I have a foreman 2.4 server running on CentOS 7. The system got rebooted and I can no longer access the WebUI. There seems to be two issues, one is postgres service will not start. The other is when navigating to the WebUI, I get the following error:
Web application could not be started
Gem loading error: cannot load such file -- rubyeventmachine (RuntimeError)
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/output.rb:13:in `strict_err'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:46:in `rescue in block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:39:in `block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:37:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext/runtime.rb:37:in `system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:19:in `block in system_require'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:14:in `each'
/opt/theforeman/tfm/root/usr/share/gems/gems/bundler_ext-0.4.1/lib/bundler_ext.rb:14:in `system_require'
/usr/share/foreman/config/application.rb:35:in `<top (required)>'
/opt/rh/rh-ruby25/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:59:in `require'
/usr/share/foreman/config/environment.rb:2:in `<top (required)>'
config.ru:5:in `block in <main>'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:125:in `instance_eval'
/opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:125:in `initialize'
config.ru:1:in `new'
config.ru:1:in `<main>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `eval'
/usr/share/passenger/helper-scripts/rack-preloader.rb:112:in `preload_app'
/usr/share/passenger/helper-scripts/rack-preloader.rb:158:in `<module:App>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:29:in `<module:PhusionPassenger>'
/usr/share/passenger/helper-scripts/rack-preloader.rb:28:in `<main>'
Error ID
016aba23
Please help, I am happy to provide any further information that I am able to.
Joseph
