/scope.rb:37:in
method_missing'
/opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode.rb:102:in
`bind'
I am using the latest version of Foreman. The installation itself completed
without any errors.
Please let me know if any more information is required.
Regards,
Abhijeet
I could go around this. Looks like I was not providing the correct
provisioning templates.
Now I am getting another error in the production.log.
Started GET "/tasks/85fafb4e-5ebb-4325-9cd0-f849d7426938" for
123.201.119.171 at 2014-04-07 08:48:09 -0400
Processing by TasksController#show as /
Parameters: {"id"=>"85fafb4e-5ebb-4325-9cd0-f849d7426938"}
Rendered tasks/_list.html.erb (0.8ms)
Completed 200 OK in 4ms (Views: 1.6ms | ActiveRecord: 0.3ms)
About to start post launch script on ec2743.proserv.com
generating template to upload to ec2743.proserv.com
Prepare post installation script for ec2743.proserv.com task failed with
the following error: undefined method 'root_pass' for Host::Managed::Jail
(Host::Managed)/opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode/jail.rb:17:in
method_missing' /opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode.rb:53:in
bind'
/opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode.rb:51:in
eval' /opt/rh/ruby193/root/usr/share/gems/gems/safemode-1.2.0/lib/safemode.rb:51:in
eval'
/usr/share/foreman/lib/foreman/renderer.rb:9:in `render_safe'
Looks like the root_password is not being set properly.
Can somebody please tell what is missing?
I have set the following templates -
finish - Jumpstart default finish
PXELinux - Kickstart default PXELinux
PXEGrub - PXEGrub default local boot
provision - Kickstart
You need a finish-style template associated to the OS. You could
probably copy the %post section from the "Kickstart default" template if
you're provisioning an EL-type OS, or use the "Preseed default finish"
template if you're provisioning a Debian-type OS.
I don't think associating the "Jumpstart default finish" will work
unless you're actually provisioning Solaris.
Dominic Cleal
Red Hat Engineering
Started GET “/tasks/85fafb4e-5ebb-4325-9cd0-f849d7426938” for
Parameters: {“id”=>“85fafb4e-5ebb-4325-9cd0-f849d7426938”}
the following error: undefined method ‘root_pass’ for
Host::Managed::Jail
bind’
eval’
/usr/share/foreman/lib/foreman/renderer.rb:9:in `render_safe’
Groups “Foreman users” group.
an email to foreman-users+unsubscribe@googlegroups.com
Thanks Dominic. That worked.
I created a new finish template and copied the %post part of the Kikcstart
RHEL default template to the new template. That seems to have resolved the
root password related error.
But now I am getting another error.
Started GET "/tasks/ebb46c98-cd63-44c4-95be-9ff9b24b2d5c" for
123.201.119.153 at 2014-04-08 03:43:51 -0400
Parameters: {"id"=>"ebb46c98-cd63-44c4-95be-9ff9b24b2d5c"}
Rendered tasks/_list.html.erb (0.5ms)
Completed 200 OK in 3ms (Views: 1.0ms | ActiveRecord: 0.2ms)
About to start post launch script on ec28414.proserv.com
generating template to upload to ec28414.proserv.com
Prepare post installation script for ec28414.proserv.com task failed with
the following error: undefined local variable or method puppet_enabled' for #<Host::Managed:0x00000007ebba48>/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/attribute_methods.rb:407:in
method_missing'
method_missing' (erb):26:in
render_safe'
/opt/rh/ruby193/root/usr/share/ruby/erb.rb:838:in eval' /opt/rh/ruby193/root/usr/share/ruby/erb.rb:838:in
result'
/usr/share/foreman/lib/foreman/renderer.rb:12:in render_safe' /usr/share/foreman/lib/foreman/renderer.rb:78:in
unattended_render'
/usr/share/foreman/lib/foreman/renderer.rb:85:in `block in
unattended_render_to_temp_file'
Looks like puppet_enabled variable is not defined. Where should I define
that variable.
To work around this, i commented the references of this variable from the
templates that I have selected. But still I am getting this error.
Thanks and regards-
Abhijeet
> Dominic Cleal
> Red Hat Engineering
> > Processing by TasksController#show as */*
> with
> > Host::Managed::Jail
> > `method_missing'
> > `bind'
> > `eval'
> > `eval'
> > You received this message because you are subscribed to the Google
> > Groups "Foreman users" group.
> > an email to foreman-user...@googlegroups.com
> > <mailto:foreman-users+unsubscribe@googlegroups.com >.
> > To post to this group, send email to forema...@googlegroups.com
> > <mailto:forema...@googlegroups.com >.
> > Visit this group at http://groups.google.com/group/foreman-users.
> > For more options, visit https://groups.google.com/d/optout.
You'll also need some of the variable declarations from the top of the
kickstart file:
https://github.com/theforeman/community-templates/blob/master/kickstart/provision.erb#L14-L22
I've just written a complete finish script and submitted it to the
templates repo, it might save you a few steps:
https://github.com/theforeman/community-templates/pull/69/files
Hopefully we can get this in 1.5.
Dominic Cleal
Red Hat Engineering
Kikcstart RHEL default template to the new template. That seems to have
resolved the root password related error.
Started GET “/tasks/ebb46c98-cd63-44c4-95be-9ff9b24b2d5c” for
Parameters: {“id”=>“ebb46c98-cd63-44c4-95be-9ff9b24b2d5c”}
with the following error: undefined local variable or method
method_missing’
render_safe’
result’
unattended_render’
unattended_render_to_temp_file’
that variable.
the templates that I have selected. But still I am getting this error.
Thanks and regards-
Abhijeet
template if
Dominic Cleal
Red Hat Engineering
<http://ec2743.proserv.com>
<http://ec2743.proserv.com> task failed with
> Host::Managed::Jail
> `method_missing'
> `bind'
> `eval'
> `eval'
send
> an email to foreman-user...@googlegroups.com <javascript:>
> <mailto:foreman-users+unsubscribe@googlegroups.com <javascript:>>.
<javascript:>
> <mailto:forema...@googlegroups.com <javascript:>>.
<http://groups.google.com/group/foreman-users>.
<https://groups.google.com/d/optout>.
I took both of these.
Getting a new error now.
Started GET "/tasks/dcf0df04-4c0b-4c7e-b8b7-f8b8c97df9e6" for
123.201.119.195 at 2014-04-08 07:16:52 -0400
Parameters: {"id"=>"dcf0df04-4c0b-4c7e-b8b7-f8b8c97df9e6"}
Rendered tasks/_list.html.erb (0.9ms)
Completed 200 OK in 5ms (Views: 1.7ms | ActiveRecord: 0.4ms)
About to start post launch script on ec28421.proserv.com
generating template to upload to ec28421.proserv.com
Prepare post installation script for ec28421.proserv.com task failed with
the following error: undefined method otp' for #<Host::Managed:0x000000090bc350>/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/attribute_methods.rb:407:in
method_missing'
method_missing' (erb):29:in
render_safe'
result'
unattended_render'
There were references to @host.otp in both these templates. Commented them
out in the templates, yet getting these errors.
I checked the page for template writing. Didnt find any reference to
host.otp there. Is this new in foreman?
How should I resolve this error.
Sorry for the dumb questions, but I am really new to forman.
-Abhijeet
> kickstart file:
> Dominic Cleal
> Red Hat Engineering
> > `puppet_enabled' for
> #/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/attribute_methods.rb:407:in
> > `method_missing'
> > `method_missing'
> > (erb):26:in `render_safe'
> > /opt/rh/ruby193/root/usr/share/ruby/erb.rb:838:in `eval'
> > /opt/rh/ruby193/root/usr/share/ruby/erb.rb:838:in `result'
> > /usr/share/foreman/lib/foreman/renderer.rb:12:in `render_safe'
> > /usr/share/foreman/lib/foreman/renderer.rb:78:in `unattended_render'
> > that variable.
> > Thanks and regards-
> > Abhijeet
> > template if
> finish"
> > Dominic Cleal
> > Red Hat Engineering
> > task failed with
> > > Host::Managed::Jail
> > > `method_missing'
> > > `bind'
> > > `eval'
> > > `eval'
> > send
Sorry, yes, this is a Foreman 1.5 feature. If you comment out all the
realm or OTP related lines you should be fine.
Dominic Cleal
Red Hat Engineering
Started GET “/tasks/dcf0df04-4c0b-4c7e-b8b7-f8b8c97df9e6” for
Parameters: {“id”=>“dcf0df04-4c0b-4c7e-b8b7-f8b8c97df9e6”}
with the following error: undefined method otp' for #<Host::Managed:0x000000090bc350>/opt/rh/ruby193/root/usr/share/gems/gems/activemodel-3.2.8/lib/active_model/attribute_methods.rb:407:in
method_missing’
render_safe’
result’
unattended_render’
them out in the templates, yet getting these errors.
-Abhijeet
kickstart file:
<https://github.com/theforeman/community-templates/blob/master/kickstart/provision.erb#L14-L22>
<https://github.com/theforeman/community-templates/pull/69/files>
Dominic Cleal
Red Hat Engineering
have
<http://ec28414.proserv.com>
<http://ec28414.proserv.com> task failed
> `method_missing'
> `method_missing'
define
> that variable.
error.
> Thanks and regards-
> Abhijeet
> template if
finish"
work
> Dominic Cleal
> Red Hat Engineering
correct
> > Host::Managed::Jail
> > `method_missing'
> > `bind'
> > `eval'
> > `eval'
Google
from it,
> send
<javascript:> <javascript:>>.
> <javascript:>
> > Visit this group at
<http://groups.google.com/group/foreman-users>>.
<https://groups.google.com/d/optout>>.
send
<javascript:>
Hello Dominic,
Thanks a lot for the help. This is working perfectly now.
Best regards,
Abhijeet
