When using foreman1.16/puppet5 I have hit an issue around BOOL type.
I didnt get using foreman1.15/puppet3
if a class has a default value = true
class myclass::client (
$client = true
notify{“myclass $class”:}
hammer -sc-param add-override-value --puppet-class myclass::client --smart-class-parameter-id 1–value “true” --match hostgroup=my_network/myclass
hammer -sc-param add-override-value --puppet-class myclass::client --smart-class-parameter-id 1–value “false” --match hostgroup=my_network/myclass
The second one fails with Bool. This worked on earlier versions of puppet and hammer/foreman should not be data-typing input in this way on variables that are not cast as Boolean. it is making a guest based on the default value. if this is true it is assuming bool!
old versions didnt do this and the field type reminded string.
When setting
for default value to be changed to that given. if bool then to allow “false” or false or 0 or undef at least something that sets none true.
as above
This is an easy one to replicate in a test. set the default value of a var to true and then try and override this with false. 1.16 it fails. 1.15 it didnt.
