When configuring redis - we are trying to use a remote shared cluster as we have many nodes. We have configured both:
dynflow_redis_url and rails_cache_store (we use the puppet modules for foreman)
The “worker” services seem to work correctly - utilizing our remote URL and starting up and working without issue.
The “orchestrator” service however - ignores our clustered URL
settings.yaml
[me@myserver ~]$ sudo cat /etc/foreman/settings.yaml | grep redis
:redis_url: redis://my.correct.reds.url:6379/6
:type: redis
- redis://my.correct.reds.url:6379/0
[me@myserver~]$
It “looks” like both the worker and the orchestrator utilize the below systemd unit file. This file has a localhost default. the “workers” correctly override using the URL in settings.yaml - but the “orchestrator” does not. Furthermore - the orchestrator will then fail to start because redis isn’t even installed locally when the URL is specified: https://github.com/theforeman/puppet-foreman/blob/d84fb8edb340904f9afcbf869fa66ea391f267ed/manifests/config.pp#L10-L16
[Unit]
Description=Foreman jobs daemon - %i on sidekiq
Documentation=https://theforeman.org
After=network.target remote-fs.target nss-lookup.target
[Service]
Type=notify
User=foreman
TimeoutSec=300
PrivateTmp=true
Environment=RAILS_ENV=production
Environment=DYNFLOW_SIDEKIQ_SCRIPT=/usr/share/foreman/extras/dynflow-sidekiq.rb
Environment=DYNFLOW_REDIS_URL=redis://localhost:6379/0
Environment=REDIS_PROVIDER=DYNFLOW_REDIS_URL
# Greatly reduce Ruby memory fragmentation and heap usage
# https://www.mikeperham.com/2018/04/25/taming-rails-memory-bloat/
Environment=MALLOC_ARENA_MAX=2
WorkingDirectory=/usr/share/foreman
ExecStart=/usr/libexec/foreman/sidekiq-selinux -e ${RAILS_ENV} -r ${DYNFLOW_SIDEKIQ_SCRIPT} -C /etc/foreman/dynflow/%i.yml
ExecReload=/usr/bin/kill -TSTP $MAINPID
SyslogIdentifier=dynflow-sidekiq@%i
# if we crash, restart
RestartSec=1
Restart=on-failure
[Install]
WantedBy=multi-user.target
I’m not clear on:
- Can orchestrator be configured to use a remote redis cluster, or is there some technical reason why it must be local? Worker seems to spin up using remote redis just fine.
I’m toying with (for now) simply overwriting/overriding the Environment=DYNFLOW_REDIS_URL=redis://localhost:6379/0 line in the unit file with the correct default - but want to confirm im not gonna break something by having all my orchestrator sidekiq services start using a single redis URL similar to the worker-nodes…
redis remote configuration should work when specified.
Foreman 3.0
Foreman 3.0
RHEL8.4
