Hi Adam,
Thanks for your answer.
Indeed I built new gems from git hub and added them to the foreman gems.
Here again, I'm not so familiar with Ruby but I suspect it worked since I
see the new settings under settings->ansible.
Agreed, using local connection can be dangerous. I'm just trying to use it
to experiment first before deployment
Noted for vault encryption. I'll try to have a look soon.
Any idea when the next foreman-ansible release will be? In my opinion the
ability to select the ansible connection is a great feature worth releasing
Thanks and have a good day!
Hello Bernard,
what version of foreman-ansible are you running? As far as I know there
wasn't a new release since the winrm support was added, so unless you're
running from git checkout it won't work.
Briefly looking at the code, the commit adding winrm support should also
enable using the local connection adapter, but I would refrain from doing
that. You might end up with roles being applied on wrong host, depending on
whether you use smart proxies for ansible or not
I think there's no support for vaults yet, but it would be a great addition.
Adam
Ā·Ā·Ā·
On Jan 3, 2017 09:57, "Adam Ruzicka" wrote:
On Mon, Jan 2, 2017 at 11:59 PM, Bernard Landon bernard.landon@gmail.com wrote:
Hello all
Quick question, I see thereās a commit on foreman-ansible to support winrm.
Iāve been trying to use it with no success. Iām setting the parameter
āansible_connectionā to winrm, but when running the role, the foreman still
tries to connect over ssh.
Do I need to configure anything else?
Also, should the ālocalā connection type be also supported? When trying to
use local connection, the foreman also tries to connect over sshā¦
Quick yes/no question on an unrelated topic, does the plugin support using
vault password / vault password files?
Could be handy and I would be willing to work on it if someoneās willing
to give me some help (Iām new to Ruby).
Thanks!
ā
āForeman usersā group.
ā
Google Groups āForeman usersā group.
To unsubscribe from this topic, visit https://groups.google.com/d/
topic/foreman-users/RDuiVok8izM/unsubscribe.
