foreman-nightly-rpm-pipeline 215 failed
Foreman RPM nightly pipeline failed:
https://ci.theforeman.org/job/foreman-nightly-rpm-pipeline/215/
foreman-nightly-centos7-test (failed)
this is now failing with same failure as debs:
+ ansible-playbook -i localhost provision.yml
 [WARNING]: Unable to parse /home/foreman/workspace/foreman-nightly-
centos7-test/foreman-
infra/puppet/modules/jenkins_job_builder/files/centos.org/ansible/localhost as
an inventory source
 [WARNING]: No inventory was parsed, only implicit localhost is available
 [WARNING]: Could not match supplied host pattern, ignoring: all
 [WARNING]: provided hosts list is empty, only localhost is available
PLAY [localhost] ***************************************************************
TASK [Gathering Facts] *********************************************************
ok: [localhost]
TASK [Get a new node] **********************************************************
fatal: [localhost]: FAILED! => {"changed": false, "msg": ""}
PLAY RECAP *********************************************************************
localhost                  : ok=1    changed=0    unreachable=0    failed=1
