When I set in the foreman settings
"Update IP from built request" = true it doesn't work
But with false it works, but every Host get added with IPAddress Name
instead of given hostname. So I got double entries in the List.
Also the added hosts with IPAddress Names are not manged or associated.
After time just the IPAddressed ones get updated for "Last report"
Informations
I think you explained it, when update_ip_from_built is set, then Foreman
makes attempt to change the provisioning IP address to the one that was
reported from. If you are not using NAT, this will work as expected, unless
there is an IP address in Foreman database already defined for any
interface. Than, that's a conflict. Use search interface to find such an IP.
On Wed, Nov 23, 2016 at 1:32 PM, Tom K. wrote:
Further more, if I run
puppet agent --test
on one of that doubled machines, it pushes the report to the IPAddress
named ones.
Ok, I think I understand.
But what do you mean with " Use search interface to find such an IP."
– Tom
Am Mittwoch, 23. November 2016 14:17:19 UTC+1 schrieb Lukas Zapletal:
> Hello,
> there is an IP address in Foreman database already defined for *any*
>> puppet agent --test
>> named ones.
>> "Foreman users" group.
>> Visit this group at https://groups.google.com/group/foreman-users.
> Later,
> Lukas @lzap Zapletal
