Foreman 1.6.0 // certname (CN) and hostname (FQDN)
In our environment, the FQDN is not stable, but the certname is. In the
past, I've simply tracked all nodes (in Puppet Dashboard) via the
certname.
In Foreman 1.6.0, here's the behavior I've observed:
Node with certname X and FQDN Y does a puppet run. In The Foreman, the
node shows up as Y (under All Hosts). When you click on it, it has the
certname = X value.
Now, the FQDN on this Node changes to Z. It performs a puppet run. In The
Foreman, the node shows up as Y (still). When you click on it, it has the
certname = X value.
In the rare case the certname/CN needs to change, this is what happens:
certname/CN changes to Q:
If the hostname (FQDN) is still Y when it performs a puppet run, Foreman
will update the certname for Y from X to Q. It apparently correllates the
hostname (FQDN) and uses that as identity. I believe that's from this line
in managed.rb:
return Host.new, true if host.nil?
# if we were given a certname but found the Host by hostname we should
update the certname
host.certname = certname if certname.present?
What is the reasoning behind this? To me, the certname (CN) should be the
only identity mechanism, and there should be no case where the hostname
(FQDN) can be used for identity to Puppet/Foreman. I could think of a
security issue where a new certificate is signed (cn=newnode) and the
malicious system administrator (insider thread) changes the system's
hostname/FQDN to a system that's already in Puppet/Foreman (let's call it
radiusserver). When this new system talks to Foreman for the first time,
Foreman will update the entry for Host "radiusserver" with what it thinks
is its new certname (cn=newnode), and will provide manifests to newnode as
if it were radiusserver (that is bad).
Am I missing something obvious?
Are you using ruby-storeconfigs with a shared database? If not, this sounds
like a regression. If so, you should probably split the database. (And
eventually migrate to puppetdb)
-Brian
··· On Tue, Oct 21, 2014 at 11:10 AM, Stephen Bowman wrote: > In our environment, the FQDN is not stable, but the certname is. In the > past, I've simply tracked all nodes (in Puppet Dashboard) via the certname. > > In Foreman 1.6.0, here's the behavior I've observed: > > Node with certname X and FQDN Y does a puppet run. In The Foreman, the node > shows up as Y (under All Hosts). When you click on it, it has the certname > = X value. > > Now, the FQDN on this Node changes to Z. It performs a puppet run. In The > Foreman, the node shows up as Y (still). When you click on it, it has the > certname = X value. > > In the rare case the certname/CN needs to change, this is what happens: > > certname/CN changes to Q: > > If the hostname (FQDN) is still Y when it performs a puppet run, Foreman > will update the certname for Y from X to Q. It apparently correllates the > hostname (FQDN) and uses that as identity. I believe that's from this line > in managed.rb: > > return Host.new, true if host.nil? > # if we were given a certname but found the Host by hostname we should > update the certname > host.certname = certname if certname.present? > > What is the reasoning behind this? To me, the certname (CN) should be the > only identity mechanism, and there should be no case where the hostname > (FQDN) can be used for identity to Puppet/Foreman. I could think of a > security issue where a new certificate is signed (cn=newnode) and the > malicious system administrator (insider thread) changes the system's > hostname/FQDN to a system that's already in Puppet/Foreman (let's call it > radiusserver). When this new system talks to Foreman for the first time, > Foreman will update the entry for Host "radiusserver" with what it thinks is > its new certname (cn=newnode), and will provide manifests to newnode as if > it were radiusserver (that is bad). > > Am I missing something obvious? > > -- > You received this message because you are subscribed to the Google Groups > "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an > email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/d/optout.
This is with a default configuration provided using the Foreman installer
(1.6.0). No shared DB.
··· On Tuesday, October 21, 2014 11:22:40 AM UTC-4, Brian Gupta wrote: > > Are you using ruby-storeconfigs with a shared database? If not, this > sounds > like a regression. If so, you should probably split the database. (And > eventually migrate to puppetdb) > > -Brian > > On Tue, Oct 21, 2014 at 11:10 AM, Stephen Bowman > wrote: > > In our environment, the FQDN is not stable, but the certname is. In the > > past, I've simply tracked all nodes (in Puppet Dashboard) via the > certname. > > > > In Foreman 1.6.0, here's the behavior I've observed: > > > > Node with certname X and FQDN Y does a puppet run. In The Foreman, the > node > > shows up as Y (under All Hosts). When you click on it, it has the > certname > > = X value. > > > > Now, the FQDN on this Node changes to Z. It performs a puppet run. In > The > > Foreman, the node shows up as Y (still). When you click on it, it has > the > > certname = X value. > > > > In the rare case the certname/CN needs to change, this is what happens: > > > > certname/CN changes to Q: > > > > If the hostname (FQDN) is still Y when it performs a puppet run, Foreman > > will update the certname for Y from X to Q. It apparently correllates > the > > hostname (FQDN) and uses that as identity. I believe that's from this > line > > in managed.rb: > > > > return Host.new, true if host.nil? > > # if we were given a certname but found the Host by hostname we > should > > update the certname > > host.certname = certname if certname.present? > > > > What is the reasoning behind this? To me, the certname (CN) should be > the > > only identity mechanism, and there should be no case where the hostname > > (FQDN) can be used for identity to Puppet/Foreman. I could think of a > > security issue where a new certificate is signed (cn=newnode) and the > > malicious system administrator (insider thread) changes the system's > > hostname/FQDN to a system that's already in Puppet/Foreman (let's call > it > > radiusserver). When this new system talks to Foreman for the first > time, > > Foreman will update the entry for Host "radiusserver" with what it > thinks is > > its new certname (cn=newnode), and will provide manifests to newnode as > if > > it were radiusserver (that is bad). > > > > Am I missing something obvious? > > > > -- > > You received this message because you are subscribed to the Google > Groups > > "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send > an > > email to foreman-user...@googlegroups.com . > > To post to this group, send email to forema...@googlegroups.com > . > > Visit this group at http://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/d/optout. >
