I am thinking to use foreman 2.2 rc3 with katello 3.16 on centos 7 , is it recommended for prod ? also i find one issue in installation of postgres encoding , its known bug or it only come in some special condition ?
[ERROR 2020-10-07T08:24:52 main] 2020-10-07 08:24:50.814428 WARN puppetlabs.facter - locale environment variables were bad; continuing with LANG=C LC_ALL=C
Warning: /etc/foreman-installer/custom-hiera.yaml: file does not contain a valid yaml hash
Error: Evaluation Error: Error while evaluating a Function Call, âupcaseâ parameter âargâ expects a value of type Numeric, String, Array, or Hash, got Undef (file: /usr/share/foreman-installer/modules/foreman_proxy/manifests/params.pp, line: 279, column: 29) on node fountain2
[ERROR 2020-10-07T08:24:52 main] Could not get default values, cannot continue
Back to same situation katello 3.16 have bug as it create DB in SQL_ASCII instead of UTF 8
Katello::Errors::Pulp3Error: unsupported Unicode escape sequence
LINE 1: âŚânameâ: âtechnical-writingâ, âdefaultâ: false}]â, '{âasâ: "âŚ
DETAIL: Unicode escape values cannot be used for code point values above 007F when the server encoding is not UTF8.
CONTEXT: JSON data, line 1: {âasâ:âŚ
The database must use UTF-8 encoding. If youâre deploying it all on the same server, we guarantee that but if youâre using a pre-created external database thatâs up to you.
