We are failing to cancel builds for AIX hosts (power Architecture).
According to the error, the failure comes from and issue rendering the PXE template and using nim_attributes:
Failed to cancel pending build for [HOSTNAME] with the following errors: Unable to render ‘PXELinux default local boot’ template: undefined method
nim_attributes' for #<Foreman::Renderer::Scope::Provisioning:0x00007f13266f20d0> Did you mean? aif_attributes waik_attributes, Unable to render 'PXEGrub2 default local boot' template: undefined methodnim_attributes’ for #Foreman::Renderer::Scope::Provisioning:0x00007f13257ec630 Did you mean? aif_attributes waik_attributes, Unable to render ‘PXEGrub default local boot’ template: undefined methodnim_attributes' for #<Foreman::Renderer::Scope::Provisioning:0x00007f1325d1a378> Did you mean? aif_attributes waik_attributes, Unable to render 'iPXE default local boot' template: undefined methodnim_attributes’ for #Foreman::Renderer::Scope::Provisioning:0x00007f1326250248 Did you mean? aif_attributes waik_attributes
we tried to create a dummy provision template for this hostgroup, but we realized that we are missing something, even when the template is empty, when we switch to preview and switch to and AIX host, we get the same rendering error with not being able to find nim_attributes.
Rendering through linux box works well (we get preview of empty pxe template)
There was an error rendering the aix_MSE_PXElinux template: undefined method `nim_attributes’ for #Foreman::Renderer::Scope::Provisioning:0x00007f130bc17828 Did you mean? aif_attributes waik_attributes
Added photos of both previews (for aix box and linux box) and the code for the template.
We also tried to to hit the URL with available token and use to api to set build=false, both are not providing any error but host is still pending installation
We are expecting to be able to cancel pending aix hosts build
| foreman-tasks | The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks. | Ivan Nečas | 3.0.2 |
| foreman_bootdisk | Plugin for Foreman that creates iPXE-based boot disks to provision hosts without the need for PXE infrastructure. | Dominic Cleal | 17.0.2 |
| foreman_discovery | MaaS Discovery Plugin engine for Foreman | Aditi Puntambekar, alongoldboim, Alon Goldboim, amirfefer, Amit Karsale, Amit Upadhye, Amos Benari, Avi Sharvit, Bryan Kearney, bshuster, Daniel Lobato, Daniel Lobato Garcia, Daniel Lobato García, Danny Smit, David Davis, Djebran Lezzoum, Dominic Cleal, Eric D. Helms, Ewoud Kohl van Wijngaarden, Frank Wall, Greg Sutcliffe, ChairmanTubeAmp, Ido Kanner, imriz, Imri Zvik, Ivan Nečas, Joseph Mitchell Magen, June Zhang, kgaikwad, Lars Berntzon, ldjebran, Leos Stejskal, Lukas Zapletal, Lukáš Zapletal, Marek Hulan, Marek Hulán, Martin Bačovský, Matt Jarvis, Michael Moll, Nick, odovzhenko, Ohad Levy, Ondrej Prazak, Ondřej Ezr, Ori Rabin, orrabin, Partha Aji, Petr Chalupa, Phirince Philip, Rahul Bajaj, Robert Antoni Buj Gelonch, Ron Lavi, Scubafloyd, Sean O'Keeffe, Sebastian Gräßl, Shimon Shtein, Shlomi Zadok, Stephen Benjamin, Swapnil Abnave, Thomas Gelf, Timo Goebel, Tomas Strych, Tom Caspy, Tomer Brisker, and Yann Cézard | 16.3.4 |
| foreman_hooks | Plugin engine for Foreman that enables running custom hook scripts on Foreman events | Dominic Cleal | 0.3.17 |
| foreman_host_extra_validator | This plugin adds extra validations to a host. | Timo Goebel | 0.1.0 |
| foreman_memcache | Adds memcache support to foreman | Ohad Levy | 0.1.1 |
| foreman_setup | Plugin for Foreman that helps set up provisioning. | Dominic Cleal | 7.0.0 |
| foreman_templates | Engine to synchronise provisioning templates from GitHub | Greg Sutcliffe | 9.0.1 |
