I've got a fairly new and clean install of foreman 1.14.3 and was trying to
install Katello 3.3 but after running "yum -y install katello" I ran
"foreman-installer --scenario katello --help" and I get the following error.
[root@foreman-dev foreman]# foreman-installer --scenario katello --help
/usr/share/gems/gems/kafo-1.0.5/lib/kafo/data_type.rb:29:in register_type': Data type Foreman_proxy::ListenOn is already registered, cannot be re-registered (ArgumentError) from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/data_type_parser.rb:22:in
block in
register'
from
/usr/share/gems/gems/kafo-1.0.5/lib/kafo/data_type_parser.rb:20:in each' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/data_type_parser.rb:20 :in
register'
from
/usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:314:in block (2 levels) in register_data_types' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:313:in
each'
in block in register_data_types' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:312:in
each'
from
register_data_types' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:91:in
modules'
from
/usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:193:in params' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/configuration.rb:203:in
preset_defaults_from_puppet'
from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/scenario_manager.rb:
208:in load_and_setup_configuration' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/kafo_configure.rb:274:in
set_parameters'
from
/usr/share/gems/gems/kafo-1.0.5/lib/kafo/kafo_configure.rb:99:in
initialize' from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in
new'
from /usr/share/gems/gems/clamp-1.0.0/lib/clamp/command.rb:133:in run' from /usr/share/gems/gems/kafo-1.0.5/lib/kafo/kafo_configure.rb:154:in
run'
from /sbin/foreman-installer:8:in `<main>'
I also ran the command w/o help and got:
[ INFO 2017-05-09 17:16:04 verbose] Executing hooks in group pre_migrations
[ INFO 2017-05-09 17:16:04 verbose] All hooks in group pre_migrations
finished
[ERROR 2017-05-09 17:16:04 verbose] You are trying to replace existing
installation with different scenario. This may lead to unpredictable
states. Use --force to override. You can use --compare-scenarios to see the
differences
[ INFO 2017-05-09 17:16:04 verbose] Log was be written to
/var/log/foreman-installer/katello.log
[ INFO 2017-05-09 17:16:04 verbose] Logs flushed
When I ran the --compare-scenarios I got the same error I did when I ran
–help.
I was following the procedure for install listed
here: Foreman :: Plugin Manuals
Anyone have any suggestions on how to resolve this?
