I have encountered 2 issues during the upgrade process from 1.16.0 to 1.17 RC1 on RHEL7. First is documentation issue that rake task tmp:sessions:clear is not defined:
[root@foreman-test ~]# foreman-rake tmp:sessions:clear
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Fixnum is deprecated
/opt/theforeman/tfm/root/usr/share/gems/gems/sequel-4.20.0/lib/sequel/database/schema_generator.rb:19: warning: constant ::Bignum is deprecated
/usr/share/foreman/lib/core_extensions.rb:183: warning: already initialized constant ActiveSupport::MessageEncryptor::DEFAULT_CIPHER
/opt/rh/tfm-ror51/root/usr/share/gems/gems/activesupport-5.1.4/lib/active_support/message_encryptor.rb:22: warning: previous definition of DEFAULT_CIPHER was here
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/appender.rb:139: warning: constant ::Fixnum is deprecated
rake aborted!
Don't know how to build task 'tmp:sessions:clear' (see --tasks)
/opt/rh/rh-ruby24/root/usr/share/gems/gems/rake-12.0.0/exe/rake:27:in `<top (required)>'
The second is that all rake tasks generate warnings:
[root@foreman-test ~]# foreman-rake db:migrate
/opt/theforeman/tfm/root/usr/share/gems/gems/logging-1.8.2/lib/logging/logger.rb:295: warning: constant ::Fixnum is deprecated
Do both warrant separate issues?
