Foreman installation help on Oracle Linux 6
I am new to foreman & try to install the latest version on an Oracle Linux
6 server.
I followed the steps from foreman installation guide (
Foreman :: Manual).
When I ran foreman-installer, I got the following error message (from
installation log):
Can anyone help?
[DEBUG 2015-07-17 17:39:04 main] hiera(): Looking up
apache::error_documents in YAML backend
[ERROR 2015-07-17 17:39:39 main] Repeating errors encountered during run:
[DEBUG 2015-07-17 17:39:00 main] calling :function_validate_re with
[["ERROR", "^(UNKNOWN|FATAL|ERROR|WARN|INFO|DEBUG)$"]]
[ERROR 2015-07-17 17:39:25 main] Execution of '/usr/bin/yum -d 0 -e 0 -y
install foreman-postgresql' returned 1: Error: Package: ruby
193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64)
[ERROR 2015-07-17 17:39:25 main] Package:
ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64)
/Stage[main]/Foreman::Install/Package[foreman-postgresql]/ensure: change
from absent to present fail
ed: Execution of '/usr/bin/yum -d 0 -e 0 -y install foreman-postgresql'
returned 1: Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6
[ERROR 2015-07-17 17:39:31 main] Execution of '/usr/bin/yum -d 0 -e 0 -y
install foreman-cli' returned 1: Error: Package: ruby193-rub
[ERROR 2015-07-17 17:39:31 main] Package:
[ERROR 2015-07-17 17:39:32 main]
/Stage[main]/Foreman::Cli/Package[foreman-cli]/ensure: change from absent
to present failed: Executi
on of '/usr/bin/yum -d 0 -e 0 -y install foreman-cli' returned 1: Error:
Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-rub
y193-epel-6-x86_64)
[ERROR 2015-07-17 17:39:32 main] Package:
[ERROR 2015-07-17 17:39:36 main] Execution of '/usr/bin/yum -d 0 -e 0 -y
install ruby193-rubygem-passenger-native' returned 1: Error:
[ERROR 2015-07-17 17:39:36 main] Package:
/Stage[main]/Foreman::Install/Package[ruby193-rubygem-passenger-native]/ensure:
change from absent t
o present failed: Execution of '/usr/bin/yum -d 0 -e 0 -y install
ruby193-rubygem-passenger-native' returned 1: Error: Package: ruby19
[ERROR 2015-07-17 17:39:37 main] Could not find a suitable provider for
foreman_config_entry
You need to install the OracleLinux SCL… Follow the instructions in this
Doc… no ULN subscription seems to be required.
··· On Monday, July 20, 2015 at 9:03:21 AM UTC-4, kevinm...@gmail.com wrote: > > Hi, > > I am new to foreman & try to install the latest version on an Oracle Linux > 6 server. > I followed the steps from foreman installation guide ( > http://theforeman.org/manuals/1.8/quickstart_guide.html). > > When I ran foreman-installer, I got the following error message (from > installation log): > > Can anyone help? > > Thanks, > > > [DEBUG 2015-07-17 17:39:04 main] hiera(): Looking up > apache::error_documents in YAML backend > > [ERROR 2015-07-17 17:39:39 main] Repeating errors encountered during run: > > [DEBUG 2015-07-17 17:39:00 main] calling :function_validate_re with > [["ERROR", "^(UNKNOWN|FATAL|ERROR|WARN|INFO|DEBUG)$"]] > > [ERROR 2015-07-17 17:39:25 main] Execution of '/usr/bin/yum -d 0 -e 0 -y > install foreman-postgresql' returned 1: Error: Package: ruby > > 193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:25 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:25 main] > /Stage[main]/Foreman::Install/Package[foreman-postgresql]/ensure: change > from absent to present fail > > ed: Execution of '/usr/bin/yum -d 0 -e 0 -y install foreman-postgresql' > returned 1: Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6 > > .x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:25 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:31 main] Execution of '/usr/bin/yum -d 0 -e 0 -y > install foreman-cli' returned 1: Error: Package: ruby193-rub > > y-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:31 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:32 main] > /Stage[main]/Foreman::Cli/Package[foreman-cli]/ensure: change from absent > to present failed: Executi > > on of '/usr/bin/yum -d 0 -e 0 -y install foreman-cli' returned 1: Error: > Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-rub > > y193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:32 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:36 main] Execution of '/usr/bin/yum -d 0 -e 0 -y > install ruby193-rubygem-passenger-native' returned 1: Error: > > Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 > (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:36 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:36 main] > /Stage[main]/Foreman::Install/Package[ruby193-rubygem-passenger-native]/ensure: > change from absent t > > o present failed: Execution of '/usr/bin/yum -d 0 -e 0 -y install > ruby193-rubygem-passenger-native' returned 1: Error: Package: ruby19 > > 3-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:36 main] Package: > ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) > > [ERROR 2015-07-17 17:39:37 main] Could not find a suitable provider for > foreman_config_entry >
Thanks Sean,
I installed Oracle SCL followed the instruction from the document.
I also checked ruby193 is installed with the following command:
#yum list installed | grep ruby193
rhscl-ruby193-epel-6-x86_64.noarch 1-2 @foreman
I still get the same error message when I ran foreman-installer.
Is this the right package for ruby193?
Thanks
Sorry, and you need to enable the ruby193 scl.
··· On Monday, July 20, 2015 at 10:03:19 AM UTC-4, Sean Alderman wrote: > > You need to install the OracleLinux SCL... Follow the instructions in > this Doc... no ULN subscription seems to be required. > > http://docs.oracle.com/cd/E37670_01/E59096/E59096.pdf > > On Monday, July 20, 2015 at 9:03:21 AM UTC-4, kevinm...@gmail.com wrote: >> >> Hi, >> >> I am new to foreman & try to install the latest version on an Oracle >> Linux 6 server. >> I followed the steps from foreman installation guide ( >> http://theforeman.org/manuals/1.8/quickstart_guide.html). >> >> When I ran foreman-installer, I got the following error message (from >> installation log): >> >> Can anyone help? >> >> Thanks, >> >> >> [DEBUG 2015-07-17 17:39:04 main] hiera(): Looking up >> apache::error_documents in YAML backend >> >> [ERROR 2015-07-17 17:39:39 main] Repeating errors encountered during run: >> >> [DEBUG 2015-07-17 17:39:00 main] calling :function_validate_re with >> [["ERROR", "^(UNKNOWN|FATAL|ERROR|WARN|INFO|DEBUG)$"]] >> >> [ERROR 2015-07-17 17:39:25 main] Execution of '/usr/bin/yum -d 0 -e 0 -y >> install foreman-postgresql' returned 1: Error: Package: ruby >> >> 193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:25 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:25 main] >> /Stage[main]/Foreman::Install/Package[foreman-postgresql]/ensure: change >> from absent to present fail >> >> ed: Execution of '/usr/bin/yum -d 0 -e 0 -y install foreman-postgresql' >> returned 1: Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6 >> >> .x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:25 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:31 main] Execution of '/usr/bin/yum -d 0 -e 0 -y >> install foreman-cli' returned 1: Error: Package: ruby193-rub >> >> y-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:31 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:32 main] >> /Stage[main]/Foreman::Cli/Package[foreman-cli]/ensure: change from absent >> to present failed: Executi >> >> on of '/usr/bin/yum -d 0 -e 0 -y install foreman-cli' returned 1: Error: >> Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-rub >> >> y193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:32 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:36 main] Execution of '/usr/bin/yum -d 0 -e 0 -y >> install ruby193-rubygem-passenger-native' returned 1: Error: >> >> Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 >> (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:36 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:36 main] >> /Stage[main]/Foreman::Install/Package[ruby193-rubygem-passenger-native]/ensure: >> change from absent t >> >> o present failed: Execution of '/usr/bin/yum -d 0 -e 0 -y install >> ruby193-rubygem-passenger-native' returned 1: Error: Package: ruby19 >> >> 3-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:36 main] Package: >> ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 (rhscl-ruby193-epel-6-x86_64) >> >> [ERROR 2015-07-17 17:39:37 main] Could not find a suitable provider for >> foreman_config_entry >> >
Sean,
One more thing, the server /etc/scl/prefixes directory is empty.
Do I missing something or it is ok for Oracle Linux?
Thanks
··· On Monday, July 20, 2015 at 9:43:01 AM UTC-5, kevinm...@gmail.com wrote:
Thanks Sean,
Thanks
Here is some additional information. Not sure if this helps to figure out
what I am missing.
When I try to reinstall ruby193 with the following command:
yum install ruby193*
(at the end of the this command run, I got the following message)
Finished Dependency Resolution
Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64
(ol6_software_collections)
Requires: libyaml
Error: Package: ruby193-rubygem-openscap-0.4.2-2.el6.noarch
(foreman-plugins)
Requires: openscap >= 1.2.1
Available: openscap-0.9.12-1.el6.i686 (oel6_5x64)
openscap = 0.9.12-1.el6
Available: openscap-1.0.8-1.0.1.el6_5.1.i686 (oel6_5x64_patch)
openscap = 1.0.8-1.0.1.el6_5.1
Error: Package: ruby193-rubygem-passenger-devel-4.0.18-9.el6.x86_64
Requires: ruby193-rubygem(passenger) = 4.0.18-9.el6
Available: ruby193-rubygem-passenger-4.0.18-9.el6.x86_64
Available: ruby193-rubygem-passenger-4.0.18-9.6.el6.x86_64
(foreman)
ruby193-rubygem(passenger) = 4.0.18-9.6.el6
Available: ruby193-rubygem-passenger-4.0.18-9.7.el6.x86_64
(foreman)
ruby193-rubygem(passenger) = 4.0.18-9.7.el6
Installing: ruby193-rubygem-passenger-4.0.18-9.8.el6.x86_64
(foreman)
ruby193-rubygem(passenger) = 4.0.18-9.8.el6
Installing: ruby193-rubygem-passenger40-4.0.18-11.el6.x86_64
ruby193-rubygem(passenger) = 4.0.18-11.el6
I might suggest cleaning up and starting again. For instance, yum remove
puppet* ruby193* foreman*, then install the release packages, install
foreman-installer and re-run the installer. I wasn't able to reproduce
your errors specifically, but I did encounter some errors after trying to
install ruby193 on my own, the running the installer. After starting
clean, the installer ran smoothly for me.
··· On Monday, July 20, 2015 at 11:04:32 AM UTC-4, kevinm...@gmail.com wrote: > > > Here is some additional information. Not sure if this helps to figure out > what I am missing. > > When I try to reinstall ruby193 with the following command: > > # yum install ruby193* > > (at the end of the this command run, I got the following message) > > Finished Dependency Resolution > Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 > (ol6_software_collections) > Requires: libyaml > Error: Package: ruby193-rubygem-openscap-0.4.2-2.el6.noarch > (foreman-plugins) > Requires: openscap >= 1.2.1 > Available: openscap-0.9.12-1.el6.i686 (oel6_5x64) > openscap = 0.9.12-1.el6 > Available: openscap-1.0.8-1.0.1.el6_5.1.i686 (oel6_5x64_patch) > openscap = 1.0.8-1.0.1.el6_5.1 > Error: Package: ruby193-rubygem-passenger-devel-4.0.18-9.el6.x86_64 > (rhscl-ruby193-epel-6-x86_64) > Requires: ruby193-rubygem(passenger) = 4.0.18-9.el6 > Available: ruby193-rubygem-passenger-4.0.18-9.el6.x86_64 > (rhscl-ruby193-epel-6-x86_64) > ruby193-rubygem(passenger) = 4.0.18-9.el6 > Available: ruby193-rubygem-passenger-4.0.18-9.6.el6.x86_64 > (foreman) > ruby193-rubygem(passenger) = 4.0.18-9.6.el6 > Available: ruby193-rubygem-passenger-4.0.18-9.7.el6.x86_64 > (foreman) > ruby193-rubygem(passenger) = 4.0.18-9.7.el6 > Installing: ruby193-rubygem-passenger-4.0.18-9.8.el6.x86_64 > (foreman) > ruby193-rubygem(passenger) = 4.0.18-9.8.el6 > Installing: ruby193-rubygem-passenger40-4.0.18-11.el6.x86_64 > (ol6_software_collections) > ruby193-rubygem(passenger) = 4.0.18-11.el6 > You could try using --skip-broken to work around the problem > You could try running: rpm -Va --nofiles --nodigest > >
Sean,
I have trouble to install ruby193.
Once I ran
#yum install ruby193,
I got the following:
Requires: libyaml
I ran this command before install foreman-installer.
foreman-installer and re-run the installer. I wasn’t able to reproduce
what I am missing.
Requires: libyaml
(foreman-plugins)
(foreman)
(foreman)
(foreman)
that is after I have ran the command of yum remove puppet* ruby193* &
foreman*.
Thanks
··· On Monday, July 20, 2015 at 10:58:20 AM UTC-5, kevinm...@gmail.com wrote:
Sean,
Once I ran
Requires: libyaml
out what I am missing.
Requires: libyaml
(foreman-plugins)
(foreman)
(foreman)
(foreman)
the server has puppet agent installed as part of build.
will that be an issue?
Sean,
Once I ran
Requires: libyaml
Requires: libyaml
(foreman-plugins)
(foreman)
(foreman)
(foreman)
I am doing a fresh OS install then will try again.
Thanks
··· On Monday, July 20, 2015 at 11:03:55 AM UTC-5, kevinm...@gmail.com wrote:
Sean,
Once I ran
Requires: libyaml
remove puppet* ruby193* foreman*, then install the release packages,
install foreman-installer and re-run the installer. I wasn’t able to
reproduce your errors specifically, but I did encounter some errors after
trying to install ruby193 on my own, the running the installer. After
starting clean, the installer ran smoothly for me.
On Monday, July 20, 2015 at 11:04:32 AM UTC-4, kevinm...@gmail.com >>> wrote:
Requires: libyaml
(foreman-plugins)
(oel6_5x64_patch)
(foreman)
(foreman)
(foreman)
Unfortunately, I'm not sure I can help you more, I saw your errors, but the
message seems to be have been deleted now. Anyway, for testing, I used a
Foreman system to build OEL6 vm (which begins with minimal os install, epel
repo, updates to latest, installs puppet agent). From there, I removed
puppet, installed scl_utils, installed the OEL SCL repo, PuppetLabs release
package, Foreman release package, foreman-installer, and ran the installer
with out issue.
It seems like once you have the OEL scl repo and scl_utils installed the
foreman-installer will do the rest as far as getting the ruby193 scl
enabled and installed properly.
··· On Monday, July 20, 2015 at 1:11:29 PM UTC-4, Kevin Marr wrote: > > > > I am doing a fresh OS install then will try again. > > Thanks > > > On Monday, July 20, 2015 at 11:03:55 AM UTC-5, kevinm...@gmail.com wrote: > >> >> the server has puppet agent installed as part of build. >> will that be an issue? >> >> Thanks, >> >> On Monday, July 20, 2015 at 10:58:20 AM UTC-5, kevinm...@gmail.com wrote: >> >>> Sean, >>> >>> I have trouble to install ruby193. >>> Once I ran >>> >>> #yum install ruby193, >>> >>> I got the following: >>> >>> Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 >>> (ol6_software_collections) >>> Requires: libyaml >>> You could try using --skip-broken to work around the problem >>> You could try running: rpm -Va --nofiles --nodigest >>> >>> I ran this command before install foreman-installer. >>> >>> Thanks, >>> >>> >>> On Monday, July 20, 2015 at 10:44:48 AM UTC-5, Sean Alderman wrote: >>> >>>> I might suggest cleaning up and starting again. For instance, yum >>>> remove puppet* ruby193* foreman*, then install the release packages, >>>> install foreman-installer and re-run the installer. I wasn't able to >>>> reproduce your errors specifically, but I did encounter some errors after >>>> trying to install ruby193 on my own, the running the installer. After >>>> starting clean, the installer ran smoothly for me. >>>> >>>> On Monday, July 20, 2015 at 11:04:32 AM UTC-4, kevinm...@gmail.com >>>> wrote: >>>>> >>>>> >>>>> Here is some additional information. Not sure if this helps to figure >>>>> out what I am missing. >>>>> >>>>> When I try to reinstall ruby193 with the following command: >>>>> >>>>> # yum install ruby193* >>>>> >>>>> (at the end of the this command run, I got the following message) >>>>> >>>>> Finished Dependency Resolution >>>>> Error: Package: ruby193-ruby-libs-1.9.3.484-49.el6.x86_64 >>>>> (ol6_software_collections) >>>>> Requires: libyaml >>>>> Error: Package: ruby193-rubygem-openscap-0.4.2-2.el6.noarch >>>>> (foreman-plugins) >>>>> Requires: openscap >= 1.2.1 >>>>> Available: openscap-0.9.12-1.el6.i686 (oel6_5x64) >>>>> openscap = 0.9.12-1.el6 >>>>> Available: openscap-1.0.8-1.0.1.el6_5.1.i686 >>>>> (oel6_5x64_patch) >>>>> openscap = 1.0.8-1.0.1.el6_5.1 >>>>> Error: Package: ruby193-rubygem-passenger-devel-4.0.18-9.el6.x86_64 >>>>> (rhscl-ruby193-epel-6-x86_64) >>>>> Requires: ruby193-rubygem(passenger) = 4.0.18-9.el6 >>>>> Available: ruby193-rubygem-passenger-4.0.18-9.el6.x86_64 >>>>> (rhscl-ruby193-epel-6-x86_64) >>>>> ruby193-rubygem(passenger) = 4.0.18-9.el6 >>>>> Available: ruby193-rubygem-passenger-4.0.18-9.6.el6.x86_64 >>>>> (foreman) >>>>> ruby193-rubygem(passenger) = 4.0.18-9.6.el6 >>>>> Available: ruby193-rubygem-passenger-4.0.18-9.7.el6.x86_64 >>>>> (foreman) >>>>> ruby193-rubygem(passenger) = 4.0.18-9.7.el6 >>>>> Installing: ruby193-rubygem-passenger-4.0.18-9.8.el6.x86_64 >>>>> (foreman) >>>>> ruby193-rubygem(passenger) = 4.0.18-9.8.el6 >>>>> Installing: >>>>> ruby193-rubygem-passenger40-4.0.18-11.el6.x86_64 (ol6_software_collections) >>>>> ruby193-rubygem(passenger) = 4.0.18-11.el6 >>>>> You could try using --skip-broken to work around the problem >>>>> You could try running: rpm -Va --nofiles --nodigest >>>>> >>>>> >>>>
Thanks Sean,
I will give it a try again.
··· On Tuesday, July 21, 2015 at 9:53:19 AM UTC-5, Sean Alderman wrote:
Unfortunately, I’m not sure I can help you more, I saw your errors, but
the message seems to be have been deleted now. Anyway, for testing, I used
a Foreman system to build OEL6 vm (which begins with minimal os install,
epel repo, updates to latest, installs puppet agent). From there, I
removed puppet, installed scl_utils, installed the OEL SCL repo, PuppetLabs
release package, Foreman release package, foreman-installer, and ran the
installer with out issue.
Thanks
On Monday, July 20, 2015 at 10:58:20 AM UTC-5, kevinm...@gmail.com >>> wrote:
Sean,
Once I ran
Requires: libyaml
On Monday, July 20, 2015 at 11:04:32 AM UTC-4, kevinm...@gmail.com >>>>> wrote:
Requires: libyaml
(foreman-plugins)
(oel6_5x64_patch)
(foreman)
(foreman)
Installing:
ruby193-rubygem-passenger-4.0.18-9.8.el6.x86_64 (foreman)
Installing:
