Next time I’ll open a new thread!
This is what is coming up:
TASK [foreman : Get foreman-installer] ***********************************************************************************************************************************************************************task path: /home/administrator/ci_infra/farm_base/roles/foreman/tasks/foreman.yml:45
Wednesday 01 February 2023 15:55:28 +0000 (0:00:01.831) 0:00:19.036 ****
fatal: [vmforeman-test.dev-farm.xyz.net]: FAILED! => {"cache_update_time": 1675266928, "cache_updated": false, "changed": false, "msg": "'/usr/bin/apt-get -y -o \"Dpkg::Options::=--force-confdef\" -o \"Dpkg::Options::=--force-confold\" install 'foreman-installer'' failed: E: Unable to correct problems, you have held broken packages.\n", "rc": 100, "stderr": "E: Unable to correct problems, you have held broken packages.\n", "stderr_lines": ["E: Unable to correct problems, you have held broken packages."], "stdout": "Reading package lists...\nBuilding dependency tree...\nReading state information...\nSome packages could not be installed. This may mean that you have\nrequested an impossible situation or if you are using the unstable\ndistribution that some required packages have not yet been created\nor been moved out of Incoming.\nThe following information may help to resolve the situation:\n\nThe following packages have unmet dependencies:\n foreman-installer : Depends: ruby-kafo (>= 6.0.0) but it is not going to be installed\n Depends: ruby-kafo (< 7.0.0) but it is not going to be installed\n", "stdout_lines": ["Reading package lists...", "Building dependency tree...", "Reading state information...", "Some packages could not be installed. This may mean that you have", "requested an impossible situation or if you are using the unstable", "distribution that some required packages have not yet been created", "or been moved out of Incoming.", "The following information may help to resolve the situation:", "", "The following packages have unmet dependencies:", " foreman-installer : Depends: ruby-kafo (>= 6.0.0) but it is not going to be installed", " Depends: ruby-kafo (< 7.0.0) but it is not going to be installed"]}
[WARNING]: Failure using method (v2_runner_on_failed) in callback plugin (<ansible_collections.community.general.plugins.callback.mail.CallbackModule object at 0x7f1b8db1a490>): [Errno 111] Connection
refused
PLAY RECAP ***************************************************************************************************************************************************************************************************vmforeman-test.dev-farm.xyz.net : ok=14 changed=0 unreachable=0 failed=1 skipped=1 rescued=0 ignored=0
This is where it fails for me right now.
Sorry, forgot the apt policy:
apt policy
Package files:
100 /var/lib/dpkg/status
release a=now
500 http://apt.puppetlabs.com bionic/puppet7 all Packages
release o=Puppetlabs,a=bionic,n=bionic,l=Puppetlabs,c=puppet7,b=all
origin apt.puppetlabs.com
500 http://apt.puppetlabs.com bionic/puppet7 amd64 Packages
release o=Puppetlabs,a=bionic,n=bionic,l=Puppetlabs,c=puppet7,b=amd64
500 http://apt.puppetlabs.com bionic/puppet6 all Packages
release o=Puppetlabs,a=bionic,n=bionic,l=Puppetlabs,c=puppet6,b=all
500 http://apt.puppetlabs.com bionic/puppet6 amd64 Packages
release o=Puppetlabs,a=bionic,n=bionic,l=Puppetlabs,c=puppet6,b=amd64
500 http://deb.theforeman.org plugins/3.5 amd64 Packages
release o=TheForeman,a=plugins,n=plugins,l=TheForeman,c=3.5,b=amd64
origin deb.theforeman.org
500 http://deb.theforeman.org plugins/2.4 amd64 Packages
release o=TheForeman,a=plugins,n=plugins,l=TheForeman,c=2.4,b=amd64
500 http://deb.theforeman.org bionic/2.4 amd64 Packages
release o=TheForeman,a=bionic,n=bionic,l=TheForeman,c=2.4,b=amd64
500 http://ppa.launchpad.net/ansible/ansible/ubuntu focal/main amd64 Packages
release v=20.04,o=LP-PPA-ansible-ansible,a=focal,n=focal,l=ansible,c=main,b=amd64
origin ppa.launchpad.net
500 http://ch.archive.ubuntu.com/ubuntu focal-security/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=multiverse,b=amd64
origin ch.archive.ubuntu.com
500 http://ch.archive.ubuntu.com/ubuntu focal-security/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-security/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-security/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal-security,n=focal,l=Ubuntu,c=main,b=amd64
100 http://ch.archive.ubuntu.com/ubuntu focal-backports/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-backports,n=focal,l=Ubuntu,c=universe,b=amd64
100 http://ch.archive.ubuntu.com/ubuntu focal-backports/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal-backports,n=focal,l=Ubuntu,c=main,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-updates/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=multiverse,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-updates/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-updates/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal-updates/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal-updates,n=focal,l=Ubuntu,c=main,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal/multiverse amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=multiverse,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal/universe amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=universe,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal/restricted amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=restricted,b=amd64
500 http://ch.archive.ubuntu.com/ubuntu focal/main amd64 Packages
release v=20.04,o=Ubuntu,a=focal,n=focal,l=Ubuntu,c=main,b=amd64
Pinned packages:
