Problem: During foreman start, it is trying to load a file and failling:
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/application.rb:363:in `initialize!'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `public_send'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/railtie.rb:190:in `method_missing'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /usr/share/foreman/config/environment.rb:5:in `<top (required)>'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/rh/rh-ruby27/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:83:in `require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/polyglot-0.3.5/lib/polyglot.rb:65:in `require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/dependencies.rb:324:in `block in require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/dependencies.rb:291:in `load_dependency'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/activesupport-6.0.4.7/lib/active_support/dependencies.rb:324:in `require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from config.ru:5:in `block in <main>'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:116:in `eval'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:116:in `new_from_string'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:105:in `load_file'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/builder.rb:66:in `parse_file'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:349:in `build_app_and_options_from_config'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:249:in `app'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:422:in `wrapped_app'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:312:in `block in start'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:379:in `handle_profiling'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/rack-2.2.3/lib/rack/server.rb:311:in `start'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/commands/server/server_command.rb:39:in `start'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/commands/server/server_command.rb:147:in `block in perform'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/commands/server/server_command.rb:138:in `tap'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/commands/server/server_command.rb:138:in `perform'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/thor-1.0.1/lib/thor/command.rb:27:in `run'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/thor-1.0.1/lib/thor/invocation.rb:127:in `invoke_command'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/thor-1.0.1/lib/thor.rb:392:in `dispatch'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/command/base.rb:69:in `perform'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/command.rb:46:in `invoke'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/theforeman/tfm/root/usr/share/gems/gems/railties-6.0.4.7/lib/rails/commands.rb:18:in `<top (required)>'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/rh/rh-ruby27/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:158:in `require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/rh/rh-ruby27/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:158:in `rescue in require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /opt/rh/rh-ruby27/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:147:in `require'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: from /usr/share/foreman/bin/rails:9:in `<main>'
Feb 06 16:27:00 bdapmgmtprd01.mgmt foreman[5605]: /opt/rh/rh-**ruby27/root/usr/share/rubygems/rubygems/core_ext/kernel_require.rb:83:in `require': cannot load such file -- rails/commands (LoadError)**
Feb 06 16:27:00 bdapmgmtprd01.mgmt systemd[1]: foreman.service: main process exited, code=exited, status=1/FAILURE
Feb 06 16:27:00 bdapmgmtprd01.mgmt systemd[1]: Failed to start Foreman.
Expected outcome: Foreman starts
Foreman and Proxy versions: Foreman 3.3 and proxy 3.3
** OS:** RHEL 7.9
** Gems installed **
[root@bdapmgmtprd01 share]# scl enable tfm – gem list --all
*** LOCAL GEMS ***
actioncable (6.0.4.7)
actionmailbox (6.0.4.7)
actionmailer (6.0.4.7)
actionpack (6.0.4.7)
actiontext (6.0.4.7)
actionview (6.0.4.7)
activejob (6.0.4.7)
activemodel (6.0.4.7)
activerecord (6.0.4.7)
activerecord-import (1.1.0)
activerecord-session_store (2.0.0)
activestorage (6.0.4.7)
activesupport (6.0.4.7)
addressable (2.8.0)
algebrick (0.7.3)
amazing_print (1.1.0)
ancestry (3.0.7)
anemone (0.7.2)
angular-rails-templates (1.1.0)
ansi (1.5.0)
apipie-bindings (0.5.0)
apipie-dsl (2.4.0)
apipie-params (0.0.5)
apipie-rails (0.5.17)
audited (4.9.0)
awesome_print (1.8.0)
bcrypt (3.1.12)
bigdecimal (2.0.0)
builder (3.2.4)
bundler (2.2.24)
bundler_ext (0.4.1)
clamp (1.1.2)
coffee-rails (5.0.0)
coffee-script (2.4.1)
coffee-script-source (1.12.2)
colorize (0.8.1)
concurrent-ruby (1.1.6)
concurrent-ruby-edge (0.6.0)
connection_pool (2.2.2)
crass (1.0.6)
css_parser (1.4.7)
daemons (1.2.3)
deacon (1.0.0)
deep_cloneable (3.0.0)
deface (1.5.3)
did_you_mean (1.4.0)
domain_name (0.5.20160310)
dynflow (1.6.4)
erubi (1.9.0)
excon (0.76.0)
execjs (2.7.0)
facter (4.0.51)
faraday (0.17.3)
fast_gettext (1.4.1)
ffi (1.12.2)
fog-aws (3.6.5)
fog-core (2.1.0)
fog-json (1.2.0)
fog-libvirt (0.9.0)
fog-ovirt (2.0.1)
fog-xml (0.1.2)
foreman-tasks (6.0.2)
foreman_openscap (5.2.2)
foreman_puppet (4.0.1)
foreman_remote_execution (7.1.0)
foreman_virt_who_configure (0.5.8)
formatador (0.2.1)
friendly_id (5.3.0)
fx (0.5.0)
get_process_mem (0.2.7)
gettext_i18n_rails (1.8.0)
gitlab-sidekiq-fetcher (0.6.0)
globalid (0.4.2)
graphql (1.8.14)
graphql-batch (0.3.10)
gssapi (1.2.0)
hammer_cli (3.3.0)
hammer_cli_foreman (3.3.0)
hammer_cli_foreman_openscap (0.1.13)
hammer_cli_foreman_puppet (0.0.6)
hammer_cli_foreman_remote_execution (0.2.2)
hammer_cli_foreman_tasks (0.0.17)
hammer_cli_foreman_virt_who_configure (0.0.9)
hammer_cli_katello (1.5.2)
hashie (3.6.0)
highline (2.0.3)
hocon (1.3.1)
http-cookie (1.0.2)
i18n (1.8.2)
io-console (0.5.6)
ipaddress (0.8.3)
irb (1.2.6)
json (2.3.0)
jwt (2.2.2)
kafo (6.4.0)
kafo_parsers (1.2.1)
kafo_wizards (0.0.2)
katello (4.5.0)
ldap_fluff (0.6.0)
little-plugger (1.1.4)
locale (2.0.9)
logging (2.3.1, 2.3.0)
loofah (2.4.0)
mail (2.7.1)
marcel (1.0.1)
method_source (0.9.2)
mime-types (3.3.1)
mime-types-data (3.2018.0812)
mini_mime (1.0.2)
mini_portile2 (2.5.1)
minitest (5.17.0, 5.13.0)
msgpack (1.3.3)
multi_json (1.15.0, 1.14.1)
multipart-post (2.0.0)
mustermann (1.1.1)
net-ldap (0.17.0)
net-ping (2.0.1)
net-scp (1.2.1)
net-ssh (7.0.1, 4.2.0)
net_http_unix (0.2.2)
netrc (0.11.0)
nio4r (2.5.4)
nokogiri (1.11.3)
oauth (0.5.4)
openscap (0.4.9)
openscap_parser (1.0.2)
openssl (2.1.3)
ovirt-engine-sdk (4.4.0)
parallel (1.19.1)
parse-cron (0.1.4)
pg (1.1.4)
polyglot (0.3.5)
powerbar (2.0.1)
promise.rb (0.7.4)
psych (3.1.0)
public_suffix (3.0.3)
pulp_ansible_client (0.13.1)
pulp_certguard_client (1.5.0)
pulp_container_client (2.10.3)
pulp_deb_client (2.18.0)
pulp_file_client (1.10.0)
pulp_ostree_client (2.0.0a1)
pulp_python_client (3.6.0)
pulp_rpm_client (3.17.4)
pulpcore_client (3.18.5)
puma (5.6.2)
puma-status (1.3)
puppetdb_foreman (5.0.0)
qpid_messaging (1.38.0)
qpid_proton (0.37.0)
rabl (0.14.3)
racc (1.5.2, 1.4.16)
rack (2.2.3)
rack-cors (1.0.2)
rack-jsonp (1.3.1)
rack-protection (2.1.0)
rack-test (1.1.0)
rails (6.0.4.7)
rails-dom-testing (2.0.3)
rails-html-sanitizer (1.3.0)
rails-i18n (6.0.0)
railties (6.0.4.7)
rainbow (2.2.2)
rake (13.0.6, 13.0.1)
rake-compiler (1.0.7)
rb-inotify (0.9.7)
rdoc (6.2.1.1)
redfish_client (0.5.2)
redis (4.5.1)
responders (3.0.0)
rest-client (2.0.2)
rkerberos (0.1.5)
roadie (3.4.0)
roadie-rails (2.1.1)
robotex (1.0.0)
rsec (0.4.3)
ruby-libvirt (0.7.1)
ruby2_keywords (0.0.4)
ruby2ruby (2.4.2)
ruby_parser (3.10.1)
rubyipmi (0.11.0)
runcible (2.13.1)
safemode (1.3.6)
scoped_search (4.1.10)
sd_notify (0.1.0)
secure_headers (6.3.0)
sequel (5.53.0)
server_sent_events (0.1.2)
sexp_processor (4.10.0)
sidekiq (5.2.10)
sinatra (2.1.0)
smart_proxy_openscap (0.9.1)
smart_proxy_pulp (3.2.0)
sprockets (4.0.2)
sprockets-rails (3.2.1)
sshkey (1.9.0)
statsd-instrument (2.1.4)
stomp (1.4.9)
thor (1.0.1)
thread_safe (0.3.6)
tilt (2.0.8)
tzinfo (1.2.6)
unf (0.1.3)
unf_ext (0.0.7.2)
unicode (0.4.4.4)
unicode-display_width (2.4.2, 1.7.0)
validates_lengths_from_database (0.5.0)
webpack-rails (0.9.8)
websocket-driver (0.7.1)
websocket-extensions (0.1.5)
will_paginate (3.1.7)
xmlrpc (0.3.0)
zeitwerk (2.2.2)
