Foreman-installer problem
Hello everyone, I have a problem with installing foreman-installer
"Could not get default values, check log file at
> /var/log/foreman-installer/foreman-installer.log for more information"
> [DEBUG 2014-02-18 13:12:16 main] echo
> '$kafo_config_file="/usr/share/foreman-installer/config/foreman-installer.yaml"
> $kafo_add_progress=true include foreman::params include
> foreman_proxy::params include puppet::params
> dump_values("foreman::params::foreman_url","foreman::params::unattended","foreman::params::authentication","foreman::params::passenger","foreman::params::passenger_scl","foreman::params::use_vhost","foreman::params::ssl","foreman::params::custom_repo","foreman::params::repo","foreman::params::configure_epel_repo","foreman::params::configure_scl_repo","foreman::params::selinux","foreman::params::gpgcheck","foreman::params::version","foreman::params::db_manage","foreman::params::db_type","foreman::params::db_username","foreman::params::db_password","foreman::params::app_root","foreman::params::user","foreman::params::group",foreman::params::user_groups,"foreman::params::environment","foreman::params::puppet_home","foreman::params::locations_enabled","foreman::params::organizations_enabled","foreman::params::passenger_interface","foreman::params::server_ssl_ca","foreman::params::server_ssl_cert","foreman::params::server_ssl_key","foreman::params::oauth_active","foreman::params::oauth_map_users","foreman::params::oauth_consumer_key","foreman::params::oauth_consumer_secret","foreman_proxy::params::repo","foreman_proxy::params::gpgcheck","foreman_proxy::params::custom_repo",foreman_proxy::params::port,"foreman_proxy::params::dir","foreman_proxy::params::user","foreman_proxy::params::log","foreman_proxy::params::ssl","foreman_proxy::params::ssl_ca","foreman_proxy::params::ssl_cert","foreman_proxy::params::ssl_key",foreman_proxy::params::trusted_hosts,"foreman_proxy::params::manage_sudoersd","foreman_proxy::params::use_sudoersd","foreman_proxy::params::puppetca","foreman_proxy::params::ssldir","foreman_proxy::params::puppetdir","foreman_proxy::params::autosign_location","foreman_proxy::params::puppetca_cmd","foreman_proxy::params::puppet_group","foreman_proxy::params::puppetrun","foreman_proxy::params::puppetrun_cmd","foreman_proxy::params::puppetrun_provider","foreman_proxy::params::tftp","foreman_proxy::params::tftp_syslinux_root",foreman_proxy::params::tftp_syslinux_files,"foreman_proxy::params::tftp_root",foreman_proxy::params::tftp_dirs,"foreman_proxy::params::tftp_servername","foreman_proxy::params::dhcp","foreman_proxy::params::dhcp_managed","foreman_proxy::params::dhcp_interface","foreman_proxy::params::dhcp_gateway","foreman_proxy::params::dhcp_range","foreman_proxy::params::dhcp_nameservers","foreman_proxy::params::dhcp_vendor","foreman_proxy::params::dhcp_config","foreman_proxy::params::dhcp_leases","foreman_proxy::params::dhcp_key_name","foreman_proxy::params::dhcp_key_secret","foreman_proxy::params::dns","foreman_proxy::params::dns_managed","foreman_proxy::params::dns_interface","foreman_proxy::params::dns_zone","foreman_proxy::params::dns_reverse","foreman_proxy::params::dns_server",foreman_proxy::params::dns_forwarders,"foreman_proxy::params::bmc","foreman_proxy::params::bmc_default_provider","foreman_proxy::params::keyfile","foreman_proxy::params::register_in_foreman","foreman_proxy::params::foreman_base_url","foreman_proxy::params::registered_name","foreman_proxy::params::registered_proxy_url","foreman_proxy::params::oauth_effective_user","foreman_proxy::params::oauth_consumer_key","foreman_proxy::params::oauth_consumer_secret","puppet::params::version","puppet::params::user","puppet::params::group","puppet::params::dir",puppet::params::port,"puppet::params::listen","puppet::params::pluginsync","puppet::params::splay",puppet::params::runinterval,"puppet::params::runmode","puppet::params::cron_cmd","puppet::params::agent_noop","puppet::params::show_diff",puppet::params::configtimeout,"puppet::params::ca_server","puppet::params::classfile","puppet::params::main_template","puppet::params::agent_template","puppet::params::auth_template","puppet::params::nsauth_template","puppet::params::client_package","puppet::params::agent","puppet::params::server","puppet::params::user","puppet::params::group","puppet::params::dir",puppet::params::port,"puppet::params::server_vardir","puppet::params::server_ca","puppet::params::server_reports","puppet::params::server_passenger","puppet::params::server_service_fallback",puppet::params::server_passenger_max_pool,"puppet::params::server_httpd_service","puppet::params::server_external_nodes","puppet::params::server_template","puppet::params::server_config_version","puppet::params::server_git_repo","puppet::params::server_dynamic_environments",puppet::params::server_environments,"puppet::params::server_environments_owner","puppet::params::server_envs_dir","puppet::params::server_manifest_path",puppet::params::server_common_modules_path,"puppet::params::server_git_repo_path",puppet::params::server_git_branch_map,"puppet::params::server_post_hook_content","puppet::params::server_post_hook_name","puppet::params::server_storeconfigs_backend","puppet::params::server_app_root","puppet::params::server_ssl_dir","puppet::params::server_package","puppet::params::server_certname","puppet::params::server_enc_api","puppet::params::server_report_api","foreman::params::foreman_url","foreman::params::client_ssl_ca","foreman::params::client_ssl_cert","foreman::params::client_ssl_key","foreman::params::facts","foreman::params::puppet_home","foreman::params::puppet_basedir")'
> > RUBYLIB=/usr/lib/ruby/vendor_ruby/kafo/…/…//modules: puppet apply
> --modulepath
> /usr/share/foreman-installer/modules:/usr/lib/ruby/vendor_ruby/kafo/modules
> 2>&1
> [DEBUG 2014-02-18 13:12:16 main] e[1;31mError: Could not run: Failed to
> find kansas via exec: Execution of '/usr/bin/env
> PUPPET_DASHBOARD_URL=http://localhost:3000
> /opt/puppet-dashboard/bin/external_node kansas' returned 1: e[0m
Thanks in advance
After removing puppet-dashboard, i have another error message
> Output of 'facter fqdn' is different from 'hostname -f'
> Make sure above command gives the same output. If needed, change the
> hostname permanently via 'hostname' command and editing
> appropriate configuration file.
> (e.g. on Red Hat systems /etc/sysconfig/network).
> If 'hostname -f' still returns unexpected result, check /etc/hosts and put
> hostname entry in the correct order, for example:
> 1.2.3.4 full.hostname.com full
> Fully qualified hostname must be the first entry on the line
> Your system does not meet configuration criteria
> Something went wrong! Check the log for ERROR-level output
> The full log is at /var/log/foreman-installer/foreman-installer.log
[ INFO 2014-02-18 13:45:14 main] Parsing default values from puppet
··· > modules... > [DEBUG 2014-02-18 13:45:14 main] echo > '$kafo_config_file="/usr/share/foreman-installer/config/foreman-installer.yaml" > $kafo_add_progress=true include foreman::params include > foreman_proxy::params include puppet::params > dump_values("foreman::params::foreman_url","foreman::params::unattended","foreman::params::authentication","foreman::params::passenger","foreman::params::passenger_scl","foreman::params::use_vhost","foreman::params::ssl","foreman::params::custom_repo","foreman::params::repo","foreman::params::configure_epel_repo","foreman::params::configure_scl_repo","foreman::params::selinux","foreman::params::gpgcheck","foreman::params::version","foreman::params::db_manage","foreman::params::db_type","foreman::params::db_username","foreman::params::db_password","foreman::params::app_root","foreman::params::user","foreman::params::group",foreman::params::user_groups,"foreman::params::environment","foreman::params::puppet_home","foreman::params::locations_enabled","foreman::params::organizations_enabled","foreman::params::passenger_interface","foreman::params::server_ssl_ca","foreman::params::server_ssl_cert","foreman::params::server_ssl_key","foreman::params::oauth_active","foreman::params::oauth_map_users","foreman::params::oauth_consumer_key","foreman::params::oauth_consumer_secret","foreman_proxy::params::repo","foreman_proxy::params::gpgcheck","foreman_proxy::params::custom_repo",foreman_proxy::params::port,"foreman_proxy::params::dir","foreman_proxy::params::user","foreman_proxy::params::log","foreman_proxy::params::ssl","foreman_proxy::params::ssl_ca","foreman_proxy::params::ssl_cert","foreman_proxy::params::ssl_key",foreman_proxy::params::trusted_hosts,"foreman_proxy::params::manage_sudoersd","foreman_proxy::params::use_sudoersd","foreman_proxy::params::puppetca","foreman_proxy::params::ssldir","foreman_proxy::params::puppetdir","foreman_proxy::params::autosign_location","foreman_proxy::params::puppetca_cmd","foreman_proxy::params::puppet_group","foreman_proxy::params::puppetrun","foreman_proxy::params::puppetrun_cmd","foreman_proxy::params::puppetrun_provider","foreman_proxy::params::tftp","foreman_proxy::params::tftp_syslinux_root",foreman_proxy::params::tftp_syslinux_files,"foreman_proxy::params::tftp_root",foreman_proxy::params::tftp_dirs,"foreman_proxy::params::tftp_servername","foreman_proxy::params::dhcp","foreman_proxy::params::dhcp_managed","foreman_proxy::params::dhcp_interface","foreman_proxy::params::dhcp_gateway","foreman_proxy::params::dhcp_range","foreman_proxy::params::dhcp_nameservers","foreman_proxy::params::dhcp_vendor","foreman_proxy::params::dhcp_config","foreman_proxy::params::dhcp_leases","foreman_proxy::params::dhcp_key_name","foreman_proxy::params::dhcp_key_secret","foreman_proxy::params::dns","foreman_proxy::params::dns_managed","foreman_proxy::params::dns_interface","foreman_proxy::params::dns_zone","foreman_proxy::params::dns_reverse","foreman_proxy::params::dns_server",foreman_proxy::params::dns_forwarders,"foreman_proxy::params::bmc","foreman_proxy::params::bmc_default_provider","foreman_proxy::params::keyfile","foreman_proxy::params::register_in_foreman","foreman_proxy::params::foreman_base_url","foreman_proxy::params::registered_name","foreman_proxy::params::registered_proxy_url","foreman_proxy::params::oauth_effective_user","foreman_proxy::params::oauth_consumer_key","foreman_proxy::params::oauth_consumer_secret","puppet::params::version","puppet::params::user","puppet::params::group","puppet::params::dir",puppet::params::port,"puppet::params::listen","puppet::params::pluginsync","puppet::params::splay",puppet::params::runinterval,"puppet::params::runmode","puppet::params::cron_cmd","puppet::params::agent_noop","puppet::params::show_diff",puppet::params::configtimeout,"puppet::params::ca_server","puppet::params::classfile","puppet::params::main_template","puppet::params::agent_template","puppet::params::auth_template","puppet::params::nsauth_template","puppet::params::client_package","puppet::params::agent","puppet::params::server","puppet::params::user","puppet::params::group","puppet::params::dir",puppet::params::port,"puppet::params::server_vardir","puppet::params::server_ca","puppet::params::server_reports","puppet::params::server_passenger","puppet::params::server_service_fallback",puppet::params::server_passenger_max_pool,"puppet::params::server_httpd_service","puppet::params::server_external_nodes","puppet::params::server_template","puppet::params::server_config_version","puppet::params::server_git_repo","puppet::params::server_dynamic_environments",puppet::params::server_environments,"puppet::params::server_environments_owner","puppet::params::server_envs_dir","puppet::params::server_manifest_path",puppet::params::server_common_modules_path,"puppet::params::server_git_repo_path",puppet::params::server_git_branch_map,"puppet::params::server_post_hook_content","puppet::params::server_post_hook_name","puppet::params::server_storeconfigs_backend","puppet::params::server_app_root","puppet::params::server_ssl_dir","puppet::params::server_package","puppet::params::server_certname","puppet::params::server_enc_api","puppet::params::server_report_api","foreman::params::foreman_url","foreman::params::client_ssl_ca","foreman::params::client_ssl_cert","foreman::params::client_ssl_key","foreman::params::facts","foreman::params::puppet_home","foreman::params::puppet_basedir")' > > RUBYLIB=/usr/lib/ruby/vendor_ruby/kafo/../..//modules: puppet apply > --modulepath > /usr/share/foreman-installer/modules:/usr/lib/ruby/vendor_ruby/kafo/modules > 2>&1 > [DEBUG 2014-02-18 13:45:16 main] e[1;31mWarning: Could not retrieve fact > fqdne[0m > e[mNotice: Compiled catalog for kansas in environment production in 0.14 > secondse[0m > e[mNotice: Finished catalog run in 0.27 secondse[0m > > [ INFO 2014-02-18 13:45:16 main] ... finished >
So the problem is that your fqdn is not set correctly. The error message
suggests to set it using hostname command. If it does not help you can tweak
/etc/hosts.
··· -- Marek
Output of ‘facter fqdn’ is different from ‘hostname -f’
hostname permanently via ‘hostname’ command and editing
If ‘hostname -f’ still returns unexpected result, check /etc/hosts and put
modules…
‘$kafo_config_file=“/usr/share/foreman-installer/config/foreman-installer.
yaml” $kafo_add_progress=true include foreman::params include
dump_values(“foreman::params::foreman_url”,“foreman::params::unattended”,"
foreman::params::authentication",“foreman::params::passenger”,“foreman::pa
rams::passenger_scl”,“foreman::params::use_vhost”,“foreman::params::ssl”,"
foreman::params::custom_repo",“foreman::params::repo”,“foreman::params::co
nfigure_epel_repo”,“foreman::params::configure_scl_repo”,“foreman::params:
:selinux”,“foreman::params::gpgcheck”,“foreman::params::version”,“foreman:
:params::db_manage”,“foreman::params::db_type”,“foreman::params::db_userna
me”,“foreman::params::db_password”,“foreman::params::app_root”,“foreman::stuck_out_tongue:
arams::user”,“foreman::params::group”,foreman::params::user_groups,“forema
n::params::environment”,“foreman::params::puppet_home”,“foreman::params::l
ocations_enabled”,“foreman::params::organizations_enabled”,“foreman::param
s::passenger_interface”,“foreman::params::server_ssl_ca”,“foreman::params:
:server_ssl_cert”,“foreman::params::server_ssl_key”,“foreman::params::oaut
h_active”,“foreman::params::oauth_map_users”,“foreman::params::oauth_consu
mer_key”,“foreman::params::oauth_consumer_secret”,“foreman_proxy::params::
repo”,“foreman_proxy::params::gpgcheck”,“foreman_proxy::params::custom_rep
o”,foreman_proxy::params::port,“foreman_proxy::params::dir”,“foreman_proxy
::params::user”,“foreman_proxy::params::log”,“foreman_proxy::params::ssl”,
“foreman_proxy::params::ssl_ca”,“foreman_proxy::params::ssl_cert”,“foreman
proxy::params::ssl_key",foreman_proxy::params::trusted_hosts,“foreman_pro
xy::params::manage_sudoersd”,“foreman_proxy::params::use_sudoersd”,“forema
n_proxy::params::puppetca”,“foreman_proxy::params::ssldir”,“foreman_proxy:
:params::puppetdir”,“foreman_proxy::params::autosign_location”,“foreman_pr
oxy::params::puppetca_cmd”,“foreman_proxy::params::puppet_group”,"foreman
proxy::params::puppetrun”,“foreman_proxy::params::puppetrun_cmd”,“foreman_
proxy::params::puppetrun_provider”,“foreman_proxy::params::tftp”,“foreman_
proxy::params::tftp_syslinux_root”,foreman_proxy::params::tftp_syslinux_fi
les,“foreman_proxy::params::tftp_root”,foreman_proxy::params::tftp_dirs,“f
oreman_proxy::params::tftp_servername”,“foreman_proxy::params::dhcp”,“fore
man_proxy::params::dhcp_managed”,“foreman_proxy::params::dhcp_interface”,"
foreman_proxy::params::dhcp_gateway",“foreman_proxy::params::dhcp_range”,"
foreman_proxy::params::dhcp_nameservers",“foreman_proxy::params::dhcp_vend
or”,“foreman_proxy::params::dhcp_config”,“foreman_proxy::params::dhcp_leas
es”,“foreman_proxy::params::dhcp_key_name”,“foreman_proxy::params::dhcp_ke
y_secret”,“foreman_proxy::params::dns”,"foreman_proxy::params::dns_managed
",“foreman_proxy::params::dns_interface”,“foreman_proxy::params::dns_zone”
,“foreman_proxy::params::dns_reverse”,“foreman_proxy::params::dns_server”,
foreman_proxy::params::dns_forwarders,“foreman_proxy::params::bmc”,“forema
n_proxy::params::bmc_default_provider”,“foreman_proxy::params::keyfile”,“f
oreman_proxy::params::register_in_foreman”,“foreman_proxy::params::foreman
base_url",“foreman_proxy::params::registered_name”,“foreman_proxy::params
::registered_proxy_url”,“foreman_proxy::params::oauth_effective_user”,“for
eman_proxy::params::oauth_consumer_key”,“foreman_proxy::params::oauth_cons
umer_secret”,“puppet::params::version”,“puppet::params::user”,“puppet::par
ams::group”,“puppet::params::dir”,puppet::params::port,“puppet::params::li
sten”,“puppet::params::pluginsync”,“puppet::params::splay”,puppet::params:
:runinterval,“puppet::params::runmode”,“puppet::params::cron_cmd”,“puppet:
:params::agent_noop”,“puppet::params::show_diff”,puppet::params::configtim
eout,“puppet::params::ca_server”,“puppet::params::classfile”,“puppet::para
ms::main_template”,“puppet::params::agent_template”,"puppet::params::auth
template”,“puppet::params::nsauth_template”,“puppet::params::client_packag
e”,“puppet::params::agent”,“puppet::params::server”,“puppet::params::user”
,“puppet::params::group”,“puppet::params::dir”,puppet::params::port,“puppe
t::params::server_vardir”,“puppet::params::server_ca”,“puppet::params::ser
ver_reports”,“puppet::params::server_passenger”,“puppet::params::server_se
rvice_fallback”,puppet::params::server_passenger_max_pool,“puppet::params:
:server_httpd_service”,“puppet::params::server_external_nodes”,“puppet::pa
rams::server_template”,“puppet::params::server_config_version”,“puppet::pa
rams::server_git_repo”,“puppet::params::server_dynamic_environments”,puppe
t::params::server_environments,“puppet::params::server_environments_owner”
,“puppet::params::server_envs_dir”,“puppet::params::server_manifest_path”,
puppet::params::server_common_modules_path,“puppet::params::server_git_rep
o_path”,puppet::params::server_git_branch_map,“puppet::params::server_post
hook_content",“puppet::params::server_post_hook_name”,“puppet::params::se
rver_storeconfigs_backend”,“puppet::params::server_app_root”,“puppet::para
ms::server_ssl_dir”,“puppet::params::server_package”,“puppet::params::serv
er_certname”,“puppet::params::server_enc_api”,“puppet::params::server_repo
rt_api”,“foreman::params::foreman_url”,“foreman::params::client_ssl_ca”,“f
oreman::params::client_ssl_cert”,“foreman::params::client_ssl_key”,“forema
n::params::facts”,“foreman::params::puppet_home”,"foreman::params::puppet
basedir”)’>
–modulepath
s
2>&1
[DEBUG 2014-02-18 13:45:16 main] [1;31mWarning: Could not retrieve fact
fqdn [0m
seconds [0m
[mNotice: Finished catalog run in 0.27 seconds [0m
[ INFO 2014-02-18 13:45:16 main] … finished
Marek
Armand,
Per Marek's note about tweaking /etc/hosts, I was reminded of an issue we
had regarding bad FQDNs. I'm not sure if this could also be related
specifically to your issue, but we had some servers who's resolv.conf's
"domain" set to our domain name, and not the subdomain matching the DNS
records. It would seem to be another config spot that could have the
result of creating a bad fqdn. It produced host who's DNS name was
xyz.subdomain.domain.tld was registered in puppet/foreman as
xyz.domain.tld, which affected SSL certs and such causing much trouble.
tweak
/etc/hosts.
Marek
put
modules…
yaml" $kafo_add_progress=true include foreman::params include
foreman::params::authentication",“foreman::params::passenger”,"foreman::pa
rams::passenger_scl",“foreman::params::use_vhost”,“foreman::params::ssl”,"
foreman::params::custom_repo",“foreman::params::repo”,"foreman::params::co
nfigure_epel_repo",“foreman::params::configure_scl_repo”,"foreman::params:
:selinux",“foreman::params::gpgcheck”,“foreman::params::version”,"foreman:
:params::db_manage",“foreman::params::db_type”,"foreman::params::db_userna
me",“foreman::params::db_password”,“foreman::params::app_root”,"foreman::stuck_out_tongue:
arams::user",“foreman::params::group”,foreman::params::user_groups,"forema
n::params::environment",“foreman::params::puppet_home”,"foreman::params::l
ocations_enabled",“foreman::params::organizations_enabled”,"foreman::param
s::passenger_interface",“foreman::params::server_ssl_ca”,"foreman::params:
:server_ssl_cert",“foreman::params::server_ssl_key”,"foreman::params::oaut
h_active",“foreman::params::oauth_map_users”,"foreman::params::oauth_consu
mer_key",“foreman::params::oauth_consumer_secret”,"foreman_proxy::params::
repo",“foreman_proxy::params::gpgcheck”,"foreman_proxy::params::custom_rep
o",foreman_proxy::params::port,“foreman_proxy::params::dir”,"foreman_proxy
::params::user",“foreman_proxy::params::log”,“foreman_proxy::params::ssl”,
“foreman_proxy::params::ssl_ca”,“foreman_proxy::params::ssl_cert”,"foreman
xy::params::manage_sudoersd",“foreman_proxy::params::use_sudoersd”,"forema
n_proxy::params::puppetca",“foreman_proxy::params::ssldir”,"foreman_proxy:
:params::puppetdir",“foreman_proxy::params::autosign_location”,"foreman_pr
oxy::params::puppetca_cmd",“foreman_proxy::params::puppet_group”,"foreman_
proxy::params::puppetrun",“foreman_proxy::params::puppetrun_cmd”,"foreman_
proxy::params::puppetrun_provider",“foreman_proxy::params::tftp”,"foreman_
les,“foreman_proxy::params::tftp_root”,foreman_proxy::params::tftp_dirs,"f
oreman_proxy::params::tftp_servername",“foreman_proxy::params::dhcp”,"fore
man_proxy::params::dhcp_managed",“foreman_proxy::params::dhcp_interface”,"
or",“foreman_proxy::params::dhcp_config”,"foreman_proxy::params::dhcp_leas
es",“foreman_proxy::params::dhcp_key_name”,"foreman_proxy::params::dhcp_ke
y_secret",“foreman_proxy::params::dns”,"foreman_proxy::params::dns_managed
foreman_proxy::params::dns_forwarders,“foreman_proxy::params::bmc”,"forema
n_proxy::params::bmc_default_provider",“foreman_proxy::params::keyfile”,"f
_base_url",“foreman_proxy::params::registered_name”,"foreman_proxy::params
::registered_proxy_url",“foreman_proxy::params::oauth_effective_user”,"for
umer_secret",“puppet::params::version”,“puppet::params::user”,"puppet::par
ams::group",“puppet::params::dir”,puppet::params::port,"puppet::params::li
sten",“puppet::params::pluginsync”,“puppet::params::splay”,puppet::params:
:runinterval,“puppet::params::runmode”,“puppet::params::cron_cmd”,"puppet:
:params::agent_noop",“puppet::params::show_diff”,puppet::params::configtim
eout,“puppet::params::ca_server”,“puppet::params::classfile”,"puppet::para
ms::main_template",“puppet::params::agent_template”,"puppet::params::auth_
template",“puppet::params::nsauth_template”,"puppet::params::client_packag
e",“puppet::params::agent”,“puppet::params::server”,“puppet::params::user”
,“puppet::params::group”,“puppet::params::dir”,puppet::params::port,"puppe
t::params::server_vardir",“puppet::params::server_ca”,"puppet::params::ser
ver_reports",“puppet::params::server_passenger”,"puppet::params::server_se
:server_httpd_service",“puppet::params::server_external_nodes”,"puppet::pa
rams::server_template",“puppet::params::server_config_version”,"puppet::pa
rams::server_git_repo",“puppet::params::server_dynamic_environments”,puppe
_hook_content",“puppet::params::server_post_hook_name”,"puppet::params::se
rver_storeconfigs_backend",“puppet::params::server_app_root”,"puppet::para
ms::server_ssl_dir",“puppet::params::server_package”,"puppet::params::serv
er_certname",“puppet::params::server_enc_api”,"puppet::params::server_repo
rt_api",“foreman::params::foreman_url”,“foreman::params::client_ssl_ca”,"f
oreman::params::client_ssl_cert",“foreman::params::client_ssl_key”,"forema
n::params::facts",“foreman::params::puppet_home”,"foreman::params::puppet_
basedir")'>
–modulepath
s
2>&1
fact
fqdn [0m
0.14
seconds [0m
Marek
“Foreman users” group.
Sean M. Alderman
Senior Engineer, UDit Systems Integration and Engineering
University of Dayton
salderman1@udayton.edu
“We are not some casual and meaningless product of evolution. Each of us
is the result of a thought of God. Each of us is willed. Each of us is
loved. Each of us is necessary.”
- BXVI
When changing the /etc/hosts configuration, make sure you do it in the
correct order.
http://lukas.zapletalovi.com/2011/12/setting-hostname-properly-in-fedora-and.html
LZ
··· On Wed, Feb 19, 2014 at 09:36:30AM -0500, Sean Alderman wrote: > Armand, > > Per Marek's note about tweaking /etc/hosts, I was reminded of an issue we > had regarding bad FQDNs. I'm not sure if this could also be related > specifically to your issue, but we had some servers who's resolv.conf's > "domain" set to our domain name, and not the subdomain matching the DNS > records. It would seem to be another config spot that could have the > result of creating a bad fqdn. It produced host who's DNS name was > xyz.subdomain.domain.tld was registered in puppet/foreman as > xyz.domain.tld, which affected SSL certs and such causing much trouble. > > > > On Wed, Feb 19, 2014 at 3:36 AM, Marek Hulan wrote: > > > So the problem is that your fqdn is not set correctly. The error message > > suggests to set it using hostname command. If it does not help you can > > tweak > > /etc/hosts. > > > > -- > > Marek > > > > On Tuesday 18 of February 2014 05:17:52 Armand Guio wrote: > > > After removing puppet-dashboard, i have another error message > > > > > > > Output of 'facter fqdn' is different from 'hostname -f' > > > > > > > > Make sure above command gives the same output. If needed, change the > > > > hostname permanently via 'hostname' command and editing > > > > appropriate configuration file. > > > > (e.g. on Red Hat systems /etc/sysconfig/network). > > > > > > > > If 'hostname -f' still returns unexpected result, check /etc/hosts and > > put > > > > > > > > hostname entry in the correct order, for example: > > > > 1.2.3.4 full.hostname.com full > > > > > > > > Fully qualified hostname must be the first entry on the line > > > > Your system does not meet configuration criteria > > > > > > > > Something went wrong! Check the log for ERROR-level output > > > > The full log is at /var/log/foreman-installer/foreman-installer.log > > > > > > [ INFO 2014-02-18 13:45:14 main] Parsing default values from puppet > > > > > > > modules... > > > > [DEBUG 2014-02-18 13:45:14 main] echo > > > > > > '$kafo_config_file="/usr/share/foreman-installer/config/foreman-installer. > > > > yaml" $kafo_add_progress=true include foreman::params include > > > > foreman_proxy::params include puppet::params > > > > > > dump_values("foreman::params::foreman_url","foreman::params::unattended"," > > > > > > foreman::params::authentication","foreman::params::passenger","foreman::pa > > > > > > rams::passenger_scl","foreman::params::use_vhost","foreman::params::ssl"," > > > > > > foreman::params::custom_repo","foreman::params::repo","foreman::params::co > > > > > > nfigure_epel_repo","foreman::params::configure_scl_repo","foreman::params: > > > > > > :selinux","foreman::params::gpgcheck","foreman::params::version","foreman: > > > > > > :params::db_manage","foreman::params::db_type","foreman::params::db_userna > > > > > > me","foreman::params::db_password","foreman::params::app_root","foreman::p > > > > > > arams::user","foreman::params::group",foreman::params::user_groups,"forema > > > > > > n::params::environment","foreman::params::puppet_home","foreman::params::l > > > > > > ocations_enabled","foreman::params::organizations_enabled","foreman::param > > > > > > s::passenger_interface","foreman::params::server_ssl_ca","foreman::params: > > > > > > :server_ssl_cert","foreman::params::server_ssl_key","foreman::params::oaut > > > > > > h_active","foreman::params::oauth_map_users","foreman::params::oauth_consu > > > > > > mer_key","foreman::params::oauth_consumer_secret","foreman_proxy::params:: > > > > > > repo","foreman_proxy::params::gpgcheck","foreman_proxy::params::custom_rep > > > > > > o",foreman_proxy::params::port,"foreman_proxy::params::dir","foreman_proxy > > > > > > ::params::user","foreman_proxy::params::log","foreman_proxy::params::ssl", > > > > > > "foreman_proxy::params::ssl_ca","foreman_proxy::params::ssl_cert","foreman > > > > > > _proxy::params::ssl_key",foreman_proxy::params::trusted_hosts,"foreman_pro > > > > > > xy::params::manage_sudoersd","foreman_proxy::params::use_sudoersd","forema > > > > > > n_proxy::params::puppetca","foreman_proxy::params::ssldir","foreman_proxy: > > > > > > :params::puppetdir","foreman_proxy::params::autosign_location","foreman_pr > > > > > > oxy::params::puppetca_cmd","foreman_proxy::params::puppet_group","foreman_ > > > > > > proxy::params::puppetrun","foreman_proxy::params::puppetrun_cmd","foreman_ > > > > > > proxy::params::puppetrun_provider","foreman_proxy::params::tftp","foreman_ > > > > > > proxy::params::tftp_syslinux_root",foreman_proxy::params::tftp_syslinux_fi > > > > > > les,"foreman_proxy::params::tftp_root",foreman_proxy::params::tftp_dirs,"f > > > > > > oreman_proxy::params::tftp_servername","foreman_proxy::params::dhcp","fore > > > > > > man_proxy::params::dhcp_managed","foreman_proxy::params::dhcp_interface"," > > > > > > foreman_proxy::params::dhcp_gateway","foreman_proxy::params::dhcp_range"," > > > > > > foreman_proxy::params::dhcp_nameservers","foreman_proxy::params::dhcp_vend > > > > > > or","foreman_proxy::params::dhcp_config","foreman_proxy::params::dhcp_leas > > > > > > es","foreman_proxy::params::dhcp_key_name","foreman_proxy::params::dhcp_ke > > > > > > y_secret","foreman_proxy::params::dns","foreman_proxy::params::dns_managed > > > > > > ","foreman_proxy::params::dns_interface","foreman_proxy::params::dns_zone" > > > > > > ,"foreman_proxy::params::dns_reverse","foreman_proxy::params::dns_server", > > > > > > foreman_proxy::params::dns_forwarders,"foreman_proxy::params::bmc","forema > > > > > > n_proxy::params::bmc_default_provider","foreman_proxy::params::keyfile","f > > > > > > oreman_proxy::params::register_in_foreman","foreman_proxy::params::foreman > > > > > > _base_url","foreman_proxy::params::registered_name","foreman_proxy::params > > > > > > ::registered_proxy_url","foreman_proxy::params::oauth_effective_user","for > > > > > > eman_proxy::params::oauth_consumer_key","foreman_proxy::params::oauth_cons > > > > > > umer_secret","puppet::params::version","puppet::params::user","puppet::par > > > > > > ams::group","puppet::params::dir",puppet::params::port,"puppet::params::li > > > > > > sten","puppet::params::pluginsync","puppet::params::splay",puppet::params: > > > > > > :runinterval,"puppet::params::runmode","puppet::params::cron_cmd","puppet: > > > > > > :params::agent_noop","puppet::params::show_diff",puppet::params::configtim > > > > > > eout,"puppet::params::ca_server","puppet::params::classfile","puppet::para > > > > > > ms::main_template","puppet::params::agent_template","puppet::params::auth_ > > > > > > template","puppet::params::nsauth_template","puppet::params::client_packag > > > > > > e","puppet::params::agent","puppet::params::server","puppet::params::user" > > > > > > ,"puppet::params::group","puppet::params::dir",puppet::params::port,"puppe > > > > > > t::params::server_vardir","puppet::params::server_ca","puppet::params::ser > > > > > > ver_reports","puppet::params::server_passenger","puppet::params::server_se > > > > > > rvice_fallback",puppet::params::server_passenger_max_pool,"puppet::params: > > > > > > :server_httpd_service","puppet::params::server_external_nodes","puppet::pa > > > > > > rams::server_template","puppet::params::server_config_version","puppet::pa > > > > > > rams::server_git_repo","puppet::params::server_dynamic_environments",puppe > > > > > > t::params::server_environments,"puppet::params::server_environments_owner" > > > > > > ,"puppet::params::server_envs_dir","puppet::params::server_manifest_path", > > > > > > puppet::params::server_common_modules_path,"puppet::params::server_git_rep > > > > > > o_path",puppet::params::server_git_branch_map,"puppet::params::server_post > > > > > > _hook_content","puppet::params::server_post_hook_name","puppet::params::se > > > > > > rver_storeconfigs_backend","puppet::params::server_app_root","puppet::para > > > > > > ms::server_ssl_dir","puppet::params::server_package","puppet::params::serv > > > > > > er_certname","puppet::params::server_enc_api","puppet::params::server_repo > > > > > > rt_api","foreman::params::foreman_url","foreman::params::client_ssl_ca","f > > > > > > oreman::params::client_ssl_cert","foreman::params::client_ssl_key","forema > > > > > > n::params::facts","foreman::params::puppet_home","foreman::params::puppet_ > > > > basedir")'> > > > > > RUBYLIB=/usr/lib/ruby/vendor_ruby/kafo/../..//modules: puppet apply > > > > > > > > --modulepath > > > > > > /usr/share/foreman-installer/modules:/usr/lib/ruby/vendor_ruby/kafo/module > > > > s > > > > 2>&1 > > > > [DEBUG 2014-02-18 13:45:16 main] [1;31mWarning: Could not retrieve > > fact > > > > fqdn [0m > > > > > > > > [mNotice: Compiled catalog for kansas in environment production in > > 0.14 > > > > > > > > seconds [0m > > > > > > > > [mNotice: Finished catalog run in 0.27 seconds [0m > > > > > > > > [ INFO 2014-02-18 13:45:16 main] ... finished > > > > -- > > Marek > > > > -- > > You received this message because you are subscribed to the Google Groups > > "Foreman users" group. > > To unsubscribe from this group and stop receiving emails from it, send an > > email to foreman-users+unsubscribe@googlegroups.com. > > To post to this group, send email to foreman-users@googlegroups.com. > > Visit this group at http://groups.google.com/group/foreman-users. > > For more options, visit https://groups.google.com/groups/opt_out. > > > > > > -- > Sean M. Alderman > Senior Engineer, UDit Systems Integration and Engineering > University of Dayton > salderman1@udayton.edu > > *"We are not some casual and meaningless product of evolution. Each of us > is the result of a thought of God. Each of us is willed. Each of us is > loved. Each of us is necessary."* - BXVI > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users. > For more options, visit https://groups.google.com/groups/opt_out.
Later,
Lukas “lzap” Zapletal
irc: lzap #theforeman
