I configured Proxmox 8 as compute resource. When I go to create a new host after I select deploy on and click the virtual machine tab I get this error
Failure: SSL_read: unexpected eof while reading (OpenSSL::SSL::SSLError)
I am running Foreman 3.13.0
I have the following plugins installed
| foreman-tasks | The goal of this plugin is to unify the way of showing task statuses across the Foreman instance. It defines Task model for keeping the information about the tasks and Lock for assigning the tasks to resources. The locking allows dealing with preventing multiple colliding tasks to be run on the same resource. It also optionally provides Dynflow infrastructure for using it for managing the tasks. | Ivan Nečas | 10.0.1 |
| foreman_ansible | Ansible integration with Foreman | Daniel Lobato Garcia | 15.0.1 |
| foreman_fog_proxmox | Foreman plugin adds Proxmox VE compute resource using fog-proxmox. It is compatible with Foreman 1.22+ | Tristan Robert and The Foreman Team | 0.17.1 |
| foreman_remote_execution | A plugin bringing remote execution to the Foreman, completing the config management functionality with remote management functionality. | Foreman Remote Execution team | 14.0.2 |
| foreman_templates | Engine to synchronise provisioning templates from GitHub | Greg Sutcliffe | 10.0.1 |
| foreman_webhooks | Plugin for Foreman that allows to configure Webhooks. | Timo Goebel | 4.0.0 |
| katello | Katello adds Content and Subscription Management to Foreman. For this it relies on Candlepin and Pulp. | N/A | 4.15.0 |
| Not sure how to fix this. Foreman is using signed carts created on IDM I also have signed cert for both of proxmox 8 servers. Originally the proxmox servers had self signed carets. |
Any suggestions for how to fix this?
