After configured an user on foreman, at login with the same I obtain the
follow SSL_connect SYSCALL returned=5 errno=0 state=unknown state
Don't worry I solved it. I had configured foreman to listen in 389 port,
and Foreman worked in security mode, I have change to 636 and fixed it.
Thanks for your support.
Il giorno venerdì 17 maggio 2013 11:42:32 UTC+2, Euclideo ha scritto: > > After configured an user on foreman, at login with the same I obtain the > follow SSL_connect SYSCALL returned=5 errno=0 state=unknown stateHello,
please provide more info about your setup. What is your LDAP
configuration?
LZ
On Fri, May 17, 2013 at 02:42:32AM -0700, Euclideo wrote: > After configured an user on foreman, at login with the same I obtain the > follow SSL_connect SYSCALL returned=5 errno=0 state=unknown state > > -- > You received this message because you are subscribed to the Google Groups "Foreman users" group. > To unsubscribe from this group and stop receiving emails from it, send an email to foreman-users+unsubscribe@googlegroups.com. > To post to this group, send email to foreman-users@googlegroups.com. > Visit this group at http://groups.google.com/group/foreman-users?hl=en. > For more options, visit https://groups.google.com/groups/opt_out. > >–
Later,
Lukas “lzap” Zapletal
irc: lzap #theforeman
