This issue is on Centos 7.9, a new install on a new VM.
The installation completes without any errors, tomcat and other services are running, but candlepin is not starting up. I can visit the URL of the server in a browser but it only displays an error informing me that candlepin is not running
Logs below (I have omitted repeat entries), please let me know if you require more information or logs. I’m not sure where to start as I am new to Katello and Foreman.
localhost.22-02.01.log
Feb 01, 2022 10:32:01 AM org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance of class org.candlepin.guice.CandlepinContextListener
com.google.inject.CreationException: Unable to create injector, see the following errors:
1) Error injecting constructor, java.io.IOException: Could not read key
at org.candlepin.pki.CertificateReader.<init>(CertificateReader.java:50)
at org.candlepin.guice.CandlepinModule.bindPki(CandlepinModule.java:303)
while locating org.candlepin.pki.CertificateReader
for the 1st parameter of org.candlepin.pki.impl.JSSPKIUtility.<init>(JSSPKIUtility.java:101)
while locating org.candlepin.pki.impl.JSSPKIUtility
at org.candlepin.guice.CandlepinModule.bindPki(CandlepinModule.java:302)
while locating org.candlepin.pki.PKIUtility
Caused by: java.io.IOException: Could not read key
at org.candlepin.pki.impl.ProviderBasedPrivateKeyReader$PKCS8EncryptedPrivateKeyPemParser.decode(ProviderBasedPrivateKeyReader.java:210)
at org.candlepin.pki.PrivateKeyReader$PrivateKeyPemParser.decode(PrivateKeyReader.java:47)
at org.candlepin.pki.impl.ProviderBasedPrivateKeyReader.readPem(ProviderBasedPrivateKeyReader.java:156)
at org.candlepin.pki.impl.ProviderBasedPrivateKeyReader.read(ProviderBasedPrivateKeyReader.java:82)
at org.candlepin.pki.impl.ProviderBasedPrivateKeyReader.read(ProviderBasedPrivateKeyReader.java:60)
at org.candlepin.pki.CertificateReader.readPrivateKey(CertificateReader.java:78)
at org.candlepin.pki.CertificateReader.<init>(CertificateReader.java:58)
at org.candlepin.pki.CertificateReader$$FastClassByGuice$$d3225fea.newInstance(<generated>)
at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:168)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65)
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:213)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:184)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:111)
at com.google.inject.Guice.createInjector(Guice.java:87)
at org.jboss.resteasy.plugins.guice.GuiceResteasyBootstrapServletContextListener.contextInitialized(GuiceResteasyBootstrapServletContextListener.java:56)
at org.candlepin.guice.CandlepinContextListener.contextInitialized(CandlepinContextListener.java:133)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5127)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5643)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1260)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:2002)
at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: java.security.NoSuchAlgorithmException: 1.2.840.113549.1.5.13 SecretKeyFactory not available
at java.base/javax.crypto.SecretKeyFactory.<init>(SecretKeyFactory.java:122)
at java.base/javax.crypto.SecretKeyFactory.getInstance(SecretKeyFactory.java:168)
at org.candlepin.pki.impl.ProviderBasedPrivateKeyReader$PKCS8EncryptedPrivateKeyPemParser.decode(ProviderBasedPrivateKeyReader.java:203)
... 42 more
2) Error injecting constructor, java.io.IOException: Could not read key
... 33 more
3) Error injecting constructor, java.io.IOException: Could not read key
for the 1st parameter of org.candlepin.model.KeyPairCurator.<init>(KeyPairCurator.java:36)
at org.candlepin.model.KeyPairCurator.class(KeyPairCurator.java:36)
while locating org.candlepin.model.KeyPairCurator
... 50 more
4) Error injecting constructor, java.io.IOException: Could not read key
for the 1st parameter of org.candlepin.model.ProductCertificateCurator.<init>(ProductCertificateCurator.java:53)
at org.candlepin.model.ProductCertificateCurator.class(ProductCertificateCurator.java:45)
while locating org.candlepin.model.ProductCertificateCurator
Caused by: java.io.IOException (same stack trace as error #3)
4 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:554)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:188)
candlepin’s error.log
2022-02-01 10:31:59,604 [thread=localhost-startStop-1] [=, org=, csid=] WARN org.hibernate.id.UUIDHexGenerator - HHH000409: Using org.hibernate.id.UUIDHexGenerator which does not generate IETF RFC 4122 compliant UUID values; consider using org.hibernate.id.UUIDGenerator instead
2022-02-01 10:31:59,659 [thread=localhost-startStop-1] [=, org=, csid=] WARN org.hibernate.mapping.RootClass - HHH000038: Composite-id class does not override equals(): org.candlepin.model.PoolAttribute
2022-02-01 10:31:59,659 [thread=localhost-startStop-1] [=, org=, csid=] WARN org.hibernate.mapping.RootClass - HHH000039: Composite-id class does not override hashCode(): org.candlepin.model.PoolAttribute
2022-02-01 10:32:00,699 [thread=localhost-startStop-1] [=, org=, csid=] WARN org.hibernate.metamodel.internal.MetadataContext - HHH015011: Unable to locate static metamodel field : org.candlepin.model.KeyPair_#privateKey; this may or may not indicate a problem with the static metamodel
2022-02-01 10:32:00,699 [thread=localhost-startStop-1] [=, org=, csid=] WARN org.hibernate.metamodel.internal.MetadataContext - HHH015011: Unable to locate static metamodel field : org.candlepin.model.KeyPair_#publicKey; this may or may not indicate a problem with the static metamodel
health check output:
Running ForemanMaintain::Scenario::FilteredScenario
Check number of fact names in database: e[32me[1m[OK]e[0m
Check whether all services are running: e[32me[1m[OK]e[0m
Check whether all services are running using the ping call: e[31me[1m[FAIL]e[0m
Couldn't connect to the server: undefined method `to_sym' for nil:NilClass
Continue with step [Restart applicable services]?, [y(yes), n(no)]
Restart applicable services:
Stopping the following service(s):
rh-redis5-redis, postgresql, pulpcore-api, pulpcore-content, pulpcore-worker@1.service, pulpcore-worker@2.service, pulpcore-worker@3.service, pulpcore-worker@4.service, pulpcore-worker@5.service, pulpcore-worker@6.service, pulpcore-worker@7.service, pulpcore-worker@8.service, tomcat, dynflow-sidekiq@orchestrator, foreman, httpd, puppetserver, dynflow-sidekiq@worker-1, dynflow-sidekiq@worker-hosts-queue-1, foreman-proxy
/ stopping foreman-proxy
/ stopping dynflow-sidekiq@worker-1
/ stopping dynflow-sidekiq@worker-hosts-queue-1
/ stopping dynflow-sidekiq@orchestrator
/ stopping foreman
/ stopping httpd
/ stopping puppetserver
Warning: Stopping foreman.service, but it can still be activated by:
foreman.socket
/ stopping pulpcore-worker@1.service
/ stopping pulpcore-worker@2.service
/ stopping pulpcore-worker@3.service
/ stopping pulpcore-worker@4.service
/ stopping pulpcore-worker@5.service
/ stopping pulpcore-worker@6.service
/ stopping pulpcore-worker@7.service
/ stopping pulpcore-worker@8.service
/ stopping tomcat
/ stopping postgresql
/ stopping pulpcore-api
/ stopping pulpcore-content
Warning: postgresql.service changed on disk. Run 'systemctl daemon-reload' to reload units.
Warning: Stopping pulpcore-api.service, but it can still be activated by:
pulpcore-api.socket
Warning: Stopping pulpcore-content.service, but it can still be activated by:
pulpcore-content.socket
/ stopping rh-redis5-redis
/ All services stopped
Starting the following service(s):
- starting rh-redis5-redis
- starting postgresql
- starting pulpcore-api
- starting pulpcore-content
- starting pulpcore-worker@1.service
- starting pulpcore-worker@2.service
- starting pulpcore-worker@3.service
- starting pulpcore-worker@4.service
- starting pulpcore-worker@5.service
- starting pulpcore-worker@6.service
- starting pulpcore-worker@7.service
- starting pulpcore-worker@8.service
- starting tomcat
- starting dynflow-sidekiq@orchestrator
- starting foreman
- starting httpd
- starting puppetserver
- starting dynflow-sidekiq@worker-1
- starting dynflow-sidekiq@worker-hosts-queue-1
- starting foreman-proxy
- All services started
\ Checking server response
\ Try 1/5: checking status of hammer ping
\ Waiting 30 seconds before retry.
\ Try 2/5: checking status of hammer ping
\ Try 3/5: checking status of hammer ping
\ Try 4/5: checking status of hammer ping
\ Try 5/5: checking status of hammer ping e[31me[1m[FAIL]e[0m
Server response check failed!
Rerunning the check after fix procedure
Check for paused tasks: e[32me[1m[OK]e[0m
Check to verify no empty CA cert requests exist: e[32me[1m[OK]e[0m
Scenario [ForemanMaintain::Scenario::FilteredScenario] failed.
[server-ping]
Resolve the failed steps and rerun
the command. In case the failures are false positives,
use --whitelist="server-ping"
foreman rake for the given error on the page
2022-02-01T15:09:12 [I|app|71a9921d] Started GET "/" for 10.231.104.125 at 2022-02-01 15:09:12 -0500
2022-02-01T15:09:18 [W|app|71a9921d] 404 Not Found
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/abstract_response.rb:223:in `exception_with_response'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/abstract_response.rb:103:in `return!'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/request.rb:809:in `process_result'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/request.rb:725:in `block in transmit'
71a9921d | /opt/rh/rh-ruby27/root/usr/share/ruby/net/http.rb:933:in `start'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/request.rb:715:in `transmit'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/request.rb:145:in `execute'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/request.rb:52:in `execute'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rest-client-2.0.2/lib/restclient/resource.rb:51:in `get'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:275:in `backend_status'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:95:in `block in ping_candlepin_without_auth'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:144:in `exception_watch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:94:in `ping_candlepin_without_auth'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:245:in `ping_services_for_capsule'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/ping.rb:25:in `ping!'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/services/katello/organization_creator.rb:14:in `create_all_organizations!'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/lib/katello/middleware/organization_created_enforcer.rb:12:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/lib/katello/middleware/event_daemon.rb:10:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/static.rb:126:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-dsl-2.4.0/lib/apipie_dsl/static_dispatcher.rb:67:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/static_dispatcher.rb:66:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/extractor/recorder.rb:137:in `call'
71a9921d | /usr/share/foreman/lib/foreman/middleware/libvirt_connection_cleaner.rb:9:in `call'
71a9921d | /usr/share/foreman/lib/foreman/middleware/telemetry.rb:10:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/apipie-rails-0.5.17/lib/apipie/middleware/checksum_in_headers.rb:27:in `call'
71a9921d | /usr/share/foreman/lib/foreman/middleware/catch_json_parse_errors.rb:9:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/tempfile_reaper.rb:15:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/etag.rb:27:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/conditional_get.rb:27:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/head.rb:12:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/http/content_security_policy.rb:18:in `call'
71a9921d | /usr/share/foreman/lib/foreman/middleware/logging_context_session.rb:22:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:266:in `context'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/session/abstract/id.rb:260:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/cookies.rb:648:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:101:in `run_callbacks'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/actionable_exceptions.rb:18:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/rack/logger.rb:37:in `call_app'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/rack/logger.rb:28:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/sprockets-rails-3.2.1/lib/sprockets/rails/quiet_assets.rb:13:in `call'
71a9921d | /usr/share/foreman/lib/foreman/middleware/logging_context_request.rb:11:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/request_id.rb:27:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/lib/katello/prevent_json_parsing.rb:12:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/method_override.rb:24:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/runtime.rb:22:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache/strategy/local_cache_middleware.rb:29:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/executor.rb:14:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/sendfile.rb:110:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/secure_headers-6.3.0/lib/secure_headers/middleware.rb:11:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/engine.rb:527:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `public_send'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.3.7/lib/rails/railtie.rb:190:in `method_missing'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:74:in `block in call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `each'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/urlmap.rb:58:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/configuration.rb:249:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/request.rb:77:in `block in handle_request'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/thread_pool.rb:340:in `with_force_shutdown'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/request.rb:76:in `handle_request'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/server.rb:447:in `process_client'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/puma-5.5.0/lib/puma/thread_pool.rb:147:in `block in spawn_thread'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/logging-2.3.0/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
2022-02-01T15:09:18 [I|app|71a9921d] Processing by DashboardController#index as HTML
2022-02-01T15:09:18 [I|app|71a9921d] Rendering dashboard/index.html.erb within layouts/application
2022-02-01T15:09:18 [I|app|71a9921d] Rendered dashboard/index.html.erb within layouts/application (Duration: 63.3ms | Allocations: 3607)
2022-02-01T15:09:18 [W|app|71a9921d] Katello::Errors::CandlepinNotRunning
2022-02-01T15:09:18 [I|app|71a9921d] Backtrace for 'Katello::Errors::CandlepinNotRunning' error (ActionView::Template::Error): Katello::Errors::CandlepinNotRunning
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/katello/resources/candlepin.rb:27:in `raise_rest_client_exception'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/katello/http_resource.rb:94:in `rescue in issue_request'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/katello/http_resource.rb:84:in `issue_request'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/katello/http_resource.rb:47:in `block (2 levels) in singleton class'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/lib/katello/resources/candlepin/owner.rb:32:in `find'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/glue/candlepin/owner.rb:20:in `find_owner'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/glue/candlepin/owner.rb:31:in `owner_details'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/glue/candlepin/owner.rb:46:in `content_access_mode'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/glue/candlepin/owner.rb:51:in `block in simple_content_access?'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:332:in `block in fetch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:717:in `block in save_block_result_to_cache'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:686:in `block in instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications.rb:182:in `instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:686:in `instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:716:in `save_block_result_to_cache'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/cache.rb:332:in `fetch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/models/katello/glue/candlepin/owner.rb:50:in `simple_content_access?'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/app/helpers/katello/concerns/dashboard_helper_extensions.rb:35:in `removed_widgets'
71a9921d | /usr/share/foreman/app/helpers/dashboard_helper.rb:32:in `widgets_to_add'
71a9921d | /usr/share/foreman/app/helpers/dashboard_helper.rb:16:in `block in dashboard_actions'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/helpers/capture_helper.rb:45:in `block in capture'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/helpers/capture_helper.rb:209:in `with_output_buffer'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/helpers/capture_helper.rb:45:in `capture'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/helpers/tag_helper.rb:273:in `content_tag'
71a9921d | /usr/share/foreman/app/helpers/dashboard_helper.rb:15:in `dashboard_actions'
71a9921d | /usr/share/foreman/app/views/dashboard/index.html.erb:2:in `_cb796603fa96e8c93a8fff55bf61fdf3'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/base.rb:274:in `_run'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/template.rb:185:in `block in render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/template.rb:385:in `instrument_render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/template.rb:183:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/deface-1.5.3/lib/deface/action_view_extensions.rb:43:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/template_renderer.rb:58:in `block (2 levels) in render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/abstract_renderer.rb:88:in `block in instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications.rb:180:in `block in instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/notifications.rb:180:in `instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/abstract_renderer.rb:87:in `instrument'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/template_renderer.rb:57:in `block in render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/template_renderer.rb:65:in `render_with_layout'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/template_renderer.rb:56:in `render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/template_renderer.rb:13:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/renderer.rb:61:in `render_template_to_object'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/renderer/renderer.rb:29:in `render_to_object'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/rendering.rb:117:in `block in _render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/base.rb:304:in `in_rendering_context'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/rendering.rb:116:in `_render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/streaming.rb:218:in `_render_template'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/rendering.rb:103:in `render_to_body'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rendering.rb:52:in `render_to_body'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/renderers.rb:142:in `render_to_body'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/rendering.rb:25:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rendering.rb:36:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:44:in `block (2 levels) in render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/core_ext/benchmark.rb:14:in `block in ms'
71a9921d | /opt/rh/rh-ruby27/root/usr/share/ruby/benchmark.rb:308:in `realtime'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/core_ext/benchmark.rb:14:in `ms'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:44:in `block in render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:84:in `cleanup_view_runtime'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/controller_runtime.rb:34:in `cleanup_view_runtime'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:43:in `render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/implicit_render.rb:35:in `default_render'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `block in send_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `tap'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/base.rb:195:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rendering.rb:30:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/callbacks.rb:42:in `block in process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:112:in `block in run_callbacks'
71a9921d | /usr/share/foreman/app/controllers/concerns/foreman/controller/timezone.rb:10:in `set_timezone'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
71a9921d | /usr/share/foreman/app/models/concerns/foreman/thread_session.rb:32:in `clear_thread'
71a9921d | /usr/share/foreman/app/controllers/concerns/foreman/controller/topbar_sweeper.rb:12:in `set_topbar_sweeper_controller'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/audited-4.9.0/lib/audited/sweeper.rb:14:in `around'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.3.7/lib/active_support/callbacks.rb:139:in `run_callbacks'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/callbacks.rb:41:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/rescue.rb:22:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/instrumentation.rb:32:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/activerecord-6.0.3.7/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/abstract_controller/base.rb:136:in `process'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionview-6.0.3.7/lib/action_view/rendering.rb:39:in `process'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal.rb:190:in `dispatch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_controller/metal.rb:254:in `dispatch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:33:in `serve'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:49:in `block in serve'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:32:in `each'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/journey/router.rb:32:in `serve'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/actionpack-6.0.3.7/lib/action_dispatch/routing/route_set.rb:834:in `call'
71a9921d | /opt/theforeman/tfm/root/usr/share/gems/gems/katello-4.3.0/lib/katello/middleware/organization_created_enforcer.rb:18:in `call'
2022-02-01T15:09:18 [I|app|71a9921d] Rendering common/500.html.erb within layouts/application
2022-02-01T15:09:18 [I|app|71a9921d] Rendered common/500.html.erb within layouts/application (Duration: 4.3ms | Allocations: 1064)
2022-02-01T15:09:18 [I|app|71a9921d] Rendered layouts/_application_content.html.erb (Duration: 0.9ms | Allocations: 401)
2022-02-01T15:09:18 [I|app|71a9921d] Rendering layouts/base.html.erb
2022-02-01T15:09:18 [I|app|71a9921d] Rendered layouts/base.html.erb (Duration: 4.9ms | Allocations: 2548)
2022-02-01T15:09:18 [I|app|71a9921d] Completed 500 Internal Server Error in 140ms (Views: 13.4ms | ActiveRecord: 8.0ms | Allocations: 37924)
Foreman version: 3.1.1
Plugins:
- foreman-tasks 5.2.0
- foreman_remote_execution 5.0.1
- katello 4.3.0
