Rsync fails while setting up boxes, but I have no idea why because I’m not aware of anything changing here.
21:58:55 e[0;31m stderr: |-e[0m
21:58:55 e[0;31m There was an error when attempting to rsync a synced folder.e[0m
21:58:55 e[0;31m Please inspect the error message below for more info.e[0m
21:58:55 e[0;31m e[0m
21:58:55 e[0;31m Host path: /root/forklift/e[0m
21:58:55 e[0;31m Guest path: /vagrante[0m
21:58:55 e[0;31m Command: "rsync" "--max-size=100m" "--no-owner" "--no-group" "--rsync-path" "sudo rsync" "-e" "ssh -p 22 -o LogLevel=FATAL -o ControlMaster=auto -o ControlPath=/tmp/vagrant-rsync-20220805-60244-1jl5t9t -o ControlPersist=10m -o IdentitiesOnly=yes -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null -i '/root/forklift/.vagrant/machines/pipe-foreman-server-nightly-almalinux8/libvirt/private_key'" "--exclude" ".vagrant/" "/root/forklift/" "vagrant@192.168.121.57:/vagrant"e[0m
21:58:55 e[0;31m Error: rsync: on remote machine: --sparse-block=1024: unknown optione[0m
21:58:55 e[0;31m rsync error: syntax or usage error (code 1) at main.c(1582) [server=3.1.3]e[0m
21:58:55 e[0;31m rsync: connection unexpectedly closed (0 bytes received so far) [sender]e[0m
21:58:55 e[0;31m rsync error: error in rsync protocol data stream (code 12) at io.c(226) [sender=3.1.3]e[0m
Since it happens on both CentOS and Almalinux it is probably something from the host.
