Foreman-ansible use cases review
Hello everyone,
In the next few days, I will spend some time testing foreman-ansible
plugin. As a start, I created some use cases which I think are applicable
for this plugin. I documented them in [1]. I know some of you are already
using this plugin extensively. Can you please spend few minutes to review
my use cases and let me know your comments (anything like: Use case *** is
applicable, use case *** is missing, etc).
The google doc is open for comments. Please provide your feedback as
comments in the doc. Your feedback is very valuable and will help improve
this plugin. Thanks in advance.
[1]
··· -- Suresh Thirugnanasambandan RHCSA irc: sthirugn | LinkedIn
I recall testing it specifically with Katello and there were some bits that
were painful. In particular I believe it [plugin's reporting] was /very/
slow. Definitely something I'll be looking into in the future and I'll
update you if I have anything useful.
