foreman-nightly-rpm-pipeline 1522 failed
Foreman RPM nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/1522/
foreman-pipeline-foreman-nightly-almalinux8-upgrade (failed) (remote job)
foreman-pipeline-foreman-nightly-centos8-stream-install (passed) (remote job)
foreman-pipeline-foreman-nightly-almalinux8-install (passed) (remote job)
foreman-pipeline-foreman-nightly-centos8-stream-upgrade (failed) (remote job)
Upgrade parts of the job failed due to:
19:23:11  e[0;31m    2022-06-27 23:23:02 [NOTICE] [root] Loading installer configuration. This will take some time.e[0m
19:23:11  e[0;31m    2022-06-27 23:23:07 [NOTICE] [root] Running installer with log based terminal output at level NOTICE.e[0m
19:23:11  e[0;31m    2022-06-27 23:23:07 [NOTICE] [root] Use -l to set the terminal output log level to ERROR, WARN, NOTICE, INFO, or DEBUG. See --full-help for definitions.e[0m
19:23:11  e[0;31m    2022-06-27 23:23:10 [ERROR ] [root] Parameter foreman-db-database invalid: nil is not a valid stringe[0m
19:23:11  e[0;31m    Error during configuration, exitinge[0m
19:23:11  e[0;31m  stdout_lines: <omitted>e[0m
@ekohl looks related to the changes made around dropping UNSET?
Yes, I should have linked back the PR to fix it (merged by now):
https://github.com/theforeman/foreman-installer/pull/787
