Foreman is not installable on CentOS 8 Stream, because if dnf-modular filtering, so therefore it is not possible to install with puppet the latest stable package version of foreman and foreman-proxy.
Error: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-postgresql' returned 1: Error:
Problem: package foreman-postgresql-3.2.0-0.4.rc2.20220303183223git6f49270.el8.noarch requires foreman = 3.2.0-0.4.rc2.20220303183223git6f49270.el8, but none of the providers can be installed
- package foreman-3.2.0-0.4.rc2.20220303183223git6f49270.el8.noarch requires rubygem(will_paginate) >= 3.1.7, but none of the providers can be installed
- package foreman-3.2.0-0.4.rc2.20220303183223git6f49270.el8.noarch requires rubygem(will_paginate) < 4, but none of the providers can be installed
- cannot install the best candidate for the job
- package rubygem-will_paginate-3.1.7-4.el8.noarch is filtered out by modular filtering
Error: /Stage[main]/Foreman::Install/Package[foreman-postgresql]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-postgresql' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-service' returned 1: Error:
Problem: package foreman-service-3.2.0-0.4.rc2.20220303183223git6f49270.el8.noarch requires rubygem(puma-status), but none of the providers can be installed
- package rubygem-puma-status-1.3-1.el8.noarch is filtered out by modular filtering
Error: /Stage[main]/Foreman::Install/Package[foreman-service]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-service' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y list puppet-agent-oauth' returned 1: Error: No matching Packages to list
Error: /Stage[main]/Foreman::Providers/Package[puppet-agent-oauth]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y list puppet-agent-oauth' returned 1: Error: No matching Packages to list
Notice: /Stage[main]/Foreman::Providers/Anchor[foreman::providers::oauth]: Dependency Package[puppet-agent-oauth] has failures: true
Warning: /Stage[main]/Foreman::Providers/Anchor[foreman::providers::oauth]: Skipping because of failed dependencies
Notice: /Stage[main]/Foreman::Config/File[/usr/share/foreman]: Dependency Package[foreman-postgresql] has failures: true
Notice: /Stage[main]/Foreman::Config/File[/usr/share/foreman]: Dependency Package[foreman-service] has failures: true
Warning: /Stage[main]/Foreman::Config/File[/usr/share/foreman]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Group[foreman]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/File[/etc/foreman/database.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/User[foreman]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Selboolean[httpd_can_network_connect]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Selboolean[allow_httpd_mod_auth_pam]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Selboolean[httpd_dbus_sssd]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/File[/etc/pam.d/foreman]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Exec[ipa-getkeytab]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/File[/etc/httpd/conf/http.keytab]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Augeas[sssd-ifp-extra-attributes]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Service[sssd]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Compute::Libvirt/Package[foreman-libvirt]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Compute::Openstack/Package[foreman-openstack]: Skipping because of failed dependencies
Error: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-proxy' returned 1: Error:
Problem: package foreman-proxy-3.2.0-0.1.rc2.20220303182109git71c07db.el8.noarch requires rubygem(sinatra), but none of the providers can be installed
- package rubygem-sinatra-2.1.0-2.el8.noarch is filtered out by modular filtering
Error: /Stage[main]/Foreman_proxy::Install/Package[foreman-proxy]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install foreman-proxy' returned 1: Error:
Notice: /Stage[main]/Foreman_proxy::Config/User[foreman-proxy]: Dependency Package[foreman-proxy] has failures: true
Warning: /Stage[main]/Foreman_proxy::Config/User[foreman-proxy]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/pxelinux.cfg]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/grub]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/grub2]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/boot]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/ztp.cfg]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/poap.cfg]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/grub2/grub.cfg]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/chain.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/ldlinux.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/libcom32.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/libutil.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/mboot.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/menu.c32]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/memdisk]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp/File[/var/lib/tftpboot/pxelinux.0]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp::Netboot/File[/var/lib/tftpboot/grub2/boot]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp::Netboot/File[/var/lib/tftpboot/grub2/grubx64.efi]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp::Netboot/File[/var/lib/tftpboot/grub2/shimx64.efi]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Tftp::Netboot/File[/var/lib/tftpboot/grub2/shim.efi]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/File[/etc/sudoers.d/foreman-proxy]: Skipping because of failed dependencies
Error: Systemd start for sysfsutils failed!
journalctl log for sysfsutils:
-- Logs begin at Tue 2022-04-12 09:51:39 CEST, end at Tue 2022-04-12 13:57:32 CEST. --
-- No entries --
Error: /Stage[main]/Sysfs/Service[sysfsutils]/ensure: change from 'stopped' to 'running' failed: Systemd start for sysfsutils failed!
-- No entries --
Warning: /Stage[main]/Foreman::Config/Concat[/etc/foreman/settings.yaml]/Concat_file[/etc/foreman/settings.yaml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Concat[/etc/foreman/settings.yaml]/File[/etc/foreman/settings.yaml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Systemd::Dropin_file[foreman-service]/File[/etc/systemd/system/foreman.service.d]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Systemd::Dropin_file[foreman-service]/File[/etc/systemd/system/foreman.service.d/installer.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Systemd::Dropin_file[foreman-socket]/File[/etc/systemd/system/foreman.socket.d]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Systemd::Dropin_file[foreman-socket]/File[/etc/systemd/system/foreman.socket.d/installer.conf]: Skipping because of failed dependencies
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_bootdisk' returned 1: Error:
Problem: package rubygem-foreman_bootdisk-19.0.3-1.fm3_2.el8.noarch requires foreman >= 3.1, but none of the providers can be installed
- package foreman-3.2.0-0.3.rc1.20220214174122git7ccb4f6.el8.noarch requires rubygem(will_paginate) >= 3.1.7, but none of the providers can be installed
- package foreman-3.2.0-0.3.rc1.20220214174122git7ccb4f6.el8.noarch requires rubygem(will_paginate) < 4, but none of the providers can be installed
- conflicting requests
- package foreman-3.2.0-1.el8.noarch is filtered out by modular filtering
Error: /Stage[main]/Foreman::Plugin::Bootdisk/Foreman::Plugin[bootdisk]/Package[rubygem-foreman_bootdisk]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_bootdisk' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_dhcp_browser' returned 1: Error:
Problem: package rubygem-foreman_dhcp_browser-0.0.8-5.fm2_5.el8.noarch requires rubygem(deface), but none of the providers can be installed
- package rubygem-deface-1.5.3-3.el8.noarch requires rubygem(rails) >= 4.1, but none of the providers can be installed
- package rubygem-rails-6.0.3.7-1.el8.noarch is filtered out by modular filtering
Error: /Stage[main]/Foreman::Plugin::Dhcp_browser/Foreman::Plugin[dhcp_browser]/Package[rubygem-foreman_dhcp_browser]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_dhcp_browser' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_discovery' returned 1: Error:
Problem: package rubygem-foreman_discovery-20.0.1-1.fm3_2.el8.noarch requires foreman >= 3.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Discovery/Foreman::Plugin[discovery]/Package[rubygem-foreman_discovery]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_discovery' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_expire_hosts' returned 1: Error:
Problem: package rubygem-foreman_expire_hosts-7.0.4-2.fm2_5.el8.noarch requires rubygem(deface), but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Expire_hosts/Foreman::Plugin[expire_hosts]/Package[rubygem-foreman_expire_hosts]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_expire_hosts' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_hooks' returned 1: Error:
Problem: package rubygem-foreman_hooks-0.3.17-2.fm2_5.el8.noarch requires foreman >= 1.4.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Hooks/Foreman::Plugin[hooks]/Package[rubygem-foreman_hooks]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_hooks' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_host_extra_validator' returned 1: Error:
Problem: package rubygem-foreman_host_extra_validator-0.1.0-4.fm2_5.el8.noarch requires foreman >= 1.24.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Host_extra_validator/Foreman::Plugin[host_extra_validator]/Package[rubygem-foreman_host_extra_validator]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_host_extra_validator' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_memcache' returned 1: Error:
Problem: package rubygem-foreman_memcache-0.1.1-4.fm2_5.el8.noarch requires foreman >= 1.16.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Memcache/Foreman::Plugin[memcache]/Package[rubygem-foreman_memcache]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_memcache' returned 1: Error:
Notice: /Stage[main]/Foreman::Plugin::Memcache/Foreman::Plugin[memcache]/File[/etc/foreman/plugins/foreman_memcache.yaml]: Dependency Package[rubygem-foreman_memcache] has failures: true
Warning: /Stage[main]/Foreman::Plugin::Memcache/Foreman::Plugin[memcache]/File[/etc/foreman/plugins/foreman_memcache.yaml]: Skipping because of failed dependencies
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_monitoring' returned 1: Error:
Problem: package rubygem-foreman_monitoring-2.1.0-2.fm2_5.el8.noarch requires rubygem(deface) < 2.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Monitoring/Foreman::Plugin[monitoring]/Package[rubygem-foreman_monitoring]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_monitoring' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_openscap' returned 1: Error:
Problem: package rubygem-foreman_openscap-5.2.1-1.fm3_2.el8.noarch requires foreman >= 1.24.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Openscap/Foreman::Plugin[openscap]/Package[rubygem-foreman_openscap]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_openscap' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_puppet' returned 1: Error:
Problem: package rubygem-foreman_puppet-3.0.5-1.fm3_2.el8.noarch requires foreman >= 3.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Puppet/Foreman::Plugin[puppet]/Package[rubygem-foreman_puppet]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_puppet' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-puppetdb_foreman' returned 1: Error:
Problem: package rubygem-puppetdb_foreman-5.0.0-3.fm2_5.el8.noarch requires foreman >= 1.17.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Puppetdb/Foreman::Plugin[puppetdb]/Package[rubygem-puppetdb_foreman]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-puppetdb_foreman' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman-tasks' returned 1: Error:
Problem: package rubygem-foreman-tasks-6.0.1-1.fm3_2.el8.noarch requires rubygem(sinatra), but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Tasks/Foreman::Plugin[tasks]/Package[rubygem-foreman-tasks]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman-tasks' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_templates' returned 1: Error:
Problem: package rubygem-foreman_templates-9.1.0-1.fm2_6.el8.noarch requires foreman >= 1.24.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Templates/Foreman::Plugin[templates]/Package[rubygem-foreman_templates]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_templates' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_host_reports' returned 1: Error:
Problem: package rubygem-foreman_host_reports-1.0.2-1.fm3_2.el8.noarch requires foreman >= 3.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Host_reports/Foreman::Plugin[host_reports]/Package[rubygem-foreman_host_reports]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_host_reports' returned 1: Error:
Error: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_column_view' returned 1: Error:
Problem: package rubygem-foreman_column_view-0.4.0-5.fm2_5.el8.noarch requires rubygem(deface) < 2.0, but none of the providers can be installed
Error: /Stage[main]/Foreman::Plugin::Column_view/Foreman::Plugin[column_view]/Package[rubygem-foreman_column_view]/ensure: change from 'purged' to 'present' failed: Execution of '/bin/dnf -d 0 -e 1 -y install rubygem-foreman_column_view' returned 1: Error:
Notice: /Stage[main]/Foreman::Plugin::Column_view/Foreman::Plugin[column_view]/File[/etc/foreman/plugins/foreman_column_view.yaml]: Dependency Package[rubygem-foreman_column_view] has failures: true
Warning: /Stage[main]/Foreman::Plugin::Column_view/Foreman::Plugin[column_view]/File[/etc/foreman/plugins/foreman_column_view.yaml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Settings_file[settings]/File[/etc/foreman-proxy/settings.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Discovery/Foreman_proxy::Remote_file[/var/lib/tftpboot/boot/fdi-image-latest.tar]/Exec[mkdir -p /var/lib/tftpboot/boot]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Discovery/Foreman_proxy::Remote_file[/var/lib/tftpboot/boot/fdi-image-latest.tar]/File[/var/lib/tftpboot/boot/fdi-image-latest.tar]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Discovery/Exec[untar fdi-image-latest.tar]: Skipping because of failed dependencies
Notice: /Stage[main]/Profile::Postgresql::Repo/Yum::Gpgkey[/etc/pki/rpm-gpg/RPM-GPG-KEY-PGDG-13]/Exec[rpm-import-/etc/pki/rpm-gpg/RPM-GPG-KEY-PGDG-13]/returns: executed successfully (corrective)
Warning: /Stage[main]/Foreman::Config/Foreman::Settings_fragment[header.yaml]/Concat::Fragment[foreman_settings+01-header.yaml]/Concat_fragment[foreman_settings+01-header.yaml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Foreman::Settings_fragment[reverse-proxy-headers.yaml]/Concat::Fragment[foreman_settings+03-reverse-proxy-headers.yaml]/Concat_fragment[foreman_settings+03-reverse-proxy-headers.yaml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/File[/etc/httpd/conf.d/05-foreman.d]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/File[/etc/httpd/conf.d/05-foreman-ssl.d]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat[05-foreman.conf]/Concat_file[05-foreman.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat[05-foreman.conf]/File[/etc/httpd/conf.d/05-foreman.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-apache-header]/Concat_fragment[foreman-apache-header]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-docroot]/Concat_fragment[foreman-docroot]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-directories]/Concat_fragment[foreman-directories]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-additional_includes]/Concat_fragment[foreman-additional_includes]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-logging]/Concat_fragment[foreman-logging]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-serversignature]/Concat_fragment[foreman-serversignature]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-access_log]/Concat_fragment[foreman-access_log]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-requestheader]/Concat_fragment[foreman-requestheader]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-proxy]/Concat_fragment[foreman-proxy]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-rewrite]/Concat_fragment[foreman-rewrite]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-serveralias]/Concat_fragment[foreman-serveralias]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-custom_fragment]/Concat_fragment[foreman-custom_fragment]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-charsets]/Concat_fragment[foreman-charsets]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Concat::Fragment[foreman-file_footer]/Concat_fragment[foreman-file_footer]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat[05-foreman-ssl.conf]/Concat_file[05-foreman-ssl.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat[05-foreman-ssl.conf]/File[/etc/httpd/conf.d/05-foreman-ssl.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-apache-header]/Concat_fragment[foreman-ssl-apache-header]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-docroot]/Concat_fragment[foreman-ssl-docroot]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-directories]/Concat_fragment[foreman-ssl-directories]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-additional_includes]/Concat_fragment[foreman-ssl-additional_includes]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-logging]/Concat_fragment[foreman-ssl-logging]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-serversignature]/Concat_fragment[foreman-ssl-serversignature]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-access_log]/Concat_fragment[foreman-ssl-access_log]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-requestheader]/Concat_fragment[foreman-ssl-requestheader]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-sslproxy]/Concat_fragment[foreman-ssl-sslproxy]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-proxy]/Concat_fragment[foreman-ssl-proxy]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-rewrite]/Concat_fragment[foreman-ssl-rewrite]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-serveralias]/Concat_fragment[foreman-ssl-serveralias]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-ssl]/Concat_fragment[foreman-ssl-ssl]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-custom_fragment]/Concat_fragment[foreman-ssl-custom_fragment]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-charsets]/Concat_fragment[foreman-ssl-charsets]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman-ssl]/Concat::Fragment[foreman-ssl-file_footer]/Concat_fragment[foreman-ssl-file_footer]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Settings_fragment[authorize_login_delegation.yaml]/Concat::Fragment[foreman_settings+02-authorize_login_delegation.yaml]/Concat_fragment[foreman_settings+02-authorize_login_delegation.yaml]: Skipping because of failed dependencies
Notice: /Stage[main]/Profile::Foreman::Plugin::Openscap/Foreman::Rake[foreman_openscap:bulk_upload:default]/Exec[foreman-rake-foreman_openscap:bulk_upload:default]: Dependency Package[rubygem-foreman_openscap] has failures: true
Warning: /Stage[main]/Profile::Foreman::Plugin::Openscap/Foreman::Rake[foreman_openscap:bulk_upload:default]/Exec[foreman-rake-foreman_openscap:bulk_upload:default]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Bmc/Foreman_proxy::Module[bmc]/Foreman_proxy::Feature[BMC]/Datacat_fragment[foreman_proxy::enabled_features::BMC]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Bmc/Foreman_proxy::Module[bmc]/Foreman_proxy::Settings_file[bmc]/File[/etc/foreman-proxy/settings.d/bmc.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Dhcp/Foreman_proxy::Module[dhcp]/Foreman_proxy::Settings_file[dhcp]/File[/etc/foreman-proxy/settings.d/dhcp.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[dhcp_isc]/Foreman_proxy::Settings_file[dhcp_isc]/File[/etc/foreman-proxy/settings.d/dhcp_isc.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[dhcp_libvirt]/Foreman_proxy::Settings_file[dhcp_libvirt]/File[/etc/foreman-proxy/settings.d/dhcp_libvirt.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Dns/Foreman_proxy::Module[dns]/Foreman_proxy::Settings_file[dns]/File[/etc/foreman-proxy/settings.d/dns.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[dns_nsupdate]/Foreman_proxy::Settings_file[dns_nsupdate]/File[/etc/foreman-proxy/settings.d/dns_nsupdate.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[dns_nsupdate_gss]/Foreman_proxy::Settings_file[dns_nsupdate_gss]/File[/etc/foreman-proxy/settings.d/dns_nsupdate_gss.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[dns_libvirt]/Foreman_proxy::Settings_file[dns_libvirt]/File[/etc/foreman-proxy/settings.d/dns_libvirt.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Httpboot/Foreman_proxy::Module[httpboot]/Foreman_proxy::Settings_file[httpboot]/File[/etc/foreman-proxy/settings.d/httpboot.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Puppet/Foreman_proxy::Module[puppet]/Foreman_proxy::Feature[Puppet]/Datacat_fragment[foreman_proxy::enabled_features::Puppet]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Puppet/Foreman_proxy::Module[puppet]/Foreman_proxy::Settings_file[puppet]/File[/etc/foreman-proxy/settings.d/puppet.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_puppet_api]/Foreman_proxy::Settings_file[puppet_proxy_puppet_api]/File[/etc/foreman-proxy/settings.d/puppet_proxy_puppet_api.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_legacy]/Foreman_proxy::Settings_file[puppet_proxy_legacy]/File[/etc/foreman-proxy/settings.d/puppet_proxy_legacy.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_puppetrun]/Foreman_proxy::Settings_file[puppet_proxy_puppetrun]/File[/etc/foreman-proxy/settings.d/puppet_proxy_puppetrun.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_customrun]/Foreman_proxy::Settings_file[puppet_proxy_customrun]/File[/etc/foreman-proxy/settings.d/puppet_proxy_customrun.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_mcollective]/Foreman_proxy::Settings_file[puppet_proxy_mcollective]/File[/etc/foreman-proxy/settings.d/puppet_proxy_mcollective.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_salt]/Foreman_proxy::Settings_file[puppet_proxy_salt]/File[/etc/foreman-proxy/settings.d/puppet_proxy_salt.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppet_proxy_ssh]/Foreman_proxy::Settings_file[puppet_proxy_ssh]/File[/etc/foreman-proxy/settings.d/puppet_proxy_ssh.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Puppetca/Foreman_proxy::Module[puppetca]/Foreman_proxy::Feature[Puppet CA]/Datacat_fragment[foreman_proxy::enabled_features::Puppet CA]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Puppetca/Foreman_proxy::Module[puppetca]/Foreman_proxy::Settings_file[puppetca]/File[/etc/foreman-proxy/settings.d/puppetca.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppetca_hostname_whitelisting]/Foreman_proxy::Settings_file[puppetca_hostname_whitelisting]/File[/etc/foreman-proxy/settings.d/puppetca_hostname_whitelisting.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppetca_token_whitelisting]/Foreman_proxy::Settings_file[puppetca_token_whitelisting]/File[/etc/foreman-proxy/settings.d/puppetca_token_whitelisting.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppetca_http_api]/Foreman_proxy::Settings_file[puppetca_http_api]/File[/etc/foreman-proxy/settings.d/puppetca_http_api.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[puppetca_puppet_cert]/Foreman_proxy::Settings_file[puppetca_puppet_cert]/File[/etc/foreman-proxy/settings.d/puppetca_puppet_cert.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Realm/Foreman_proxy::Module[realm]/Foreman_proxy::Feature[Realm]/Datacat_fragment[foreman_proxy::enabled_features::Realm]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Realm/Foreman_proxy::Module[realm]/Foreman_proxy::Settings_file[realm]/File[/etc/foreman-proxy/settings.d/realm.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Config/Foreman_proxy::Provider[realm_freeipa]/Foreman_proxy::Settings_file[realm_freeipa]/File[/etc/foreman-proxy/settings.d/realm_freeipa.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Tftp/Foreman_proxy::Module[tftp]/Foreman_proxy::Feature[TFTP]/Datacat_fragment[foreman_proxy::enabled_features::TFTP]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Tftp/Foreman_proxy::Module[tftp]/Foreman_proxy::Settings_file[tftp]/File[/etc/foreman-proxy/settings.d/tftp.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Templates/Foreman_proxy::Module[templates]/Foreman_proxy::Feature[Templates]/Datacat_fragment[foreman_proxy::enabled_features::Templates]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Templates/Foreman_proxy::Module[templates]/Foreman_proxy::Settings_file[templates]/File[/etc/foreman-proxy/settings.d/templates.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Logs/Foreman_proxy::Module[logs]/Foreman_proxy::Feature[Logs]/Datacat_fragment[foreman_proxy::enabled_features::Logs]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Logs/Foreman_proxy::Module[logs]/Foreman_proxy::Settings_file[logs]/File[/etc/foreman-proxy/settings.d/logs.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Registration/Foreman_proxy::Module[registration]/Foreman_proxy::Feature[Registration]/Datacat_fragment[foreman_proxy::enabled_features::Registration]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Module::Registration/Foreman_proxy::Module[registration]/Foreman_proxy::Settings_file[registration]/File[/etc/foreman-proxy/settings.d/registration.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Discovery/Foreman_proxy::Plugin[discovery]/Package[rubygem-smart_proxy_discovery]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Monitoring/Foreman_proxy::Plugin::Module[monitoring]/Foreman_proxy::Plugin[monitoring]/Package[rubygem-smart_proxy_monitoring]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Openscap/Foreman_proxy::Plugin::Module[openscap]/Foreman_proxy::Plugin[openscap]/Package[rubygem-smart_proxy_openscap]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Reports/Foreman_proxy::Plugin::Module[reports]/Foreman_proxy::Plugin[reports]/Package[rubygem-smart_proxy_reports]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config::Apache/Apache::Vhost[foreman]/Apache::Listen[80]/Concat::Fragment[Listen 80]/Concat_fragment[Listen 80]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[intercept_form_submit]/File[/etc/httpd/conf.d/05-foreman.d/intercept_form_submit.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[intercept_form_submit]/File[/etc/httpd/conf.d/05-foreman-ssl.d/intercept_form_submit.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[lookup_identity]/File[/etc/httpd/conf.d/05-foreman.d/lookup_identity.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[lookup_identity]/File[/etc/httpd/conf.d/05-foreman-ssl.d/lookup_identity.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[auth_gssapi]/File[/etc/httpd/conf.d/05-foreman.d/auth_gssapi.conf]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Config/Foreman::Config::Apache::Fragment[auth_gssapi]/File[/etc/httpd/conf.d/05-foreman-ssl.d/auth_gssapi.conf]: Skipping because of failed dependencies
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_bootdisk] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_dhcp_browser] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_discovery] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_expire_hosts] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_hooks] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_host_extra_validator] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_monitoring] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_puppet] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-puppetdb_foreman] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman-tasks] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_templates] has failures: true
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Dependency Package[rubygem-foreman_host_reports] has failures: true
Warning: /Stage[main]/Foreman::Database/Foreman::Rake[db:migrate]/Exec[foreman-rake-db:migrate]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Monitoring/Foreman_proxy::Plugin::Module[monitoring]/Foreman_proxy::Module[monitoring]/Foreman_proxy::Feature[Monitoring]/Datacat_fragment[foreman_proxy::enabled_features::Monitoring]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Monitoring/Foreman_proxy::Plugin::Module[monitoring]/Foreman_proxy::Module[monitoring]/Foreman_proxy::Settings_file[monitoring]/File[/etc/foreman-proxy/settings.d/monitoring.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Openscap/Foreman_proxy::Plugin::Module[openscap]/Foreman_proxy::Module[openscap]/Foreman_proxy::Feature[Openscap]/Datacat_fragment[foreman_proxy::enabled_features::Openscap]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Openscap/Foreman_proxy::Plugin::Module[openscap]/Foreman_proxy::Module[openscap]/Foreman_proxy::Settings_file[openscap]/File[/etc/foreman-proxy/settings.d/openscap.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Reports/Foreman_proxy::Plugin::Module[reports]/Foreman_proxy::Module[reports]/Foreman_proxy::Feature[Reports]/Datacat_fragment[foreman_proxy::enabled_features::Reports]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Plugin::Reports/Foreman_proxy::Plugin::Module[reports]/Foreman_proxy::Module[reports]/Foreman_proxy::Settings_file[reports]/File[/etc/foreman-proxy/settings.d/reports.yml]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Service/Service[foreman-proxy]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman_proxy::Register/Datacat_collector[foreman_proxy::enabled_features]: Skipping because of failed dependencies
Notice: /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Dependency Foreman_config_entry[db_pending_seed] has failures: true
Warning: /Stage[main]/Foreman::Database/Foreman::Rake[db:seed]/Exec[foreman-rake-db:seed]: Skipping because of failed dependencies
Warning: /Stage[main]/Apache::Service/Service[httpd]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Service/Service[foreman.socket]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman::Service/Service[foreman]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman/Anchor[foreman::service]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman/Foreman::Rake[apipie:cache:index]/Exec[foreman-rake-apipie:cache:index]: Skipping because of failed dependencies
Warning: /Stage[main]/Foreman/Foreman::Rake[apipie_dsl:cache]/Exec[foreman-rake-apipie_dsl:cache]: Skipping because of failed dependencies
Notice: /Stage[main]/Puppet::Agent::Service::Daemon/Service[puppet]: Dependency Foreman_smartproxy[pp-tfm-test-01.ict.dev.ttw] has failures: true
Warning: /Stage[main]/Puppet::Agent::Service::Daemon/Service[puppet]: Skipping because of failed dependencies
Warning: /Stage[main]/Puppet::Agent::Service::Cron/Cron[puppet]: Skipping because of failed dependencies
Warning: /Stage[main]/Puppet::Agent::Service::Systemd/Systemd::Timer[puppet-run.timer]/Systemd::Unit_file[puppet-run.timer]/Service[puppet-run.timer]: Skipping because of failed dependencies
Warning: /Stage[main]/Puppet::Agent::Service::Systemd/Systemd::Timer[puppet-run.timer]/Systemd::Unit_file[puppet-run.timer]/File[/etc/systemd/system/puppet-run.timer]: Skipping because of failed dependencies
Info: Stage[main]: Unscheduling all events on Stage[main]
Error: Could not find a suitable provider for foreman_config_entry
Error: Could not find a suitable provider for foreman_host
Error: Could not find a suitable provider for foreman_smartproxy
Error: Could not find a suitable provider for foreman_instance_host
Error: Could not find a suitable provider for foreman_smartproxy_host
→ installable foreman-stable-version
→ currently not installable on the system
- CentOS Stream release 8
