When I create a host in foreman and register a MAC and IP to it’s interfaces, a section for that is written to /var/lib/dhcpd/dhcpd.leases, immediately and looks like this:
But this seems to work for the primary/first interface of a host only: If I add another interface to the host, set that device’s MAC and IP and save, there is no entry added to /var/lib/dhcpd/dhcpd.leases for that. That results in that interface to receive a randomly IP instead of the configured one.
I expect that when it comes to IP reservation and assignment, a secondary interface should be handled just like the primary one by having a dhcp.leases section added for it.
when you add the second interface, do you check “Managed” flag? Only managed interfaces are orchestrated. Also, make sure it is associated with a subnet that has DHCP Proxy set, otherwise DHCP orchestration is not performed.
Yes, the nodes have multiple NICs and I expect that each one get’s the IP I configured for them in Foreman. One IP per one NIC, nothing too special nor multiple IPs on the same NIC.
I tried to update our instance of Forman to 1.22.0, since this is what happened when following the Upgrade manual. I installed Foreman on CentOS 7 using the foreman-installer. I ended up with a version of 1.22.0, which had other issues (like removing all users from the “admins” user-group upon login of a LDAP authenticated user), but this issue did not get fixed. So I restored the VM snapshot of the Foreman - node I took before starting the upgrade.
The Bug reads exactly like the issue I am facing, but upgrading to 1.22.0 does not help here; the fix should be included in this release as well, doesn’t it?
