I am trying to provision an image with “User Data” selected (i.e. using cloud-init). However when I try to build the VM an error is returned:
“Failed to create a compute uatba801 (Libvirt) instance lucy-brumlow.equiduct.eu: Error saving the server: Call to virDomainDefineXML failed: unsupported configuration: IDE controllers are unsupported for this QEMU binary or machine type”
I assume this is foreman trying to create a CDROM device for the “lucy-brumlow.example.com-cloud-init.iso” that has been created by foreman which holds the “user-data” file. But the QEMU machine type pc-q35 does not support IDE. Shouldn’t foreman request libvirt to create a SATA/SCSI device rather than a IDE device?
Provisioning of libvirt resource completes without error.
Foreman 3.10
Katello 4.12.0
AlmaLinux 8.9
Compute resources are running RHEL 8.7 and 9.4. Both have the same error message.
