Problem: I had foreman 3.5 running as expected and performed upgrade to version 3.6.
Everything went well but at the very last step I see some errors. As a result, smart proxy that is running on the same system as foreman did not get updated
2023-11-07 11:06:43 [ERROR ] [configure] Host it-foreman.NNNN.edu does not exist in Foreman at https://it-foreman.NNNN.edu/
2023-11-07 11:06:43 [ERROR ] [configure] /Stage[main]/Foreman::Register/Foreman_instance_host[foreman-it-foreman.NNNN.edu]/ensure: change from 'absent' to 'present' failed: Host it-foreman.NNNN.edu does not exist in Foreman at https://it-foreman.NNNN.edu/
2023-11-07 11:06:45 [ERROR ] [configure] Error making POST request to Foreman at https://it-foreman.NNNN.edu/api/v2/smart_proxies: URL Only one declaration of a proxy is allowed
2023-11-07 11:06:45 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[it-foreman.NNNN.edu]/ensure: change from 'absent' to 'present' failed: Error making POST request to Foreman at https://it-foreman.NNNN.edu/api/v2/smart_proxies: URL Only one declaration of a proxy is allowed
2023-11-07 11:06:50 [NOTICE] [configure] System configuration has finished.
Smart proxy was configured successfuly during initial installation.
I tried to change the name of the foreman to FQDN, smae for proxy, made no difference in any combination of short name or FQDN. Expected outcome:
Expected smart proxy to be upgraded to the same version 3.6 Foreman and Proxy versions:
Now Foreman is 3.6 but proxy is still 3.5 Foreman and Proxy plugin versions:
Runs on Rocky 8.8 fully updated Other relevant data:
I have it-foreman listed in hosts in Foreman web interface.
I am back to original short names both for the system listed in Foreman and smart proxy. Ran foreman-installer again. Exactly the same error as in my original post. Nothing added /var/log/foreman-proxy/proxy.log. No errors there.
I did not change any names during the run. Made changes, started new installer run.
I see some strange entries in /var/log/foreman-installer/katello.log:
2023-11-07 14:07:49 [ERROR ] [configure] Host it-foreman.NNNN.edu does not exist in Foreman at https://it-foreman.cshl.edu/
2023-11-07 14:07:49 [ERROR ] [configure] /Stage[main]/Foreman::Register/Foreman_instance_host[foreman-it-foreman.NNNN.edu]/ensure: change from 'absent' to 'present' failed: Host it-for
And then, some ~100 lines later another error:
2023-11-07 14:07:52 [ERROR ] [configure] Error making POST request to Foreman at https://it-foreman.NNNN.edu/api/v2/smart_proxies: URL Only one declaration of a proxy is allowed
2023-11-07 14:07:52 [ERROR ] [configure] /Stage[main]/Foreman_proxy::Register/Foreman_smartproxy[it-foreman.NNNN.edu]/ensure: change from 'absent' to 'present' failed: Error making POS
T request to Foreman at https://it-foreman.NNNN.edu/api/v2/smart_proxies: URL Only one declaration of a proxy is allowed`
Now that you are back to shortnames, if you are able to load up the UI or we can do it with hammer host list do you see this host it-foreman.NNNN.edu does not exist in Foreman listed?
The web interface is up. I can see host it-foreman listed but not it-foreman.NNNN.edu
That is why I was try ing to play with short name - FQDN. All my nodes are listed as short names. I have no idea why foreman thinks of itself with the long name. That could be the root of my problem.
Hammer command shows it with global status Error though:
That should set the value as an alias for whatever is passed to --foreman-proxy-registered-name, which is the parameter that fixes the latter. You should be able to use foreman-installer --foreman-proxy-registered-name it-foreman now.
Thank you for looking into this!
I added suggested line to /etc/foreman-installer/custom-hiera.yaml file.
Now any attempt to run foreman-installer generates an error:
2023-11-08 09:45:25 [ERROR ] [root] Error: Evaluation Error: Error while evaluating a Function Call, Lookup of key 'lookup_options' failed: Unable to parse (/etc/foreman-installer/custom-hiera.yaml): did not find expected key while parsing a block mapping at line 24 column 1 (line: 108, column: 41) on node it-foreman.cshl.edu
This is happening even if I run foreman-installer --help
[root@it-foreman foreman-installer]# cat custom-hiera.yaml
# This YAML file lets you set your own custom configuration in Hiera for the
# installer puppet modules that might not be exposed to users directly through
# installer arguments.
# For example, to set 'TraceEnable Off' in Apache, a common requirement for
# security auditors, add this to this file:
# apache::trace_enable: Off
# Consult the full module documentation on http://forge.puppetlabs.com,
# or the actual puppet classes themselves, to discover options to configure.
# Do note, setting some values may have unintended consequences that affect the
# performance or functionality of the application. Consider the impact of your
# changes before applying them, and test them in a non-production environment
# first.
# Here are some examples of how you tune the PostgreSQL options if needed:
# postgresql::server::config_entries:
# max_connections: 600
# shared_buffers: 1024MB
foreman::register::foreman_host_name: '%{alias('foreman_proxy::registered_name')}'
