[this message from earlier today, was eaten by google groups]
While I do understand that there are local problems I have to fix, the
reporting of those errors in the foreman has potential to improvement to
help admins understand their situation:
This is the actual problem:
[root@puppet ~]# ipmitool -H 10.0.0.1 -U admin -P s3cr3t power status
Error: Unable to establish LAN session
Unable to get Chassis Power Status
[root@puppet ~]# ping -c 3 10.0.0.1
PING 10.0.0.1 (10.0.0.1) 56(84) bytes of data.
--- 10.0.0.1 ping statistics ---
3 packets transmitted, 0 received, 100% packet loss, time 12001ms
This is what the smart proxy's API says:
[root@puppet ~]# wget --auth-no-challenge --header "Accept:
application/json" --ca-certificate=/var/lib/puppet/ssl/certs/ca.pem
–private-key=/var/lib/puppet/ssl/private_keys/puppet.example.com.pem
–certificate=/var/lib/puppet/ssl/certs/puppet.example.com.pem -O - -S
https://puppet.example.com:8443/bmc/10.0.0.1/chassis/power/status -nv
–user=admin --password=s3cr3t
HTTP/1.1 200 OK
Content-Length: 33
Server: WEBrick/1.3.1 (Ruby/1.8.7/2011-06-30) OpenSSL/1.0.1e
Content-Type: text/html
Connection: Keep-Alive
{"action":"status","result":null}2015-02-11 14:55:21
URL:https://puppet.example.com:8443/bmc/10.0.0.1/chassis/power/status
[33/33] -> "-" [1]
[root@puppet ~]#
This is what the BMC tab on the foreman's host page for the host in
question says:
Failure: undefined method `downcase' for nil:NilClass
This is happening on foreman{,-proxy}-1.6.2-1.el6 from the 1.6 repo
running on Scientific Linux release 6.5 (Carbon).
Regards, David
Date: Wed, 11 Feb 2015 13:55:21 GMT
This looks like Bug #2749: Failed to fetch bmc information: undefined method `downcase' for nil:NilClass - Foreman &
Bug #7543: allow additional rubyipmi connection options to be passed through - Smart Proxy - Foreman.
> Hi,
> This is the *actual* problem:
> --private-key=/var/lib/puppet/ssl/private_keys/puppet.example.com.pem
> --certificate=/var/lib/puppet/ssl/certs/puppet.example.com.pem -O - -S
> --user=admin --password=s3cr3t
> HTTP/1.1 200 OK
> Content-Length: 33
> [33/33] -> "-" [1]
> [root@puppet ~]#
> question says:
Dominic Cleal
Red Hat Engineering
Could you try to apply Fixes #2749 - power status helper can handle unknown states by ares · Pull Request #2154 · theforeman/foreman · GitHub
Marek
This is what the smart proxy’s API says:
[root@puppet ~]# wget --auth-no-challenge --header “Accept:
application/json” --ca-certificate=/var/lib/puppet/ssl/certs/ca.pem
HTTP/1.1 200 OK
Content-Length: 33
[33/33] → “-” [1]
[root@puppet ~]#
This is what the BMC tab on the foreman’s host page for the host in
question says:
Failure: undefined method `downcase’ for nil:NilClass
Marek
