Cannot run ansible role on fresh Foreman installation. It is acting like ssh command - runs on remote host (not smart proxy)
Run ansible-playbook on smart-proxy
fresh install of 1.24.3 using foreman-installer on bionic (following foreman docs)
dpkg --list | grep ruby
Summary
ii libruby2.5:amd64 2.5.1-1ubuntu1.6 amd64 Libraries necessary to run Ruby 2.5
ii puppet-agent 6.16.0-1bionic amd64 The Puppet Agent package contains all of the elements needed to run puppet, including ruby, facter, and hiera.
ii rake 12.3.1-1ubuntu0.1 all ruby make-like utility
ii ruby 1:2.5.1 amd64 Interpreter of object-oriented scripting language Ruby (default version)
ii ruby-algebrick 0.7.4-1 all Algebraic types and pattern matching for Ruby
ii ruby-ansi 1.5.0-1 all ANSI escape codes at your fingertips
ii ruby-apipie-bindings 0.3.0-1 all Ruby bindings for Apipie documented APIs
ii ruby-apipie-params 0.0.5-1 all DSL for describing data structures
ii ruby-augeas 1:0.5.0-3build6 amd64 Augeas bindings for the Ruby language
ii ruby-awesome-print 1.8.0-1 all pretty print Ruby objects with proper indentation and colors
ii ruby-bcrypt-pbkdf 1.0.0-1build2 amd64 Ruby library for OpenBSD's bcrypt_pdkfd
ii ruby-bundler 1.16.1-1 all Manage Ruby application dependencies (runtime)
ii ruby-bundler-ext 0.4.1-1 all Load system gems via Bundler DSL
ii ruby-clamp 1.1.1-1 all minimal framework for Ruby command-line utilities
ii ruby-concurrent 1.1.6+dfsg-2 all modern concurrency tools for Ruby
ii ruby-dev:amd64 1:2.5.1 amd64 Header files for compiling extension modules for Ruby (default version)
ii ruby-did-you-mean 1.2.0-2 all smart error messages for Ruby > 2.3
ii ruby-domain-name 0.5.20160216-2 all Domain Name manipulation library for Ruby
ii ruby-dynflow 1.4.2-1 all DYNamic workFLOW orchestration engine
ii ruby-fast-gettext 1.3.0-1 all Fast GetText implementation for Ruby
ii ruby-ffi 1.9.10debian-1build4 amd64 load dynamic libraries, bind functions from within ruby code
ii ruby-foreman-ansible 4.0.5-1 all Foreman Ansible plugin
ii ruby-foreman-deface 1.5.3-1 all Foreman Deface Plugin Dependency
ii ruby-foreman-remote-execution 2.0.8-1 all Foreman Remote Execution Plugin
ii ruby-foreman-remote-execution-core 1.3.0-1 all Foreman remote execution - core bits
ii ruby-foreman-tasks 0.17.6-1 all Tasks management engine for Foreman.
ii ruby-foreman-tasks-core 0.3.4-1 all Foreman tasks - core bits
ii ruby-gssapi 1.2.0-1 all FFI wrapper around the system GSSAPI library
ii ruby-hammer-cli 0.19.2-1 all Universal command-line interface
ii ruby-hammer-cli-foreman 0.19.7-1 all Foreman commands for Hammer
ii ruby-hashie 3.5.5-2 all small collection of tools that make hashes more powerful
ii ruby-highline 1.7.8-1 all high-level interactive IO Ruby library
ii ruby-http-cookie 1.0.2-1 all Ruby library to handle HTTP Cookies based on RFC 6265
ii ruby-json 2.1.0+dfsg-2 amd64 JSON library for Ruby
ii ruby-jwt 2.2.1-1 all JSON Web Token implementation in Ruby
ii ruby-kafo 4.0.0-1 all Ruby gem for making installations based on puppet user friendly
ii ruby-kafo-parsers 1.0.0-1 all Puppet module parsers
ii ruby-kafo-wizards 0.0.1-1 all Wizard like interfaces in terminal
ii ruby-libvirt 0.7.0-1build2 amd64 Ruby bindings for libvirt
ii ruby-little-plugger 1.1.4-1 all module that provides Gem based plugin management
ii ruby-locale 2.1.2-1 all Locale library for Ruby
ii ruby-logging 2.2.2-1 all flexible and extendable logging library for Ruby
ii ruby-mime-types 3.1-1 all guess MIME type of files
ii ruby-mime-types-data 3.2015.1120-1 all registry for information about MIME media type definitions
ii ruby-minitest 5.10.3-1 all Ruby test tools supporting TDD, BDD, mocking, and benchmarking
ii ruby-molinillo 0.6.4-1 all generic dependency resolution algorithm
ii ruby-multi-json 1.12.1-1 all Ruby library to provide easy switching between different JSON backends
ii ruby-net-http-persistent 2.9.4-1 all Manages persistent connections using Net::HTTP
ii ruby-net-scp 1.2.1-5 all pure ruby implementation of the SCP protocol
ii ruby-net-ssh 1:4.2.0-2ubuntu1 all Ruby implementation of the SSH protocol
ii ruby-net-telnet 0.1.1-2 all telnet client library
ii ruby-netrc 0.11.0-1 all Ruby library to read and write netrc files
ii ruby-oauth 0.5.3-1 all Ruby library for OAuth core
ii ruby-oj:amd64 3.4.0-1build1 amd64 fast JSON parser and serializer for Ruby
ii ruby-power-assert 0.3.0-1 all library showing values of variables and method calls in an expression
ii ruby-powerbar 1.0.18-1 all progressbar library for Ruby
ii ruby-rack 1.6.4-4ubuntu0.1 all modular Ruby webserver interface
ii ruby-rack-protection 1.5.3-2+deb9u1build0.18.04.1 all Protects against typical web attacks for Rack apps
ii ruby-rb-inotify 0.9.7-1 all A Ruby wrapper for Linux's inotify, using FFI
ii ruby-rbnacl 5.0.0-3 all Ruby binding to the Networking and Cryptography (NaCl) library
ii ruby-rest-client 2.0.2-3 all simple REST client for Ruby
ii ruby-rkerberos 0.1.3-3 amd64 Kerberos binding for Ruby
ii ruby-rsec 0.4.2-1 all Parser / Regexp Combinator For Ruby
ii ruby-rubyipmi 0.10.0-1 all A ruby wrapper for ipmi command line tools that supports ipmitool and freeipmi
ii ruby-sequel 5.6.0-1 all Simple, flexible, and powerful SQL database access toolkit for Ruby
ii ruby-sinatra 1.4.8-1 all Ruby web-development dressed in a DSL
ii ruby-smart-proxy-ansible 3.0.0-2 all Ansible support for Foreman smart proxy
ii ruby-smart-proxy-dynflow 0.2.4-1 all Dynflow runtime for Foreman smart proxy
ii ruby-smart-proxy-dynflow-core 0.2.4-1 all Dynflow runtime for Foreman smart proxy
ii ruby-smart-proxy-remote-execution-ssh 0.2.1-1 all SSH remote execution provider for Foreman smart proxy
ii ruby-sqlite3 1.3.13-1build2 amd64 SQLite3 interface for Ruby
ii ruby-test-unit 3.2.5-1 all unit testing framework for Ruby
ii ruby-thor 0.19.4-1 all Ruby scripting framework
ii ruby-tilt 2.0.1-2 all Generic interface to multiple Ruby template engines
ii ruby-unf 0.1.4-2 all Wrapper library to bring Unicode Normalization Form support to Ruby
ii ruby-unf-ext 0.0.7.4-1build2 amd64 Unicode Normalization Form support library for CRuby
ii ruby-unicode 0.4.4-2build8 amd64 Unicode string manipulation library for Ruby
ii ruby-unicode-display-width 1.1.3-1 all Determines the monospace display width of a string in Ruby
ii ruby-xmlrpc 0.3.0-2 all XMLRPC library for Ruby
ii ruby2.5 2.5.1-1ubuntu1.6 amd64 Interpreter of object-oriented scripting language Ruby
ii ruby2.5-dev:amd64 2.5.1-1ubuntu1.6 amd64 Header files for compiling extension modules for the Ruby 2.5
ii ruby2.5-doc 2.5.1-1ubuntu1.6 all Documentation for Ruby 2.5
ii rubygems-integration 1.11 all integration of Debian Ruby packages with Rubygems
Ubuntu server 18.04 Bionic
Here is the log where you can see tha playbook was copied to Provisioned host and run as a script (!) . I have verified it acts exactly the same as if I run a job Run Command - SSH Default
smart proxy logs:
2020-07-02T11:45:16 [D] opening session to root@00000000-0000-0000-ffff-000000029175.bic.local
2020-07-02T11:45:16 f3dca61e [I] Finished POST /dynflow/tasks/ with 200 (21.36 ms)
2020-07-02T11:45:16 [D] close: 192.168.168.105:59294
2020-07-02T11:45:17 [D] Sending data to /var/tmp/foreman-ssh-cmd-0a6927e3-cf7f-48e3-a7e4-ca9455af23e7/script on remote host:
- hosts: all
gather_facts: no
pre_tasks:
- name: Display all parameters known for the Foreman host
debug:
var: foreman
tasks:
- name: Apply roles
include_role:
name: "{{ role }}"
loop: "{{ foreman_ansible_roles }}"
loop_control:
loop_var: role
2020-07-02T11:45:17 [D] executing script:
| sh <<WRAPPER
| (/var/tmp/foreman-ssh-cmd-0a6927e3-cf7f-48e3-a7e4-ca9455af23e7/script < /dev/null; echo \$?>/var/tmp/foreman-ssh-cmd-0a6927e3-cf7f-48e3-a7e4-ca9455af23e7/exit_code) | /usr/bin/tee /var/tmp/foreman-ssh-cmd-0a6927e3-cf7f-48e3-a7e4-ca9455af23e7/output
| exit \$(cat /var/tmp/foreman-ssh-cmd-0a6927e3-cf7f-48e3-a7e4-ca9455af23e7/exit_code)
| WRAPPER
2020-07-02T11:45:17 [D] refresh runner 0a6927e3-cf7f-48e3-a7e4-ca9455af23e7
2020-07-02T11:45:17 [D] refreshing runner
2020-07-02T11:45:17 [D] planning to refresh 0a6927e3-cf7f-48e3-a7e4-ca9455af23e7
2020-07-02T11:45:18 [D] Ticker ticking for 1 events
2020-07-02T11:45:18 [D] refresh runner 0a6927e3-cf7f-48e3-a7e4-ca9455af23e7
2020-07-02T11:45:18 [D] refreshing runner
2020-07-02T11:45:18 [D] finish runner 0a6927e3-cf7f-48e3-a7e4-ca9455af23e7
2020-07-02T11:45:18 [D] closing session for command [0a6927e3-cf7f-48e3-a7e4-ca9455af23e7],0 actors left
2020-07-02T11:45:18 [D] terminate 0a6927e3-cf7f-48e3-a7e4-ca9455af23e7
2020-07-02T11:45:18 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 2 got event #<ForemanTasksCore::Runner::Update:0x000055e1c3f13b28>
2020-07-02T11:45:18 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 2 suspended >> running in phase Run ForemanRemoteExecutionCore::Actions::RunScript
2020-07-02T11:45:18 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 2 running >> success in phase Run ForemanRemoteExecutionCore::Actions::RunScript
2020-07-02T11:45:18 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 5 pending >> running in phase Run SmartProxyDynflowCore::Callback::Action
2020-07-02T11:45:19 [D] Executor heartbeat
2020-07-02T11:45:21 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 5 running >> success in phase Run SmartProxyDynflowCore::Callback::Action
2020-07-02T11:45:21 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 3 pending >> running in phase Finalize ForemanRemoteExecutionCore::Actions::RunScript
2020-07-02T11:45:21 [E] Script execution failed
2020-07-02T11:45:21 [D] Step ef1ddb3a-8831-4db1-90bc-c0c2734e7eac: 3 running >> error in phase Finalize ForemanRemoteExecutionCore::Actions::RunScript
2020-07-02T11:45:21 [D] ExecutionPlan ef1ddb3a-8831-4db1-90bc-c0c2734e7eac running >> stopped
