When I tried to delete one test VM I had created earlier with foreman, it gives the error "Failed to delete test-vm-5.kt21c.net ":
That is a VM on a libvirt hypervisor, installations done with PXE and kickstart.
As far as I can tell, that this VM was created before I installed the remote-execution feature (yesterday, June 4th):
foreman-installer --enable-foreman-plugin-remote-execution --enable-foreman-proxy-plugin-remote-execution-ssh
[root@fuji3 qemu]# ll /etc/libvirt/qemu/test-vm-5.kt21c.net.xml
-rw------- 1 root root 2734 Jun 3 23:19 /etc/libvirt/qemu/test-vm-5.kt21c.net.xml
[root@fuji3 qemu]# date
Fri Jun 5 20:27:39 EEST 2020
[root@fuji3 qemu]#
I mention this, because I suspect this might have something to do with it, because the log reports soemthing related to ssh keys failing:
2020-06-05T20:10:23 aa7e5f15 warning app ERF12-6886 [ProxyAPI::ProxyException]: Unable to remove host from known hosts ([TypeError]: no implicit conversion of nil into String) for proxy https://katello.kt
21c.net:9090/ssh
2020-06-05T20:10:23 aa7e5f15 warning app Rolling back due to a problem: [#<Orchestration::Task:0x00007fcfc08c0428 @name="Remove SSH known hosts for test-vm-5.kt21c.net", @id="ssh_remove_known_hosts_interface__1", @status="failed", @priority=200, @action=[#<Nic::Managed id: 12, mac: "52:54:00:ca:9e:bd", ip: nil, type: "Nic::Managed", name: "test-vm-5.kt21c.net", host_id: 12, subnet_id: 1, domain_id: 1, attrs: {}, created_at: "2020-06-03 20:18:50", updated_at: "2020-06-03 20:18:50", provider: nil, username: nil, password: nil, virtual: false, link: true, identifier: "", tag: "", attached_to: "", managed: true, mode: "balance-rr", attached_devices: "", bond_options: "", primary: true, provision: true, compute_attributes: {"type"=>"bridge", "bridge"=>"br-kt21c", "model"=>"virtio"}, ip6: "", subnet6_id: nil, execution: true>, :drop_from_known_hosts, [1, nil]], @created=1591377023.478005, @timestamp=2020-06-05 17:10:23 UTC>]
VM should be deleted in libvirt hypervisor and foreman.
Both katello VM and the hypervisor (fuji3) are:
[root@fuji3 vms]# cat /etc/redhat-release
CentOS Linux release 7.8.2003 (Core)
[root@fuji3 vms]#
production.log contains this:
2020-06-05T20:10:23 aa7e5f15 info app Started DELETE "/hosts/test-vm-5.kt21c.net" for 192.168.1.148 at 2020-06-05 20:10:23 +0300
2020-06-05T20:10:23 aa7e5f15 info app Processing by HostsController#destroy as HTML
2020-06-05T20:10:23 aa7e5f15 info app Parameters: {"authenticity_token"=>"Ahg7iib63olZtInZZSvNZTYZlj9tk2HAi/RKaEhviXXUsWA62wYEUd/R6lbevjQdwhjNaFUrVWa61yFIwEulHg==", "id"=>"test-vm-5.kt21c.net"}
2020-06-05T20:10:23 aa7e5f15 info app Delete the TFTP configuration for test-vm-5.kt21c.net
21c.net:9090/ssh
2020-06-05T20:10:23 aa7e5f15 info app Deploying TFTP iPXE configuration for test-vm-5.kt21c.net
2020-06-05T20:10:23 aa7e5f15 info app Deploying TFTP PXEGrub configuration for test-vm-5.kt21c.net
2020-06-05T20:10:24 aa7e5f15 info app Deploying TFTP PXEGrub2 configuration for test-vm-5.kt21c.net
2020-06-05T20:10:24 aa7e5f15 info app Deploying TFTP PXELinux configuration for test-vm-5.kt21c.net
2020-06-05T20:10:24 aa7e5f15 info app Processed 5 tasks from queue 'Host::Managed Main', completed 0/5
2020-06-05T20:10:24 aa7e5f15 err app Task 'Delete TFTP PXELinux config for test-vm-5.kt21c.net' *rollbacked*
2020-06-05T20:10:24 aa7e5f15 err app Task 'Delete TFTP PXEGrub2 config for test-vm-5.kt21c.net' *rollbacked*
2020-06-05T20:10:24 aa7e5f15 err app Task 'Delete TFTP PXEGrub config for test-vm-5.kt21c.net' *rollbacked*
2020-06-05T20:10:24 aa7e5f15 err app Task 'Delete TFTP iPXE config for test-vm-5.kt21c.net' *rollbacked*
2020-06-05T20:10:24 aa7e5f15 err app Task 'Remove SSH known hosts for test-vm-5.kt21c.net' *failed*
2020-06-05T20:10:24 aa7e5f15 err app Failed to save:
2020-06-05T20:10:24 aa7e5f15 info app Redirected to https://katello.kt21c.net/hosts/test-vm-5.kt21c.net
2020-06-05T20:10:24 aa7e5f15 info app Completed 302 Found in 951ms (ActiveRecord: 133.6ms)
2020-06-05T20:10:24 709cefc7 info app Started GET "/hosts/test-vm-5.kt21c.net" for 192.168.1.148 at 2020-06-05 20:10:24 +0300
2020-06-05T20:10:24 709cefc7 info app Processing by HostsController#show as HTML
2020-06-05T20:10:24 709cefc7 info app Parameters: {"id"=>"test-vm-5.kt21c.net"}
2020-06-05T20:10:24 709cefc7 info app Rendering hosts/show.html.erb within layouts/application
2020-06-05T20:10:24 709cefc7 info app Rendered hosts/show.html.erb within layouts/application (23.3ms)
2020-06-05T20:10:24 709cefc7 info app Rendered layouts/_application_content.html.erb (0.5ms)
2020-06-05T20:10:24 709cefc7 info app Rendering layouts/base.html.erb
2020-06-05T20:10:24 709cefc7 info app Rendered layouts/base.html.erb (26.4ms)
2020-06-05T20:10:24 709cefc7 info app Completed 200 OK in 71ms (Views: 47.4ms | ActiveRecord: 7.9ms)
