Foreman 2.0rc1 install problems
As always I’m early with the new foreman installation. This time I run into a dependency problem.
–> Finished Dependency Resolution
Error: Package: tfm-ror52-rubygem-turbolinks-2.5.4-1.el7.noarch (@foreman-rails-1.20-rhel7)
Requires: tfm-ror52-rubygem(coffee-rails)
Removing: tfm-ror52-rubygem-coffee-rails-4.2.2-1.el7.noarch (@foreman-rails-1.20-rhel7)
tfm-ror52-rubygem(coffee-rails) = 4.2.2
Obsoleted By: tfm-rubygem-coffee-rails-4.2.2-5.el7.noarch (foreman-2.0-rhel7)
Not found
We need a new turbolink package. Is repo http://yum.theforeman.org/rails/foreman-2.0/ obsolete ? It is empty.
Foreman 1.24 -> Foreman 2.0
lsb_release -a
LSB Version: :core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID: RedHatEnterpriseServer
Description: Red Hat Enterprise Linux Server release 7.7 (Maipo)
Release: 7.7
Codename: Maipo
Attached repos from Sattelite
rhel-x86_64-server-7
rhel-x86_64-server-7-rhscl-1
rhel-x86_64-server-extras-7
rhel-x86_64-server-optional-7
rhel-x86_64-server-rh-common-7
rhel-x86_64-server-supplementary-7
rhn-tools-rhel-x86_64-server-7
Addinial Repos
EPEL
Cenos-SCL
copy of Foreman 2.0 repo
copy of Foreman 2.0 plugins repo
Yes, all packages were added to the main repository. turbolinks has been removed. The foreman-release package should have all the repositories you need though for rhel you also need the rhscl repository enabled prior to installation.
It is still on the TODO to update the installation/upgrade manual.
I was only able to update when I removed the turbolink packages via
rpm -e --nodeps tfm-ror52-rubygem-turbolinks-2.5.4-1.el7.noarch
There was no way to resolve the dependency problem.
We’ve moved all packages from tfm-ror52-* to tfm-*. I suspect that we had tfm-rubygem-turbolinks obsolete tfm-ror52-rubygem-turbolinks. Then we dropped turbolinks and had tfm obsolete tfm-rubygem-turbolinks. This means yum doesn’t know how to obsolete it. The solution is probably to have tfm also obsolete tfm-ror52-rubygem-turbolinks.
https://projects.theforeman.org/issues/29181
