> From: "Brian Williams" <brianrwlms@gmail.com>
> To: foreman-users@googlegroups.com
> Cc: stephen@redhat.com
> Sent: Thursday, May 14, 2015 11:15:36 PM
> Subject: Re: [foreman-users] Foreman 1.8 + salt 2014.7.5: undefined method merge' for nil:NilClass (updated) > > Thanks - I upgraded to Foreman 1.8 - latest and salt 2014.7.5, now I see > this in salt logs. > > 2015-05-14 15:23:45,410 [salt.loaded.int.module.cmdmod ][ERROR > ] Command '/usr/bin/foreman-node testvm01.xxxx.com' failed with retu > rn code: 1 > 2015-05-14 15:23:45,411 [salt.loaded.int.module.cmdmod ][ERROR > ] output: Could not get grains: undefined method
merge' for nil:Nil
> Class
You might see this if the minion has no cached grains, have you ever
used the minion before? It should go away when you run salt <hostname> grains.items
> 2015-05-14 15:23:45,412 [salt.loaded.int.pillar.puppet
> ][CRITICAL] YAML data from /usr/bin/foreman-node failed to parse
> [root@ntpforeman salt]# /usr/bin/foreman-node testvm01.xxxx.com
> classes:
> - vim
> parameters:
> puppetmaster: ntpforeman.xxxx.com
> hostgroup: NTP
> root_pw: $1$7S7go7WC$aA3yLRp/FRJfDBp9/e0Ub.
> puppet_ca: ntpforeman.xxxx.com
> foreman_env: development
> owner_name: Admin User
> owner_email: root@xxxx.com
> foreman_subnets:
> - network: 10.137.244.0
> mask: 255.255.252.0
> vlanid: ''
> gateway: 10.137.247.254
> dns_primary: ''
> dns_secondary: ''
> from: ''
> to: ''
> boot_mode: Static
> ipam: None
> foreman_interfaces:
> - mac: 00:0c:29:91:36:50
> ip: 10.137.247.246
> type: Interface
> attrs:
> netmask: 255.255.252.0
> mtu: '1500'
> virtual: false
> link: true
> identifier: eth0
> managed: true
> primary: true
> provision: true
> subnet:
> mask: 255.255.252.0
> vlanid: ''
> dns_primary: ''
> dns_secondary: ''
> from: ''
> to: ''
> boot_mode: Static
> ipam: None
> salt_master: ntpforeman.xxxx.com
Is this really the output of the command? It doesn't look right, environment is missing, and
salt_master shouldn't be at that indentation level.
> I imported a salt state - 'vim' successfully in foreman. Yet it is not
> being applied
Have you have you configured /etc/salt/master? It has this?
master_tops:
ext_nodes: /usr/bin/foreman-node
The missing environment output from foreman-node could be the source of the problems, but assuming
foreman-node returns the right output, not sure why Salt wouldn't do the right thing.
What happens if you run: salt -v <hostname> state.highstate?
> and I am not seeing salt states when provisioining thru
> foreman-discovery. Even though I choose salt master, and environment, the
> salt states tab asks me to specify and environment.
Could you file a bug? Foreman
I had a quick look and it seems like it might be easy to fix so it works with discovery.
Thanks
----- Original Message -----
Any thoughts?
Thanks
On Sunday, May 3, 2015 at 4:27:03 PM UTC-5, Stephen Benjamin wrote:
On Thu, Apr 30, 2015 at 02:29:47PM -0700, Brian Williams wrote:
2015-04-29 15:12:43,175 [salt.loaded.int.module.cmdmod
][ERROR
] Command ‘/usr/bin/foreman-node testvm.xxxx.com’ failed with return
code: 1
][ERROR
] output: Could not get grains: undefined method `merge’ for
nil:NilClass
2015-04-29 15:12:43,176 [salt.loaded.int.pillar.puppet
I am not seeing grains in foreman, nor do I see salt states. Salt states
are not applied to builds, but ‘run salt’ highstate does work on
provisioned systems.
You have to add the states manually to Foreman, we don’t import them
yet (Feature #8473: Import list of Salt environments and States from the Master - Salt - Foreman).
Can you run ‘/usr/bin/foreman-node testvm.xxxx.com’ on the salt master?
What is
returned? I’d guess it’s not returning YAML it sounds like your
/etc/salt/foreman.yaml is misconfigured (see:
Foreman :: Plugin Manuals). You can
also check /var/log/foreman/production.log.
Also does the testvm.xxxx.com minion return grains if you do this?
salt ‘testvm.xxxx.com’ grains.items
Groups “Foreman users” group.
an email to foreman-user...@googlegroups.com <javascript:>.
To post to this group, send email to forema...@googlegroups.com
<javascript:>.
"Foreman users" group.
