I need to be able to add web users automatically (aka - scripted) via some
sort of CLI or 'curl' request. Assuming I need to allow this user only
access to the provisioning module, what should i expect? The current
production.log showing the actual (and working) command, but I am unable to
translate it into the curl commands…
I would appreciate some real example of such an operation. It could be
great.
> great.
Hi. I actually did. I worked very extensively with hammer up until now,
including (nearly) full automation of Foreman deployment. However:
hammer user create --login someuser --firstname some --lastname user
–mail someuser@domain.com --password 123456
Could not create the user:
Error: option '–auth-source-id' is required
–mail someuser@domain.com --password 123456 --auth-source-id INTERNAL
Invalid username or password
–mail someuser@domain.com --password 123456 --auth-source-id 1
I do not know what is auth-source-id and where do I get it. I do not think
the command responds correctly to either value I place there (I have only
internal, built-in admin user currently, and no plans of connecting the
system to ADS or any other LDAP service). Moreover - how do I set the roles
the user should get when it's created - the 'hammer user update' allows
specifying '–id' which is the resource ID. What is the resource ID? Is it
role from the roles menu? Is it something else?
Thanks!
Etzion
On Wednesday, 12 February 2014 08:35:03 UTC+2, ohad wrote:
> On Wed, Feb 12, 2014 at 1:31 AM, Etzion Bar-Noy <etz...@barnoy.co.il > > wrote:
>> some sort of CLI or 'curl' request. Assuming I need to allow this user only
>> translate it into the curl commands...
>> great.
> did you try out our CLI? see
> http://blog.theforeman.org/2013/11/hammer-cli-for-foreman-part-i-setup.html
>> Thanks!
>> Etzion
>> "Foreman users" group.
>> Visit this group at http://groups.google.com/group/foreman-users.
>> For more options, visit https://groups.google.com/groups/opt_out.
–auth-source-id should be 1 in your case, which is 'INTERNAL' (not
connected to LDAP or anything). The last option is right.
I just tried: "hammer user create --login someuser --firstname some
–lastname user --mail someuser@domain.com --password 123456
–auth-source-id 1", after you type that in, it should ask for your
username and password, then you type your admin username and password and
it should work (it works on my Foreman).
Updating the roles is a little trickier and I believe hammer can only
update the login, firstname, lastname, email, admin flag, password, and
authentication source.
You can update the roles programatically using the API though, https://gist.github.com/eLobato/8973253 is the format of the API response
for users, more info here Foreman or in IRC #theforeman-dev#theforeman
Error: option ‘–auth-source-id’ is required
the user should get when it’s created - the ‘hammer user update’ allows
specifying ‘–id’ which is the resource ID. What is the resource ID? Is it
Thanks!
Etzion
some sort of CLI or ‘curl’ request. Assuming I need to allow this user only
great.
Groups “Foreman users” group.
an email to foreman-user...@googlegroups.com.
To post to this group, send email to forema...@googlegroups.com.
So far, hammer was able to perform actions without asking me for login
details. However, the output I showed is the output I get. I will emphasise
that I use foreman 1.3.2 and RPM build of these tools under it.
Etzion
On Thursday, 13 February 2014 13:04:10 UTC+2, Daniel Lobato wrote:
> Hi Etzion,
> --auth-source-id should be 1 in your case, which is 'INTERNAL' (not
> --lastname user --mail some...@domain.com --password 123456
> --auth-source-id 1", after you type that in, it should ask for your
> for users, more info here http://theforeman.org/api.html or in IRC
> #theforeman-dev #theforeman
> On Wed, Feb 12, 2014 at 9:47 PM, Etzion Bar-Noy <etz...@barnoy.co.il > > wrote:
>> Error: option '--auth-source-id' is required
>> --auth-source-id 1
>> think the command responds correctly to either value I place there (I have
>> only internal, built-in admin user currently, and no plans of connecting
>> the system to ADS or any other LDAP service). Moreover - how do I set the
>> roles the user should get when it's created - the 'hammer user update'
>> allows specifying '--id' which is the resource ID. What is the resource ID?
>> Is it role from the roles menu? Is it something else?
>> Thanks!
>> Etzion
>>>> great.
>>> did you try out our CLI? see http://blog.theforeman.org/
>>>> Thanks!
>>>> Etzion
>>>> Groups "Foreman users" group.
> Daniel Lobato
> @elobatoss
> blog.daniellobato.me
> daniellobato.me
> GPG: http://keys.gnupg.net/pks/lookup?op=get&search=0x7A92D6DD38D6DE30
Well if you are not being asked for login details and you are getting that
error, it's possible that your login details are wrong. Can you check your
username/pass are correctly set in one of:
If so, and you're able to run other hammer commands without that error, I'd
recommend updating to the latest hammer-cli and hammer-foreman-cli version.
Etzion
Hi Etzion,
–auth-source-id should be 1 in your case, which is ‘INTERNAL’ (not
I just tried: “hammer user create --login someuser --firstname some
–lastname user --mail some...@domain.com --password 123456
–auth-source-id 1”, after you type that in, it should ask for your
response for users, more info here Foreman or in
–mail some...@domain.com --password 123456
–mail some...@domain.com --password 123456 --auth-source-id INTERNAL
–mail some...@domain.com --password 123456 --auth-source-id 1
roles the user should get when it’s created - the ‘hammer user update’
allows specifying ‘–id’ which is the resource ID. What is the resource ID?
Thanks!
Etzion
great.
Other hammer commands work flawlessly, without asking for credentials.
Assuming there is no newer RPM available for hammer. What are the other
methods of installing them?
The culprit is I am required to deliver the system (and its likes), as a
fully automated deployment. I need to be able to download hammer files so
that later I would be able to install it without Internet connection
whatsoever. How should I approach to it?
Etzion
> /etc/foreman/cli_config.yml.
> ~/.foreman/cli_config.yml
> ./config/cli_config.yml
> I'd recommend updating to the latest hammer-cli and hammer-foreman-cli
> version.
> On Thu, Feb 13, 2014 at 12:37 PM, Etzion Bar-Noy <etz...@barnoy.co.il > > wrote:
>> Etzion
>>> Hi Etzion,
>>> response for users, more info here http://theforeman.org/api.html or in
>>> IRC #theforeman-dev #theforeman
>>>> --mail some...@domain.com --password 123456 --auth-source-id INTERNAL
>>>> --mail some...@domain.com --password 123456 --auth-source-id 1
>>>> Thanks!
>>>> Etzion
>>>>>> be great.
>>>>> did you try out our CLI? see http://blog.theforeman.org/201
>>>>>> Thanks!
>>>>>> Etzion
>>>>>> send an email to foreman-user...@googlegroups.com.
>>> Daniel Lobato
>>> @elobatoss
>>> daniellobato.me
> Daniel Lobato
> @elobatoss
> daniellobato.me
I will have to test it. I attempted to upgrade (in my process, not an
upgrade process per-se) theForeman to version 1.4, and found several
incompatibilities which make this process a hard one. Can I use raw API
commands to work around it? I find the API a little too complex for me, not
being a developer, and would love to have a CURL string which will perform
the little task I brought up initially.
Thanks
Etzion
> > so that later I would be able to install it without Internet connection
> Looks like you're hitting http://projects.theforeman.org/issues/3948,
> which was fixed in Foreman 1.4.0.
> The newer version of Hammer is available in the Foreman 1.4 repos, so
> you could try it, but my understanding is that it's made to work with
> Foreman 1.4 and not 1.3. I'm aware of a couple of areas that it might
> be incompatible with 1.3 in. Generally I'd suggest updating both
> Foreman and Hammer together.
> Dominic Cleal
> Red Hat Engineering
Thanks
Etzion
a
you could try it, but my understanding is that it’s made to work with
Foreman 1.4 and not 1.3. I’m aware of a couple of areas that it might
be incompatible with 1.3 in. Generally I’d suggest updating both
Then I can assign roles using the API in the following manner:
curl -k -u admin:changeme -H "Content-Type:application/json" -H
"Accept:application/json,version=2" -X PUT -d
"{"user":{"id":"2","role_ids":["","","1","4","5"]}}" https://foreman.mgmt/api/users/2-someuser | prettify_json.rb
Thanks. Not perfect, but I sure can use it now.
Etzion
On Friday, 14 February 2014 01:17:37 UTC+2, Daniel Lobato wrote:
> Yes indeed, ask away about the API.
> Here's the description http://theforeman.org/api.html
> On Thu, Feb 13, 2014 at 3:06 PM, Etzion Bar-Noy <etz...@barnoy.co.il > > wrote:
>> Thanks
>> Etzion
>>> other
>>> a
>>> connection
>>> Dominic Cleal
>>> Red Hat Engineering
> Daniel Lobato
> @elobatoss
> daniellobato.me
