Running foreman-installer --scenario katello
fails with:
/usr/share/gems/gems/kafo-6.4.0/lib/kafo/data_type.rb:31:in 'register_type': Data type Apache::LogLevel is already registered, cannot be re-registered (ArgumentError)
foreman-installer completes without error.
Alma Linux 8.5
I originally successfully installed Foreman without Katello, including the Chef plugin (we’re a long-time Chef shop). Our successful install script is:
foreman-installer \
--enable-foreman-plugin-chef \
--enable-foreman-plugin-tasks \
--enable-foreman-proxy-plugin-chef \
--foreman-proxy-plugin-chef-client-name="boss" \
--foreman-proxy-plugin-chef-enabled="true" \
--foreman-proxy-plugin-chef-private-key="/etc/chef/client.pem" \
--foreman-proxy-plugin-chef-server-url="https://manage.chef.io/organizations/..." \
--foreman-proxy-plugin-chef-ssl-verify="true" \
--foreman-proxy-plugin-chef-ssl-pem-file="/etc/letsencrypt/live/..." \
--foreman-proxy-plugin-chef-version="present" \
--foreman-proxy-foreman-ssl-ca="/etc/letsencrypt/live/..." \
--foreman-proxy-foreman-ssl-cert="/etc/letsencrypt/live/..." \
--foreman-proxy-foreman-ssl-key="/etc/letsencrypt/live/..." \
--foreman-client-ssl-cert="/etc/letsencrypt/live/..." \
--foreman-client-ssl-key="/etc/letsencrypt/live/..." \
--foreman-client-ssl-ca="/etc/letsencrypt/live/..." \
--no-enable-puppet \
--foreman-server-ssl-crl=""
We subsequently realized we want to install Katello, so I’ve uninstalled Foreman, and am trying to reinstall it, adding --scenario katello
to the script. But that fails with the error listed above. It even fails with a simple --help:
# foreman-installer --scenario katello --help
18: from /usr/sbin/foreman-installer:8:in `<main>'
17: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/kafo_configure.rb:50:in `run'
16: from /usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in `run'
15: from /usr/share/gems/gems/clamp-1.1.2/lib/clamp/command.rb:132:in `new'
14: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/kafo_configure.rb:157:in `initialize'
13: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/kafo_configure.rb:316:in `set_parameters'
12: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/scenario_manager.rb:217:in `load_and_setup_configuration'
11: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:268:in `preset_defaults_from_puppet'
10: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:258:in `params'
9: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:132:in `modules'
8: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:396:in `register_data_types'
7: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:396:in `each'
6: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:397:in `block in register_data_types'
5: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:397:in `each'
4: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/configuration.rb:398:in `block (2 levels) in register_data_types'
3: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/data_type_parser.rb:20:in `register'
2: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/data_type_parser.rb:20:in `each'
1: from /usr/share/gems/gems/kafo-6.4.0/lib/kafo/data_type_parser.rb:22:in `block in register'
/usr/share/gems/gems/kafo-6.4.0/lib/kafo/data_type.rb:31:in `register_type': Data type Apache::LogLevel is already registered, cannot be re-registered (ArgumentError)
I don’t understand where Apache::LogLevel is already registered, and how to either unregister it, or tell foreman-installer to ignore it.
