I'm trying to incorporate some modules from foreman-installer into our
set of puppet modules, that would install and configure Foreman with our
services. Basically I want to deploy it with thin instead of passenger,
so I would provide different configuration for apache. But still I want
to reuse the foreman module (if possible using git submodules). So what
I need is to customize the parameters in foreman/manifests/params.pp
(e.g. disable $passenger etc.).
I haven't find a way how to do it without modifying the original foreman
module. Anyone with a solution that would do it? So simply said: I would
like to define my own module, that would alter the params in foreman
module. From what I found so far is not possible with the current state.
But perhaps someone will enlighten me.
– Ivan
Greg,
Parameterizing the modules, would mean that we limit people to Puppet
2.6.5+. Since currently supported OSes ship lower versions of Puppet,
I'm not sure how we want to handle? (We also claim to support really
old versions of Puppet as well.)
Brian
On Fri, Jun 8, 2012 at 10:44 AM, Greg Sutcliffe wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 08/06/12 15:16, Ivan Nečas wrote:
>> Hi,
>> our set of puppet modules, that would install and configure Foreman
>> with our services. Basically I want to deploy it with thin instead
>> of passenger, so I would provide different configuration for
>> apache. But still I want to reuse the foreman module (if possible
>> using git submodules). So what I need is to customize the
>> parameters in foreman/manifests/params.pp (e.g. disable $passenger
>> etc.).
>> foreman module. Anyone with a solution that would do it? So simply
>> said: I would like to define my own module, that would alter the
>> params in foreman module. From what I found so far is not possible
>> with the current state. But perhaps someone will enlighten me.
> Parameterizing the foreman and foreman_proxy modules are defintely on
> my todo list, but I've not had time yet. If you wnt to have a go, the
> puppet module is already parameterized, and may serve as a useful
> reference guide. You can compare the 'master' and 'oldstable' branches
> of theforeman/puppet-puppet.git to see what the changes look like.
> I also have use cases for customizing the modules (different DHCP
> subnets in foreman-proxy for example) so I hope to get to it in the
> next week or two.
> Greg
> OpenPGP -> KeyID: CA0AEB93
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.19 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
> iEYEARECAAYFAk/SD9IACgkQ8O7RN8oK65MsQACfXowdFaU/piW1MGg4bi+pVsDd
> +s0An3PRi9YumIX4mptWIOR1PSFifhqn
> =o/2F
> -----END PGP SIGNATURE-----
next week or two.
Greg
> Hi,
> etc.).
we had this discussion when I parameterized the puppet module - I'm
maintaining an 'oldstable' branch of the foreman installer which is
not parameterized for older puppet clients. The wiki also reflects
that option and states which modules have been converted.
Greg
On 08/06/12 17:06, Brian Gupta wrote:
> Greg,
> Puppet 2.6.5+. Since currently supported OSes ship lower versions
> of Puppet, I'm not sure how we want to handle? (We also claim to
> support really old versions of Puppet as well.)
> Thanks, Brian
> Greg,
What about making branch katello-installer-2.0 that would state to be
working only on newer Puppet versions and keep the previous more
compatible version in 1.0 or something like that). The re-usability is
quite important for the installer (we can't assume the users to keep the
defaults) and therefore the parametrized approach is a natural
evolution. Avoiding it just for the compatibility reasons is not worth
– Ivan
On 06/08/2012 06:06 PM, Brian Gupta wrote:
from my point of view.
Brian
Hash: SHA1
I’m trying to incorporate some modules from foreman-installer into
etc.).
I haven’t find a way how to do it without modifying the original
my todo list, but I’ve not had time yet. If you wnt to have a go, the
reference guide. You can compare the ‘master’ and ‘oldstable’ branches
next week or two.
Greg
OpenPGP → KeyID: CA0AEB93
=o/2F
> Hash: SHA1
>> Hi,
>> etc.).
Thank you! That was what I was searching for. Perhaps I will send some
pull requests for that (since need it for my current project anyway).
– Ivan
next week or two.
Greg
=o/2F
Glad to help. Patches would be awesome - as I say, I will do it
eventually, but I need to focus on cleaning up our Debian packages
first
Greg
> some pull requests for that (since need it for my current project
> anyway).
