I’ve got a brand new Foreman 2.0 build, I’ve provisioned a test workstation with Centos 7.7 which has built correctly.
What I’m not seeing is any reports from that build? The only host I’m seeing that reports back is the Foreman server itself.
[root@foreman01 puppet]# cat puppet.conf
[main]
basemodulepath = /etc/puppetlabs/code/environments/common:/etc/puppetlabs/code/modules:/opt/puppetlabs/puppet/modules:/usr/share/puppet/modules
certname = foreman01.ff.test.com
codedir = /etc/puppetlabs/code
environmentpath = /etc/puppetlabs/code/environments
hiera_config = $confdir/hiera.yaml
hostprivkey = $privatekeydir/$certname.pem { mode = 640 }
logdir = /var/log/puppetlabs/puppet
pluginfactsource = puppet:///pluginfacts
pluginsource = puppet:///plugins
privatekeydir = $ssldir/private_keys { group = service }
reports = foreman
rundir = /var/run/puppetlabs
server = foreman01.ff.test.com
show_diff = false
ssldir = /etc/puppetlabs/puppet/ssl
vardir = /opt/puppetlabs/puppet/cache
[agent]
classfile = $statedir/classes.txt
default_schedules = false
environment = production
localconfig = $vardir/localconfig
masterport = 8140
noop = false
report = true
runinterval = 1800
splay = false
splaylimit = 1800
usecacheonfailure = true
[master]
autosign = /etc/puppetlabs/puppet/autosign.conf { mode = 0664 }
ca = true
external_nodes = /etc/puppetlabs/puppet/node.rb
logdir = /var/log/puppetlabs/puppetserver
node_terminus = exec
parser = current
rundir = /var/run/puppetlabs/puppetserver
strict_variables = false
vardir = /opt/puppetlabs/server/data/puppetserver
What am I missing, what else do I need to do?
