Debian 9 AMD 64
Foreman 17.0 RC1
** Log Output **
[ WARN 2018-02-27T20:23:07 main] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]/returns: from /usr/lib/ruby/2.3.0/rubygems/core_ext/k
ernel_require.rb:55:in `require'
[ERROR 2018-02-27T20:23:07 main] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Failed to call refresh: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
[ERROR 2018-02-27T20:23:07 main] /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: '/usr/sbin/foreman-rake db:migrate' returned 1 instead of one of [0]
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/errors.rb:157:in `fail'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/exec.rb:164:in `sync'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/type/exec.rb:604:in `refresh'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:147:in `process_callback'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:34:in `block in process_events'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:119:in `block in queued_events'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in `each'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:118:in `queued_events'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/event_manager.rb:33:in `process_events'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:278:in `eval_resource'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `call'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `block (2 levels) in evaluate'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:517:in `block in thinmark'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/2.4.0/benchmark.rb:308:in `realtime'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:516:in `thinmark'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:181:in `block in evaluate'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/graph/relationship_graph.rb:121:in `traverse'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction.rb:171:in `evaluate'
[ERROR 2018-02-27T20:23:07 main] /usr/lib/ruby/vendor_ruby/kafo/modules/kafo_configure/lib/puppet/parser/functions/add_progress.rb:30:in `evaluate_with_trigger'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:238:in `block in apply'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/log.rb:156:in `with_destination'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/transaction/report.rb:144:in `as_logging_destination'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/resource/catalog.rb:237:in `apply'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:174:in `block in apply_catalog'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:232:in `block in benchmark'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:231:in `benchmark'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:173:in `apply_catalog'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:348:in `run_internal'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:224:in `block in run'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/context.rb:65:in `override'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet.rb:260:in `override'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/configurer.rb:198:in `run'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:354:in `apply_catalog'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block (2 levels) in main'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:280:in `block in main'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:233:in `main'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application/apply.rb:174:in `run_command'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `block in run'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util.rb:665:in `exit_on_fail'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/application.rb:375:in `run'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:137:in `run'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/lib/ruby/vendor_ruby/puppet/util/command_line.rb:73:in `execute'
[ERROR 2018-02-27T20:23:07 main] /opt/puppetlabs/puppet/bin/puppet:5:in `<main>'
Problem occured after adding
- [âś“] Configure foreman_plugin_tasks
and
- [âś“] Configure foreman_plugin_ansible
root@foreman:/home/tkoeck# apt-get install Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 3 not fully installed or removed. After this operation, 0 B of additional disk space will be used. Setting up ruby-foreman-deface (1.2.0-1) ... dpkg: error processing package ruby-foreman-deface (--configure): subprocess installed post-installation script returned error exit status 6 dpkg: dependency problems prevent configuration of ruby-foreman-azure: ruby-foreman-azure depends on ruby-foreman-deface (<< 2.0.0); however: Package ruby-foreman-deface is not configured yet. dpkg: error processing package ruby-foreman-azure (--configure): dependency problems - leaving unconfigured dpkg: dependency problems prevent configuration of ruby-foreman-ansible: ruby-foreman-ansible depends on ruby-foreman-deface (<< 2.0.0); however: Package ruby-foreman-deface is not configured yet. dpkg: error processing package ruby-foreman-ansible (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: ruby-foreman-deface ruby-foreman-azure ruby-foreman-ansible
