[ERROR 2018-02-02T15:20:21 main] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Failed to call refresh: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
[ERROR 2018-02-02T15:20:21 main] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
Executinge the file manually gets me
root@foreman:/var/lib# /usr/sbin/foreman-rake db:migrate
API controllers newer than Apipie cache! Run apipie:cache rake task to regenerate cache.
The PGconn, PGresult, and PGError constants are deprecated, and will be
removed as of version 1.0.
You should use PG::Connection, PG::Result, and PG::Error instead, respectively.
Called from /usr/share/foreman/vendor/ruby/2.3.0/gems/activesupport-4.2.9/lib/active_support/dependencies.rb:240:in `load_dependency'
rake aborted!
Sequel::DatabaseError: PG::DuplicateColumn: ERROR: column "version" of relation "dynflow_schema_info" already exists
I already have purged/deleted the postgresql executables and db files but the error still comes around? Any idea why?
Package: foreman
Version: 1.16.0-1
Architecture: amd64
Thanks!
Tobias Köck
