I just installed a brand new foreman in production (vagrant box works just fine) - everything is done with puppet with the same modules.
Centos7.4 on both
foreman throws this error:
Forbidden
You don’t have permission to access / on this server.
Passenger status:
[root@sjc04p1fomma01 yum.repos.d]# passenger-status
ERROR: Phusion Passenger doesn’t seem to be running. If you are sure that it is running, then the causes of this problem could be:
- You customized the instance registry directory using Apache’s PassengerInstanceRegistryDir option, Nginx’s passenger_instance_registry_dir option, or Phusion Passenger Standalone’s --instance-registry-dir command line argument. If so, please set the environment variable PASSENGER_INSTANCE_REGISTRY_DIR to that directory and run passenger-status again.
- The instance directory has been removed by an operating system background service. Please set a different instance registry directory using Apache’s PassengerInstanceRegistryDir option, Nginx’s passenger_instance_registry_dir option, or Phusion Passenger Standalone’s --instance-registry-dir command line argument.
Tried to do different things, none of those worked.
Everything installed from the same repos.
Any thoughts on this?
Thank you
